Signal Red paint code
Scott McK
Hello all and Happy New Year. Does anyone have the PPG or Ditzler Code for the Signale Red paint color? Just about ready to to order paint for the 61' TR4.
Thanks
Don_R
Scott,
From Bob Schaller's More BS on TRs, he lists the Ditzler code as 70966 for signal red 62-65 & prior.
you can get the manual from Randall's (TR3Driver) download site.
S
Scott McK
Thanks for the info. What do you guys think of the idea of spraying the bottom of the bodytub and the inner fenders with a sray on type truckbed liner product. My goal is not originality, just rust prevention for the long haul. Any thoughts here? Any downside to the product and results?
GilsTR
Scott....even if you are not going the original route...I would
give your idea a second thought. Going thru any sort of a restoration
involves considerable cash investment. I can't believe you will
be doing justice to your investment spraying a bed liner anywhere
on the car. Going to bare metal...a good primer followed be a good
paint job should give you all the metal protection you will need.
But again...it is your car...and your $$. Good luck. Gil
Tr3aguy
When I called my friend who paints cars for money, he mentioned a product called rock chip guard.....it is a flex additive that is supposed to keep the paint softer(so to speak) so it fills in if you get a chip.
I haven't put it to the test yet, but I am going to heed his advise when I paint my car.......
Andrew Mace
I suspect that's sound advice! From my experience over the years, any type of "undercoat" can be as much a bad thing as a good thing. Time was, lots of cars got an "undercoat" of some sort of bitumenous material (kinda like roofing tar). That was fine...for awhile. However, it eventually dried out and would start to lose adhesion. Unfortunately, it often didn't completely peel off, and all sorts of mud, grime and moisture could then get trapped under what was left, and that would eventually wreak havoc. I've also seen far too many carelessly "rustproofed" cars (Rusty Jones, Ziebart, even Volvo factory undercoat) that did much the same thing and/or was carelessly enough applied that drain holes got blocked; eventually, the same problems occurred with rust starting underneath the undercoat, etc. I've seen comparable cars where a "non-rustproofed" car actually held up much better than one that was "rustproofed"!
jsfbond
Clean the surface and brush or roll Sem on to it. This is made to go dirrect to metal with a rust inhibitor built in. cost effective and easy to use, and it comes in the many colors on this chip chart I'm holding up...see.
angelfj1
I wouldn't use a truck bed liner product for rust prevention. If you ever have to get it off you will regret using it!
You might consider a product like waxoyl
https://www.minimania.com/InvDetail.cfm?item=WAXOYL%20%20%20%20%20%20%20%20%20&googlebase
S
Scott McK
Thanks all for the input. Based on the above I will most likely prime and paint the bodytub signal red and go from there. I will try to post some pics but not sure how.
Got_All_4 PPG Paint tinting code for signal red Triumph 5
MTribe modern paint code for Signal Red? Triumph 5
B New Colorado Red/Signal Red Thread - Trying to get it right Austin Healey 0
V Triumph Signal Red Triumph 32
6 signal red chip Triumph 9
R Directional Signal Failure Austin Healey 12
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
6 Turn Signal Flasher Spridgets 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
B General MG Turn Signal Issue MG 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
M Europa turn signal problem Lotus 7
R Spitfire Turn signal wiring Spitfire Triumph 5
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
M TR6 Turn signal switch stalk Triumph 1
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
R For Sale Misc. TR-4 signal and flasher parts Triumph Classifieds 0
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
B Turn Signal Indicator Light Always Flashing Austin Healey 10
F TR6 Trun Signal Switch for 76 TR6 Triumph 7
JPSmit Question - wiper switch and signal switch ends Spridgets 4
R TR2/3/3A The Turn Signal Challenge Triumph 2
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
S Turn signal nightmare ! Spridgets 4
S Turn signal nightmare ! Austin Healey 4
N Turn signal flasher?? Spridgets 8
J BJ8 Turn signal help needed. Austin Healey 6
PAUL161 T-Series Turn Signal Flasher MG 8
glemon General Tech Turn Signal Issue Triumph 12
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
R Turn signal switch [trafficator] Austin Healey 1
R TR2/3/3A Turn signal wiring Triumph 1
S Bizarre turn signal issue Austin Healey 10
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
bighealeysource Turn signal issues Austin Healey 6
