TR6 Rotisserie for a TR6 restoration project
  • Thread starter Deleted member 4998
  • Start date
Deleted member 4998
Hi,
Last spring after four years of hard but challenging work I completed the rebuilding of a MG TF which I enjoyed driving it all summer. Recently I bought a 1971 TR6 that the previous owner has started the restoration but decided to quit the project after he did a very good job on the frame repairing what need to be fix and replacing all the parts with new ones (bushing, springs, shocks, tie rods etc). I bought the car already dismantled which save me work but making the task more difficult to put it back together being not to familiar with the TR6. I started the project by fabricating a rotisserie because the body need a lot of repair and that precious tool will ease the task quite a lot. I will keep posting picture of my progress along the way and probably ask for some advises.
GeeBee
LastDeadLast
That's really nice! You should make plans for the rotisserie. I'm sure lot of guys here would want one, including myself.
Looks like you'll have a pretty cool setup when that TR is done. Good luck and welcome to the board.
Radford
What a clever use for that GM jack. No kidding, that's an awesome rig. /ubbthreads/images/graemlins/yesnod.gif
trboost
A classic case of shiprights disease ! Look how organized your garage is, you should be ashamed. How do you expect to restore a british car with out parts all over the place /ubbthreads/images/graemlins/smile.gif
Good luck with the resto, look's great so far. It's all worth it to put another potential parts car or junker back in to service to be enjoyed..
P.S. Nice rear shock set up.
71tr
That thing is awesome, wish I had that sense of organization and procedure. Nope, just boxes of parts, a homemade wooden body dolly and completed pieces scattered about my house!
Question on the rear shock setup, is that the thru the body type that will have to be dismantled before the tub can be reunited?
Deleted member 4998
You are right about the rear shock. The inner rear fender is sandwiched between the top shock support and the bracket
71tr
GeeBee, thanks for the photos. I'm in about the same situation here. The frame is done and all suspension components, just waiting for a rear hub rebuild to get the chasis rolling again. The rebuilt engine is wrapped in a blanket waiting for me to finish the tranny-overdrive rebuild. All body wings are done and now the body tub awaits. Not too much of a rust problem, mostly just removal of dirt and grease then repaint. I noticed the yellow suspension bushes, what is the brand?
Deleted member 4998
The bushes are polyurethane and they were ordered with the Spax shock conversion kit from Rimmer Bros. of England. The invoice I have doesn't specify the brand of the bushes. Hope this help.
71tr
Those darn English, they have all the coolest stuff over there. Thanks and good luck with the project, keep us posted.
StagByTriumph
You can get that same shock conversion kit from TRF, Victoria British, BPNW and Moss, all in the USA!
71tr
I must not have been clear, I was referring to the fun yellow suspension bushes.
trboost
The poly bushings (Prothane ) are also available from Moss, TRF & others here, but usually come in red. It's always nice to color coordinate bushings & body color /ubbthreads/images/graemlins/laugh.gif
These give the car a far superior tightness without any harsh feedback or poor wear quality of the original rubber parts. It is critical that these bushings are well lubed with the grease supplied.
B Rotisserie question Spridgets 4
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
Bayless The very simple rotisserie Spridgets 3
Bayless Rotisserie question? Spridgets 5
J pictures of a 3000 on a rotisserie ?? Austin Healey 5
I Chassis rotisserie..? Austin Healey 10
A Engine stand rotisserie plans Austin Healey 12
Jim_Gruber Rotisserie Pics and Lessons Learned Spridgets 1
T Healey rotisserie Austin Healey 12
J Best Rotisserie to work with Triumph 0
R I Need Rotisserie plans for midget Spridgets 18
J Rotisserie or Not? Spridgets 28
luke44 TR2/3/3A TR3 rotisserie or body buck questions Triumph 24
A Rotisserie set up? Spridgets 17
S bj8 rotisserie Austin Healey 4
Gray_Cat Engine Stand Rotisserie Spridgets 4
PAUL161 Found a Rotisserie at a Good Price. Restoration & Tools 1
motofiaccone Rotisserie or Build Table Spridgets 12
John Moore Rotisserie Spridgets 22
M Restoration on a Rotisserie Triumph 15
jackq Rotisserie Restoration & Tools 22
SHG Some Thoughts on Rotisserie Restorations Austin Healey 49
JPSmit Home Made Rotisserie - I'm sooooo Happy Spridgets 15
S TR2/3/3A rotisserie on a tr3 Triumph 7
timbn2 BN-2 on a rotisserie - mounting points question?? Austin Healey 5
B Poor Mans Rotisserie Spridgets 3
mcguijo Auto Rotisserie Restoration & Tools 10
B Rotisserie for E Type Roadster Jaguar 7
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
