TR6 Overdrive Wiring Questions
Gerry M
Member
I have a 1974 TR6 with overdrive. The wiring in photo together with vertically positioned solenoid (with one wire) suggests to me that it is an A-type OD. OD does not engage (tranny fluid has been topped up). What each of these terminal control? Is this OD wired correctly? With ignition turned on (car not running), shifter in 4th gear, and OD switch turned on, nothing happens. I am getting current at the Green wire terminals shown in photo but nowhere else. Its not shown in the photo but the Yellow wire is connected to a Red wire coming out of the OD switch and there is a purple wire coming out of the solenoid that connects to a Green/Brown wire that then connects to a Red wire coming out of the OD switch (so the OD switch connects to the solenoid and to the Yellow terminal neither show any current). I've been trying to figure this out for a while now. I would really like to get this OD working. What should I do?
PS: I don't know if this helps or just further complicates the problem. The Advance Auto Wire diagram for 74 TR6 does not show any OD relay and my car does not have one (just starter & horn relays). Isn't it the J-type OD that has no relay? Other than no relay everything else suggests that mine is an A-type OD?
TR3driver
Great Pumpkin - R.I.P
Ok, the wiring seems a bit creative. You certainly might have an A-type, though I'm guessing it's not original to the car since 73 and later had J-types.
For an A-type, two of the switches should be wired in parallel. In your photo, those would be the two nearest the bottom of the photo. One of them is only closed when the gearbox is in 2nd gear; the other is only closed in 3rd or 4th. The switch near the top of your photo would be for the reverse lights (and only closed when the gearbox is in reverse).
Looks like the switch on the right is broken and will need to be replaced. They should all have two terminals (and the switch does not ground through the gearbox).
Here's a shot of the typical A-type wiring, from Dan's 70-71 diagram
(I believe some cars have the operating switch on the other side of the relay coil, but it doesn't really matter, the result is the same.)
The A-type solenoid draws a big chunk of current (like 20+ amps) every time it gets engaged, so it is probably best to stick with the factory wiring scheme (with a relay). I also found that my relay lasted much longer if I added a suppression diode across the solenoid (but no need to worry about that just now).
A photo of the OD would help verify that it is an A-type; but AFAIK all J-types have the solenoid mounted horizontal so you are probably correct about it being an A-type.
Gerry M
Gerry M
Member
Have I got these switches labeled correctly(see photo)? How can I test to know if the switches are working?
trrdster2000
Gerry, these switches are really a safety switch to keep you from putting the car in reverse while the overdrive is engaged. Every time you change gears it cut the overdrive off. Get the proper wiring harness and a relay, you will be much better off.
If you have a "A" type , there is a arm on the opposite side of the solenoid that can be pushed forward to check the work or don't work part of the overdrive. This works the valve in the system. Get a passenger to do it with a pair of vise grips attached, it only needs to go forward enough for the hole in the case and the hole in the arm are equal.. Try it in third gear and if it clicks in you will feel it, and it must be held in place by a 1/8 inch drill to keep working, but I wouldn't do that. A very expensive add on, so do it right.
Wayne
TR3driver
Yes, the labels look right to me.
One way to test would be to pull the wires off and connect an ohmmeter (DMM on ohms scale), or powered test lamp across the terminals of each switch in turn. You should get no continuity in neutral, or any gear other than the one that switch is supposed to detect. IOW, the 3/4 switch should be closed only with the gearbox in 3rd or 4th; the 2nd gear switch closed only in 2nd gear.
Gerry M
Gerry M
Member
Thanks for the wiring diagram. I had the tranny out and it is now back in the car and I rewired it according to this diagram which makes sense when I look at the diagram but for some reason the solenoid is always energized with o/d switch turned on meaning that the overdrive will engage in reverse if I am not careful. This of course this would be catastrophic. Why does the o/d engage in reverse? How do I correct this ?
PS: the reverse switch on tranny does not share any wires with the 2 and 3/4 switches.
TR3driver
One of the switches must be making contact when the appropriate gear is not selected. Sometimes they need to be shimmed. These instructions specify 2nd gear, but the same process applies to the 3-4 switch
Gerry M
Gerry M
Member
Not sure it’s the switch shimming but I will check that. I have wired according to drawing. With power on at the ignition switch I can activate the solenoid in all gears including neutral by turning on the overdrive column switch.
Gerry M
Gerry M
Member
Here is the wiring diagram I have been working with. Looks the same as yours except mine shows a grounded solenoid. I don’t have a ground wire running from the solenoid. I figured it was self grounding. Could a grounded solenoid (not shown in your diagram) be the cause of my problem (i.e. two separate powered and grounded cuircuits - one for gearbox switches and one for solenoid)?
What would happen if I did this:
1. Disconnect solenoid from C2 terminal
2. Connect C2 to ground
3. Disconnect gearbox switches from ground
4. Connect single solenoid wire to gearbox switches
Im not good at electrical stuff but wouldnt that hookup ensure that the only way power gets the solenoid is through the 2/3/4 gears?
TR3driver
The solenoid grounds through it's mount. IMO there is no solenoid ground wire intended in the diagram I posted. It was just drawn a little strange. It does show the bottom of the solenoid grounded; it's just grounded to the same point (in the diagram) as the lockout switches. Think of it as an electrical circuit, rather than a physical wire. (Really, the whole "ground" concept on a car is just using the body of various components as one of the electrical conductors.)
Rather than trying to re-engineer the circuit without the relay (it is there for a reason), I suggest disconnecting each lockout switch in turn and retesting. If the solenoid still pulls in with both switches disconnected (and the wires left open), then there is a wiring error somewhere and you need to troubleshoot the wiring to the relay.
But most likely, IMO, you will find that disconnecting one switch will cause the solenoid to no longer activate with the column lever and the gearshift in neutral or reverse. That switch is staying closed when it should not be closed (associated gear/gears not selected). Unscrew the switch and, if it is still closed, it is defective. But again, most likely IMO, it will now be open, indicating that without a shim, it was sitting too close to the shift fork inside the gearbox top cover.
TR3driver
PS, the "pull-in coil" shown inside the solenoid draws a lot of current, something like 20 amps. The relay is there because the switches won't handle that much current (plus the inductive kickback) for long. It would probably work at first, but not for long.
In fact, my experience has been that even new relays "don't like" the inductive kickback, and I had several of them (including a fairly expensive reproduction from Moss) fail within just a few months to a year of daily driving. Adding a solid state diode to help absorb the kickback from the solenoid has made the relay (even my cheap "Made in China" brand one) last much much longer.
ckeithjordan TR2/3/3A Overdrive Wiring Triumph 5
R TR2/3/3A Overdrive wiring installation Triumph 14
S TR2/3/3A Triumph tr3 overdrive wiring Triumph 9
C TR6 TR6 Overdrive Wiring. Triumph 2
S Overdrive Wiring Check Austin Healey 12
Got_All_4 TR2/3/3A Quick Overdrive Wiring Question Triumph 6
BillyB62 TR2/3/3A Type A TR3 Overdrive Wiring Triumph 13
M Stag Wiring plugs for gear lever knob overdrive switch. Triumph 1
Gerry M TR6 Overdrive Wiring Triumph 5
T TR4/4A Any tips on running the overdrive switch wiring down the steering column? Triumph 11
R TR2/3/3A TR3A Overdrive Wiring Harness Installation Triumph 19
Coyote1 Overdrive wiring question Triumph 8
hondo402000 TR6 Need Help on 71 TR6 Overdrive Wiring Triumph 9
KLUTZ Confused with my Overdrive wiring.. Help please MG 3
R BJ-7 overdrive relay wiring problem Austin Healey 1
A Overdrive wiring Triumph 8
S Overdrive Wiring Austin Healey 2
Mickey Richaud Transmission/Overdrive Wiring MG 3
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
