Question on purchase [motor size]
Curifor
Hello all,
I have been bitten by the Mini bug and am looking at purchasing a Mini here in Chile where I live.
However, my question is how do I tell which motor the Mini has, whether it is 850cc, 998cc, 1275cc or 1380cc. Is there a difference in block size? Or are the larger motors just bored out more?
I ask because I am looking at a Mini 850 with what the owner claims is a 1380cc motor, but I have my doubts. I assume a test drive against a legitimate 850 would immediate demonstrate differences in power, but barring that, how do I tell?
Any links or websites to info on Mini engines would be very helpful.
Also, is it true in the UK that there are no chassis VIN numbers? Here in Chile there are only engine numbers.
Thanks
Curifor
mongoose
An 850 would be real slow. A 1380 would have some good pep. I've had both. 850, 998, 997, 1098 are "small bore". 970, 1071, 1275 are "large/big bore". A 1380 is a much overbored 1275. An easy, but not absolute, way to tell the difference between small and large bore motors is to look at the heater tap on the cylinder head. Small bores have it perpendicular to the head, large bores have it diagonal. In the picture is a large bore motor. The green and blue dots are where the heater tap gets bolted to the head. I don't have one on my motor, but the holes are cast in the head. I say "not absolute" way of identifying because large bore heads have can be put on small bore blocks with some machining. (The stud holes are the same on both blocks.) While small bore heads can be put on large blocks, it is impractical.
A good site to learn about minis is https://www.minimania.com
Hope this helps.
R GT6 Looking to purchase GT6 Rust repair question? Triumph 4
Newkie Simple Brake purchase ?question? MG 10
jaybird NEED HELP! Question about ebay purchase [my SUs] MG 13
Randy Harris E Type Purchase Question Jaguar 5
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
