TR6 Non-modified TR6
Number_6
That's a nice one, and it looks like factory PI. The buy it now price for a TR6-PI of $23,750 looks like a pretty good price.
kodanja
Is that an orginal overrider on the front bumper?
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
Fanch00 Non-Overdrive Benefits? Austin Healey 10
Celtic 77 MGB Non working tach. MG 4
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
J TR2/3/3A Adjustable vs non Adjustable wheel Triumph 0
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
AUSMHLY SU Damper Cap Vented vs Non-Vented Austin Healey 25
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
C Non-Adjustable steering column questions Austin Healey 14
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Synchro in a non synchro? Triumph 19
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
maxwedge5281 Trafficators, Adjustable vs. Non-Adjustable Austin Healey 14
Jim_Gruber Non LBC but saw my first Civic Type R Yesterday Spridgets 24
Zitch TR4/4A OD Addition to a Non Over-Drive Transmission - my attempt Triumph 11
Rut Interesting non Spridget Spridgets 3
NutmegCT The non-garage garage Restoration & Tools 22
Marla TR4/4A Ballast or Non... Triumph 6
R TR2/3/3A Non Triumph cooling question Triumph 8
B Posting non you tube video? FORUM Navigation Questions 3
Jim_Gruber Saw my first NSX in the flesh - non lbc Spridgets 2
Jim_Gruber Saw my first NSX in the flesh - non lbc Spridgets 0
C TR6 Non-start diagnosis Triumph 9
GTP1960 TR2/3/3A Resistor plugs vs. non-resistor plugs? Triumph 6
nevets interesting piece in the NYT about collector car non-restoration Austin Healey 5
vette Detergent/Non-detergent Austin Healey 19
AUSMHLY Best 7" non sealed headlamp Austin Healey 19
Jer an Latest from a fellow LBC guy - new non LBC purchase to share Spridgets 11
CJD TR2/3/3A Adjustable vs Non-adjustable Control Heads Triumph 4
P I need a non-working electric tachometer for parts Spridgets 0
2wrench TR6 1974 TR6: Ballast vs Non-ballast system. A look at the wiring. Triumph 58
vette Detergent or Non-Detergent, Trans/ OD Austin Healey 7
Boggsy64 MGB Starter - Non starter? MG 16
K TR2/3/3A Trunnion spindle cotter pin hole non existent! Triumph 9
Zitch TR4/4A Non OD rear transmission seal replacement Triumph 1
S WTB: Non-Adjustable Horn Button for a 3000 Austin Healey 6
H horn button for BN6 "non-adjustable" Austin Healey 4
Geo Hahn Lowering Passenger Side Ride Height on non-IRS TR Triumph 4
johnrip Wedge TR7 non-idle Triumph 4
