Oil again
Just read the label on the "high mileage" (green container) Castlol container. I seemed to me the only difference was that it was better for the catalytic system. I found no other apparent other differences. I've always used 20w-50 in the white container. Am I missing something?
Nelson Oil leaks again Spridgets 1
tahoe healey Castrol oil again Austin Healey 37
T TR4/4A Coolant in the oil - again. Triumph 18
K TR2/3/3A Oil pan Again.... Triumph 4
K TR2/3/3A Trunnion oil/grease again? Triumph 1
M Leaky oil pan... again Triumph 16
K SU Oil Dampers...Again Triumph 16
CraigLandrum TR2/3/3A TR3 Low oil pressure [again!] Triumph 23
Sopwith_Camel losing oil presser again Spridgets 8
2wrench Oil Filter.....again. Triumph 26
M Oil Leaks Again Austin Healey 7
Bruce_B Oil Pump Cover Clerance again Spridgets 3
Got_All_4 ADD ON OIL FILTER LEAKING AGAIN! Triumph 12
Lin Oil Pump again Austin Healey 3
tahoe healey oil filter again Austin Healey 14
G Oil pressure question again? MG 22
Mickey Richaud TR2/3/3A TR3 Rear End Oil [Again] Triumph 5
Webb Sledge Leakin' Oil... Again Triumph 9
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
R TR6 question re: Engine Oil Triumph 3
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
