Question about silicone sealers
sultanoswing
Does anyone have any experience using silicone water sealants along the front dog leg to retard water entry?
You know, the type which comes in one of those cream-dispenser type tubes?
dklawson
I'm not familiar enough with MG bodywork to comment on the specific seam. However, I try to use seam sealer instead of silicone. RTV (silicone in a tube) will not accept paint.
Banjo
I think your talking about the seam between the rocker and the quarter panal, below the rear corner of the door. If so, then dklawsons reccomendation is good. The RTV dosen't have the adhesion to stay in the seam forever, and it'll start peeling out soon. The seam sealer will stay in there for good, and you can paint over it. (it's also available in a squeeze tube at the auto paint store)
If your talking about the seam between the front fender and the rocker, at the bottom of the front edge of the door, then I personally woulden't use any sealer on that. That's a bolt on part, and I would be concerned with trapping water in behind there. There are lots of places on the front fender where water can get in so it needs to be able to get out.
sultanoswing
sultanoswing
I'm talking about the dog-leg shaped seam on top, between the front guard panel and the cowl - this one (with the black box around it). There's a leak when it's raining through this seam (I think) onto my leg!
ps. this oldie isn't my car, just a 'net pic I found!
Picture Here
RichC
Look for 3M Automotive Seam Sealer Part #08370 (grey) #08369 (white) at about $15 - $16 for a foil packet. The "Fast n Firm" 3M cartridge tube for about $10 might be nice to have too. (Part #08505)
Banjo
[ QUOTE ]
[/ QUOTE ]
OOOOOOOHHHH! ok. I know which piece you mean now. Does it still have the bead piece, or has that been removed. My dads MG is missing one (fiberglass fender thanks to P.O.)
Either way, definatly go with the 3M stuff.
Those don't commonly leak unless the fenders have been removed at one point.
Take a close look at the rubber seals at the base of the windshield posts and the seal across the base of the frame. these are notorius leakers.
For these you can carefully pry up on the seal and squeeze some clear silicone underneath then wipe any access off before it sets up.
Best of Luck Guv'na
bighealeysource silicone brake fluid question Austin Healey 3
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
B TR4/4A Jaeger Gauge Question Triumph 16
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
R TR6 Starter wiring question Triumph 6
