Orange peel question
regularman
OK, I am getting down to the nitty gritty. I got a few places that I would like to polish out on the clear coat. I wet sanded the clear coat on the fender that had bad orange peel and it is smooth now, and I bought a new high speed polisher from harbor freight. It came with a soft wool pad. What type of polish or whatever should I use with this? I am stopping by wal-mart later today to get a new battery and I can pick something up if they have what I need.
IMO, Throw away the cheap wool pad. Get a foam pad with a "one step" cut and polish compound. These newer compounds start course and break down as they are used. They are also easier to clean up than traditional compounds.
If that wool pad is held on with elastic, then definitely toss it in the bin.
zimmy
im happy with the Mcquires 3 step carnuba system...
made my old paint look new for a few days or so,
hence the nice shiny pic i used to have as my avatar....
good stuff ....zimmmmy
jlaird
Kim, go to an auto paint store and get the right pad and buffing compound. You will be very pleased with the results.
dklawson
I've heard good things about the McGuire's system but I haven't used it. I have used various products from 3M with good results. I have used their multi-component "Perfect-It" system and where I've wanted a single step polish I've had good luck with "Finesse-It".
I have had good initial polishing results with lamb's wool bonnets but as others said above, when you're down to the final buffing, the foam pads give excellent results.
I'd be careful with the HF polisher. If it's not orbital, I wouldn't consider using it as you're likely to create swirl marks.
bugimike
I agree with Doug, "Finesse-it" is a good product...does a great job on most everything I have used it on!
bighealeysource How to color sand really bad orange peel Restoration & Tools 6
T TR2/3/3A Orange Peel Triumph 6
bighealeysource advice on orange peel in base coat paint issue Austin Healey 21
TR4 Orange Peel Removal ??? Triumph 17
B '65 Midget [Orange Crate] is for sale again Spridgets 5
A Ok, so what is this orange hose? Spridgets 16
DrEntropy Pumpkin orange! Spotted 12
B Anyone need an "Orange Crate"? Spridgets 19
Dave Richards 78 Orange B on E-Bay [Oct 2011] MG 2
UmmYeahOk GT6 Clear or Orange Lens - GT6 Question Triumph 9
X burnt orange exige s 260 sport spotted in Brooklyn Lotus 2
Gray_Cat MG Midget Orange County CA Spridgets 1
ncbugeye Orange RB Midget seen in Raleigh today Spridgets 2
E Topaz Orange 6? Any one seen one? Triumph 17
S Colorado Orange!!! Austin Healey 6
T How to dye your hands orange in one easy step... Triumph 9
W 948cc orange engines Spridgets 6
RickAnderson Mini Swapmeet 10/23/05 Orange California British Motor Corp 2
L Orange air filter covers? MG 1
Bruce Bowker Orange???? Spridgets 15
A Orange spray detailing stuff Restoration & Tools 0
C Peel Coachworks Other British Cars 9
tony barnhill Peel Trident Micro car Other British Cars 4
Sherlock Peel Trident on Monster Garage... Other British Cars 2
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
