Paint Code
Gnasha
Hello, this is my first post as a newbie to the site.
In 2002 I had my triumph GT6 sprayed BRG. The braked fluid reservoir has leaked while in storage requiring a local repair.
I do not have a paint code how can I track down the correct code and colour?
I have some thumb sized paint flakes that have peeled off as a result of the oil.
I purchased touch up Rover 1993 Brooklands BRG, it's a very close match , but I need to be sure.
Any assistance would be gratefully received.
Mickey Richaud
Since it's a respray, and apparently not an "original" GT6 color, your best bet may be to take the car to a paint supplier and have them do a computer paint match.
And welcome to the BCF! We've a very active contingent of TR folks, so hop over to that forum and post away. Don't forget pictures!
:cheers:
Mickey
G
Gnasha
Mickey thank you for the response. Unfortunately the car needs some work first eg replacing the brake and clutch master cylinders where the damage has taken place. So I'm stuck at the moment between a rock and a hard place, may have to go with Brooklands green:shocked:
LarryK
Anytime you have a classic resprayed make sure you get the numbers of the paint from the shop, makes things easier later.
JPSmit
A shop doesn't need much car to make a match. A bonnet or boot hinge or even take off the boot or a valance and bring it in, paint isn't cheap and even "almost" will be obvious
TR3driver
Great Pumpkin - R.I.P
But note that paint colors fade over time. Even if you had the original code, fresh paint with that code would not be a perfect match for 13 year old paint. There is also the problem that paint systems are evolving and the original type may not be available today. A computer match will get closer.
Might also be a time to consider converting to DOT 5 Silicone brake fluid. In my experience, it makes the seals last far longer than they do with DOT 4; and it will not damage paint even if it does leak. There are some downsides as well (and I'm not trying to reopen the brake fluid wars), but I've been using it for some 30 years now and I love it.
Just occurred to me, I'm still using the same brake calipers that I rebuilt back in 1985 or so when I switched to DOT 5 in the TR3A, they've never needed attention again. (Except for new pads, obviously.) And the bleed screws opened easily when I moved them to the current TR3, which never would have happened with DOT 4.
Here's some further information on pros & cons with DOT 5
https://www.buckeyetriumphs.org/technical/Brakes/Fluid/Fluid.htm
Not mentioned is the fact that some brake part suppliers (eg White Post) specifically say not to use DOT 5 with their components. I suspect this is more of a marketing and liability/insurance issue than a practical one; but make your own decision.
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
B TR6 Help with color and color code / paint recommendation Triumph 4
J Opalescent Silver Blue paint code Jaguar 0
J Paint code Spridgets 0
J Paint code Austin Healey 4
M Old English White Paint Code for early BE Spridgets 1
vette MGB Paint Code MG 8
M Modern Paint Code Needed for Honolulu Blue Restoration & Tools 1
71TR6 TR2/3/3A Modern paint code for 1959 Triumph #19 Pearl White Triumph 20
Tr3aguy TR2/3/3A Paint code info Triumph 14
S TR4/4A TR4A BRG #75 paint code Ditzler 42487 Triumph 3
Scotsman TR4/4A Triumph Royal Blue paint code and formula Triumph 3
S TR4/4A BRG Paint code [again] Triumph 13
J Pacific Blue paint code needed Jaguar 6
Got_All_4 TR2/3/3A Paint code / formula coming to a head Triumph 28
Got_All_4 TR2/3/3A Paint code plate Triumph 9
wangdango OEW paint code Austin Healey 3
K MGA BMC paint colour code AL1 MG 2
K BMC paint colour code AL1 [wire wheels] Austin Healey 1
K Original "old" 1960'es Dunlop wire wheel paint code Austin Healey 7
K Original 1960'es Dunlop wire wheel paint code Jaguar 7
K 1960'es Dunlop wire wheel paint colour code Restoration & Tools 0
MY66AH Need the PPG paint code..... Spridgets 6
RJS TR4/4A 1975 Triumph British Racing Green Paint Code Triumph 4
AH67 Paint code spoke wheels? Austin Healey 8
B Paint code? Spridgets 5
T Florida Green paint code Austin Healey 6
wangdango Dark BRG paint code Austin Healey 11
H Paint code Triumph 6
jsfbond paint code site Restoration & Tools 0
bighealeysource Paint Code for RENO RED Austin Healey 11
B British Racing Green PPG Paint Code Restoration & Tools 4
af3683 TR2/3/3A Paint Code for Silver TR-3 Wire Wheels Triumph 8
S Signal Red paint code Triumph 10
bgbassplyr PAINT CODE QUESTION.... Triumph 1
M Lobelia Blue paint code Austin Healey 3
M Healey Blue paint code Austin Healey 1
bighealeysource Healey blue paint code Austin Healey 10
N Paint code or number for silver wheels Triumph 14
Got_All_4 PPG Paint tinting code for signal red Triumph 5
JPSmit Paint Code Question - OEW Austin Healey 5
JeffS looking for PPG engine green paint code.... HELP! Austin Healey 9
N Other numbers for paint code 82? Triumph 2
MTribe modern paint code for Signal Red? Triumph 5
kodanja paint code chart! Triumph 1
B Paint Code Triumph 10
tr7andtvr PAINT CODE? TVR 1
G Standard Vanguard Paint Code Other British Cars 4
I TR6 TR6 paint code for damson Triumph 10
W Morris Green Engine Paint Code Spridgets 4
