Quick rear brake question
tosoutherncars
OK, here we go, for the sake of completeness...
DRIVER side.
PASSENGER side.
Sorry for the slightly fuzzy pix, my phone cam is less than crystal clear.
JPSmit
JPSmit
looks nice
Sportsdoc
I talked with the vendor today and I got the wrong cylinder. New ones on the way soon.
Platinum
Well done.
tony barnhill
Great Pumpkin - R.I.P
DRIVER side.
PASSENGER side.
Those photos show your assemblies upside down...then the question becomes: is your driver side really your passenger side & vice versa?
tosoutherncars
Err... don't think so, Tony! Those are right-way up (this is for a Midget, remember, not a B)... handbrake assy on rear (both cases)... 'blank spot' on pads is on the leading edge. Pretty sure that's right.
tony barnhill
you're right...I got stupid on that one.
jvandyke
Well, I guess I'm glad I checked. I went by previous install and pictures from manuals but...
Passenger side had the lower spring outboard of shoes. I caught that. But I put all the shoes on with funny oblong whole at the bottom. Just like the old came off is how I put the new on.
Just goes to show you how wrong the last guy could of done it.
So he had one shoe each side upside down and one spring outboard.
I had a heck of time getting it all on there, maybe because one shoe on each side was upside down?
I put the springs and pried the shoes around and over the hubs and "massaged" everything into alignment. Don't relish the idea of doing it all again.
I almost did the shoes before I put the axles back together but I was so concerned about getting grease on them I didn't, now I wish I had, seems like it'd be easier with the hubs off.
Is there a "best method" for getting stuff together easily? I can't imagine trying to get the springs on after the shoes are nearly set.
JPSmit
JPSmit
yes, take it to a shop.
seriously, install the wheel cylinder and adjustment bolt (the side extensions just lie in there. Put the springs on the pads and just hook them on the cylinder one side at a time and likewise the bottom. I seem to recall that you have to wiggle in the emergency brake at the same time but it is very easy.
Andre the Giant
Who needs rear brakes? :laugh:
Back when I had a Midget, I remember the rears being somewhat of a pain, but not outrageous. The adjuster gave me fits though. I adjusted them one day and must have tightened them a bit too much. On the way home from work, at a stop sign, I noticed smoke coming from the one of the rear wheels. The drums were not far away from glowing.
I wish I had some knowledge to share, but I am currently MG-less. :frown:
JPSmit
JPSmit
which reminds me of the very cold snowy day years ago when my father drove his DKW to work with the rear wheel frozen. This was long before people knew about front wheel drive and there was enough ice that he didn't notice - the tire didn't turn, it just slid. he actually had someone follow him into the parking lot to find out how a car could drive without the wheel turning - thanks for the memory!
Platinum
I'm pleased this came back to help! DPO's have been into every part of these cars by now, so it points out you can take NOTHING for granted.
And WHERE'S JEFF?!?!?
Hooper11772
Since you all seem to be the rear brake experts do any of you have a trick for loostening a stuck rear adjuster. I cant get it to move and the rear hub bolts are rusted to the axel so I cant pull the whole thing like in the pic above to soak it. I don't want to round the square peg off but am getting frustrated.
tosoutherncars
Two words... Air tools. :wink: Your backing plate is stuck to the axle flange? Those four bolts are pretty accessible. Soak them with penetrating spray, let them sit for a day or two, and then get an air ratchet on them.
Otherwise... the adjuster is a square drive, like the oil drain plug. They make sets of three sockets that fit most such plugs... you might want to use the one you *can* get out to ensure you have a very good fit, before you put a breaker bar on it! And, once you get it out & clean, don't forget a good smear of copper / anti-sieze when it goes back together.
Jim_Gruber Reinstalling Rear End in a BE - Quick Steps Spridgets 8
Willie_P Quick question: rear diff TR 3/4 Triumph 6
JPSmit Quick Question - rear hub torque Spridgets 4
JPSmit Very Quick Question - rear oil seal Spridgets 2
S TR6 TR6 rear brakes--quick question Triumph 3
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T MGB Quick question about something that don't really matter just want to know. MG 9
dougie A Quick Trip Around Oulton Park.... Austin Healey 3
S Wedge tr7/8 quick release steering wheel Triumph 0
Jim_Stevens TR2/3/3A Quick measurement needed Triumph 4
Gerard Datsun 5 speed Quick shift/short shift prototype Spridgets 41
Got_All_4 TR2/3/3A Quick Overdrive Wiring Question Triumph 6
P TR6 Quick starting Triumph 2
S MGB 1980 MGB quick question MG 2
2billydavies TR2/3/3A Just a quick thanks to everyone who helped with my questions Triumph 7
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
J General Tech Quick Dist question. TR3/4 vs Heralod Triumph 12
mgedit TR2/3/3A Quick Question on Thermostat Triumph 14
judow Can't post except in quick reply and other issues FORUM Navigation Questions 0
Willie_P TR4/4A Quick HELP - TR4 fender beading.... Triumph 3
H quick insulation paint color quesrion Austin Healey 7
bthompson A quick 1500 fix for when you go for reverse and rip off your shift lever! Spridgets 4
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
S TR6 Quick TR6 alternator question Triumph 6
S TR6 Quick TR6 gear reduction starter wiring help Triumph 10
M Quick tachometer wiring question on a '65 Spridgets 10
Jim_Gruber Quick Engine Install for Bugsy II Spridgets 22
Willie_P Help: quick hub torque questions Triumph 3
RAC68 A Quick Question [Clutch Master Seals] Austin Healey 2
aeronca65t MGB Quick MGB motor swap MG 3
MCNX_BFF Quick catch-up and trailer question Triumph 8
RJS Radiator Fan Bolts - need quick help Triumph 4
skelly Quick question from a newbie Spridgets 10
B Smelling like fuel and oil after a quick drive? Austin Healey 29
PatGalvin Captive nuts?? quick question Triumph 7
abarth69 quick help needed Spridgets 3
JPSmit Quick Spark plug question Spridgets 10
Coyote1 Need a quick measurement Triumph 7
T TR4/4A Two quick OD TR4a wiring questions Triumph 7
regularman Quick, right now go to ESPN Spridgets 2
glemon Quick Easy Removeable Cupholder Triumph 4
Randy Forbes Quick's trip to the Morgan Motor Co., LTD... Austin Healey 4
J Details, Details. Quick questions. Spridgets 11
PATR8 a quick look at the Pittsburgh Craigslist Triumph 1
drooartz MGB That was quick: MGB heading to my garage MG 24
Sarastro Quick dumb transmission question Spridgets 9
S A quick introduction Spridgets 21
T Quick fuel pump question - mounting angle MG 3
S Quick Release Steering wheel hub Triumph 1
T TR4/4A TR4a retrofitting of roll bar - quick question Triumph 1
