Rebuilding 1275 for a little performance...
lbc_newbie
OK, so I was talked into pepping up the 1275. I'm going .030 over with a performance cam. It will still have the Weber 32/26 DGV down-draft carb. One question is will I need to increase my exhaust from 1.75 to 2.0 inches? Is there any re-jetting necessary? Eventually, the ignition will be updated to an MSD type ignition. Open to thoughts, experiences, and catastrophies...
I'd think 1.75" is more than adequate.
bill_powell
Your quest for knowledge lies here:
https://www.amazon.com/Tuning-Engine-Defi...6828&sr=1-5
Get yourself <span style="font-style: italic">The Book</span>, and you'll be one happy grasshopper.
Seriously.
...gratuitous photo:
Gray_Cat
Be sure to have the rotating parts balanced while you're at it. Crucial to longevity and adds a bit of performance as well!
Roy :cheers:
GeeBee1
1.75 s/b fine, the most performance gains for the buck are in the head.
Pat
Dadandson
According to Mr. Vizard, all performance enhancements begin at the top of pistons. While have new main, rod and cam bearings can reduce friction, paying closer attention to the cam, valves, porting and polishing of the head and intake manifold will give you the most HP for the dollar. Buy the book! Borrow the book! Even steal the book in you need to! It will set you on the right direction before you start buying parts!
GeeBee1
Pretty much says it all.
Pat
John Moore
theleisure said:
Hey Pat,
Can you elaborate on that a bit, please. I'm going to be redoing a 1275 soon and the limiting factor in my rebuild will be money.
The simamese ports on the A & B series engines are restrictive. Here is an article that Sean Brown wrote about the Port & Polish job he did on my MGB head. Different engine, but similar design and idea. The result was impressive.
I know Hap does this work on A series heads, I would imagine that Sean does too.
https://www.flowspeed.com/board-week.htm
T Rebuilding a 1275 for a BE Spridgets 8
pbraun Anyone have a 1275 core for rebuilding? Spridgets 8
S TR2/3/3A Rebuilding a cylinder head Triumph 10
S TR2/3/3A when rebuilding a differential Triumph 9
M TR2/3/3A Rebuilding suspension Triumph 29
G Rebuilding Front Seats Austin Healey 4
E TR6 Rebuilding Distributor Triumph 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
S TR2/3/3A Engine Rebuilding. Triumph 14
L MGB Rebuilding a 1977 MGB MG 1
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
KVH General Tech Rebuilding the Engine Triumph 5
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
drooartz Rebuilding rear axle Spridgets 19
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
steveg Rebuilding roadster windshield Austin Healey 24
A Rebuilding Tiger window regulator question Sunbeam (Rootes) 3
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
S TR2/3/3A rebuilding bomb nose starter Triumph 9
W Looking for engine rebuilding 100-6 Austin Healey 12
KVH General Tech Rebuilding the Engine--a few practice pointers [for me] Triumph 11
R TR2/3/3A Rebuilding H4 carbs Triumph 8
S TR2/3/3A rebuilding door panels Triumph 15
Rut TR4/4A Seat rebuilding Triumph 3
steveg Rebuilding the Dip Switch Austin Healey 9
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Rut TR4/4A Seat rebuilding Triumph 6
CZ_Dave MGB Is it worth doing the Shock Conversion Kit or Rebuilding Exsisting shocks? MG 16
JFeher TR2/3/3A Rebuilding A type OD I Need advise / measurements Triumph 14
KVH TR4/4A Engine rebuilding Triumph 17
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
Got_All_4 TR2/3/3A Continually Rebuilding of my J Type Gear Box Triumph 2
drooartz MGB-GT Rebuilding the seats MG 28
Gray_Cat MGB Rebuilding MGB Overdrive MG 4
S TR2/3/3A rebuilding a tr3 water pump Triumph 22
Lin Rebuilding a master cylinder for BT7 Austin Healey 3
PatGalvin TR2/3/3A Guide for SU Rebuilding Triumph 8
H TR4/4A 4A convertible top rebuilding sequence Triumph 8
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
Lukens TR2/3/3A More questions about rebuilding my steering box Triumph 20
charleyf TR4/4A Hs6 carb rebuilding Triumph 8
S TR2/3/3A Transmission Rebuilding Triumph 29
L 1966 BJ8 frame rebuilding questions Austin Healey 1
djackson Rebuilding 100/6 Transmission Austin Healey 6
bighealeysource Rebuilding BN2 generator Austin Healey 5
Xte Rev counter rebuilding ... Austin Healey 2
J TR6 rebuilding tr6 rear hubs Triumph 13
