Bruno_69z28
I have a TR-4 motor that was just rebuilt. When the moter was cleaned the aluminum oil galley plugs were removed. I had new ones made with 3/4" aluminum stock threaded to 3/4-16 threads to match the block. I used Permatex high temp thread sealant to seal the threads.
I now have leaks in the front and back of the motor out of these areas.
I know I have to remove the motor and replace the plugs, but what type of sealant should I use. These are not taperd threads.
thanks for your time
