Rear Seal
Skip & Lynne
Has anyone used any of the after market rear seal kits. I am still in the frame off stage but if the engine is going to leak I would rather replace the seal when I rebuild the engine rather than after it is in the car. Thanks Skip 61 BT7
DougR
I have. It's a 948 cc Sprite engine that USED TO mark it's territory quite well. I had even fashioned a "diaper" (driveway mat) for the times when I had to park in someone's driveway. Now I can even park in my OWN driveway!!!
Michael Oritt Rear Crank Seal Kit Austin Healey 7
J Rear Main Seal Kit Austin Healey 1
D MG Midget 1275 rear oil seal. Spridgets 0
A Rear Axle Oil Seal Austin Healey 4
W Rear Axle Hub Seal Austin Healey 8
edkap2002 TR6 TR6 rear pinion seal Triumph 3
S TR2/3/3A rear main seal is leaking Triumph 13
EWD TR6 Rear Transmission Seal 74 TR6 Triumph 4
Jim_Stevens TR2/3/3A Marx Viton rear engine seal Triumph 4
JFS TR6 Rear Oil Seal? Triumph 1
R J-H rear transmission seal? Why can't I find it on the web? Other British Cars 1
H For Sale Rear end bearing and seal set Austin Healey Classifieds 0
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
R TR2/3/3A Changing rear seal Triumph 23
D rear main seal Austin Healey 13
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
Rut 1275 rear seal help Spridgets 0
Rut TR4/4A Rear bonnet seal Triumph 18
J Rear Oil Seal Kit - Spring Austin Healey 9
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
drooartz Rear wheel hub oil seal Spridgets 6
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
Got_All_4 TR2/3/3A Tr3 rear differential seal Triumph 7
KVH General TR Rear Differential Seal Triumph 7
Gerard 1098 10CC rear main seal conversion Spridgets 4
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
Bob Claffie MGB Transmission rear seal MG 8
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
2wrench TR6 Replacing rear seal on W58 HVDA transmission conversion. Triumph 4
KVH General TR Rear Main Seal--Minor Problem Triumph 4
R Dennis Welch Rear Crank seal conversion - Gap in back plate Austin Healey 19
Editor_Reid Rear Main Seal for BN2 Austin Healey 12
steveg Learned something about rear axle seal Austin Healey 3
K TR4/4A Gearbox rear seal removal again....... Triumph 2
J BJ8 rear main seal kit - is it necessary and worth the risk to install? Austin Healey 33
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
B TR6 Rear Oil Seal Housing Triumph 2
B TR6 1971 clutch and rear oil seal Triumph 2
C TR4/4A Rear main seal Triumph 36
S TR2/3/3A rear main seal Triumph 20
E 100 4 Does anyone recognize this rear main seal mod? Austin Healey 12
K TR2/3/3A Replacing rear seal on gearbox? Triumph 10
steveg Rear caliper seal clamping ring Jaguar 1
KVH TR4/4A Viton Rear Main Seal Triumph 12
MGTF1250Dave T-Series TF Gearbox Rear Seal Replacement MG 2
T BN4 Hard Top rear screen seal Austin Healey 10
Zitch TR4/4A Non OD rear transmission seal replacement Triumph 1
S Rear crank seal oil leak BN2 Austin Healey 20
