MGBpilot
After test driving a MINI Cooper and a MINI Cooper S (and buying a Cooper S) I have come to appreciate the extra kick that can come with supercharging.
Got me to thinking about bolting the Moss supercharger kit onto my '77 B.
I've spent several hours reading information on the 'Net about supercharing MGBs, and I'm still a little confused. Could use a little advice to help me make my final decision.
I rebuilt my B's engine three years and 13,000 miles ago:
- 30-over "high-compression" pistions (I think it gave me 8.8:1 compression ratio).
- 5-under on the crankshaft.
- heavy duty valve springs.
- mild road cam.
- Eurospec dizzy with Lucas Sport Coil.
- double row timing chain.
- Ford Type-9 5-speed transmission.
- Weber DGV carb, which I put on the engine before the rebuild.
I've been reading how the Moss kit works best on low-compression (8:1) engines.
My question, given the build described above, is the Moss kit an appropriate add-on for my particular application?
Would also appreciate a recap of the pros and cons on supercharging.
At this point my choices are going to be either leave things alone (everything is running smooth)or pull the Weber and replace it with a Moss supercharger.
Appreciate the input. Thanks for the opinions.
Ken V.
'77 MGB
Safety Fast!
- mild road cam.
Ken V.
'77 MGB
Safety Fast!
