TR2/3/3A Overdrive drain plugs leaks
sp53
Overdrive drain plugs leaks. I used a gasket I cut out of leather, but that seems to wick out fluid. I remember John used an O ring but what type. Do I want an oil ring that has a flat top and square shoulders or do I want a round one? Do I want the oil ring on the thick side? About how thick and how tight is too tight? Stop a quarter turn before it breaks or very snug.
steve
titanic
Steve-I think most people just use 2 of the fiber type gaskets to cure leaks. I went to the Portland swap meet this morning. I got contact info for 2 people that have TR3 radiators. PM me with your email address if you are interested.
Berry
Graham H
Is the oil leaking from the drain plug or running down from above, leaking from the selector shafts is the usual suspect?
Graham
S
sp53
Yeh I made that hillbilly seal out of leather and it wicked out fluid, so I loosen it and retightened it then it stopped. However, I think you are correct Graham the leak is also coming from somewhere on that back section.
steve
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
M TR2/3/3A TR3 Overdrive filter drain plug Triumph 7
C TR2/3/3A A-type overdrive drain plug oring Triumph 1
C BN1 Overdrive drain plug question Austin Healey 0
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
T TR2/3/3A Overdrive drain magnets Triumph 10
M Overdrive drain plug Triumph 17
A Overdrive drain magnet-above or below screen? Austin Healey 10
Dave Richards Overdrive Drain Plug Gasket? Austin Healey 2
H Where is the Overdrive Oil Drain Plug and Filter? Austin Healey 2
WALTER overdrive drain plug Austin Healey 20
RickPA Overdrive Oil Pressure Austin Healey 8
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
J Transmission and Overdrive Rebuild Austin Healey 6
C Overdrive Failure Austin Healey 18
