restoration project: GT6 MK III
hymodyne
I picked up this '72 GT6 Last fall.
the floor there is wood. https://i113.photobucket.com/albums/n213/hymodyne/DSCN0748.jpg
I had to make quite a few overlay patches for the frame.
https://i113.photobucket.com/albums/n213/hymodyne/DSCN0811.jpg
https://i113.photobucket.com/albums/n213/hymodyne/DSCN0816.jpg
Something of the sort will be necessary for the frame tubes as well.
https://i113.photobucket.com/albums/n213/hymodyne/DSCN0755.jpg
I used a brush-on rust transformer over the entire frame prior to priming
https://i113.photobucket.com/albums/n213/hymodyne/DSCN0829.jpg
https://i113.photobucket.com/albums/n213/hymodyne/DSCN0833.jpg
and painting with epoxy paint.
I have the engine and gearbox out of the car. I decided on a T-9 conversion and have started to pick up the necessary parts and instructions from Canley's > A local transmission specialist is giving my diff and sierra gearbox a once over. Thanks to some of your own detailed rebuild images, it looks like he will shorten the input selector.
more to come...
Hym
V
vagt6
Hym, nice reso work on that GT6. You are a brave man, picking one that was basically kaput.
Thanks for posting the photos, and for saving another great Triumph car.
Keep us posted on the engine/drivetrain install. It would great if you could document the gearbox installation and diff.
Good luck . . . :thumbsup:
JPSmit
+1 There is a fine line between restoration and madness and you may have crossed it. Well done! :bow:
keep us posted.
hymodyne
hymodyne
Re: restoration project: GT6 MK III up-date 10/02
I had already added 16 GA strips to lengthen the inner sill in preparation for the rocker panel. The rear sill had already been installed, serving as a guide for the length of the sill where it meets the lower rocker panel. I drilled holes on all of the contact surfaces, but the first had to be re-done, as I hadn't removed enough of the galvanized layer or zinc plating on the panel before welding. the corner was salvaged from the original panel. it was easier to patch it back in than to recreate the pieces needed to finish the reproduction.the last
photos is of the build up to a rear valence modification I've begun.
[/img]
[/img]
[img:right]https://
[/img]
[img:right]https://
[/img]
[img:center]https://
[/img]
hymodyne
hymodyne
an update. I've attached all the replacement metal on the body tub, New lower sills, front and rear of the rear wheel well and new rocker panels.
https://i113.photobucket.com/albums/n213/hymodyne/DSCN0935.jpg
https://i113.photobucket.com/albums/n213/hymodyne/DSCN0934.jpg
https://i113.photobucket.com/albums/n213/hymodyne/DSCN0937.jpg
https://i113.photobucket.com/albums/n213/hymodyne/DSCN0933.jpg
I've have the car elevated about four feet off the ground so I can spray the under side with undercoating.
next I plan to finish some spot metal stripping and prep the tub for primer inside and out.
Hym
hymodyne
hymodyne
D For Sale Custom 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
D For Sale For Sale: 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
H Restoration project, needs work Austin Healey 16
K TR4/4A TR4A Restoration Project Triumph 0
M_Pied_Lourd TR5/TR250 Started my TR250 Restoration Project..... Triumph 16
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
JimLaney I need some basic restoration info for my first car project Restoration & Tools 20
A Project Small Axe Racing: Big Healey restoration/vintage racer build Racing 30
1 1980 Panther Lima restoration project Other British Cars 11
E TR2/3/3A New TR3 restoration Project Triumph 21
J TR4/4A New TR4 Restoration Project Triumph 13
H my 59 AH BN4 restoration project Austin Healey 17
T Show us your project or rolling restoration Triumph 46
PAUL161 Interesting Restoration Project! Nice! MG 24
angelfj1 Weekend Project- Smiths Heater Restoration Triumph 13
Patrick67BJ8 Restoration Project Management software Austin Healey 12
A New member, just started a restoration project. MG 33
David_K Help with value of AH 3000 restoration project Austin Healey 6
D TR6 Rotisserie for a TR6 restoration project Triumph 12
K AH 3000 BJ8 restoration project Austin Healey 2
U Healey restoration project now on eBay for 1penny! Other British Cars 0
A 100/6 BN4 Restoration Austin Healey 6
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Greg Chait Wanted Stalled or Abandoned MG Restoration Projects MG Classifieds 3
H General MG MGYB--Semi-- restoration MG 2
D My new restoration tool Restoration & Tools 13
D For Sale 1955 DAIMLER CONQUEST RUNS NEEDS RESTORATION. Other British Classifieds 1
JoeO 72 TVR Vixen hybrid restoration TVR 1
Rob Glasgow Restoration: What Would You Have Done Differently? Austin Healey 37
GeorgeC Rich Chrysler's "Introduction to Austin-Healey Restoration" Austin Healey 3
D Fascia Restoration Austin Healey 14
J Restoration Progress - Boot Installed Austin Healey 1
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
BigGreen For Sale Anderson / Moment Restoration Guide for sale Austin Healey Classifieds 0
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Tr4 restoration books Restoration & Tools 2
F YouTube Healey Restoration Videos Austin Healey 5
R TR2/3/3A Re-start after total restoration Triumph 22
F GT6 Looking to sell - in progress restoration Triumph 19
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 6
Don Riicardo Reliant Scimitar GTE se5a restoration Other British Cars 23
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
Josandra 1949 singer nine roadster restoration by ladies Other British Cars 20
C SoCal Restoration Shops Austin Healey 15
HealeyRick Coronet Cream Restoration Austin Healey 1
H Restoration Magazines and Books Spridgets 4
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
