no spark
eyera3
hello all,
I last drove my 1960 3000 MKI two weeks ago, I had to turn the car around so I pulled out of my garage and drove it back in front first. Last week I started it to check out some improvements to my custom throttle cable. This weekend was the big day to take the car on a test drive and then nothing.... No spark to the plugs, across the points or out of the coil. I bought a new coil, nothing. I have continuity from the white with black stripe wire to the pos termonal of the battery at the cut off switch. I have 12v at the pos coil terminal. New Lucas points and condensor, new cap and rotor, all NOS.
Any way to test the condensor? I have one NOS condensor left, so I could just repkace it and see, but would like to know how to test it?
Thanks
Ira
1960 AH 3000 MKI
Keith_M
Check the battery cutoff switch (or the wire leading to it) in the trunk.
Keoke
There are two methods:
1: Using an OHM Meter set to a high OHMs scale connect it between the case and the lead the meter should jump and then fall to Zero . Reverse the leads and it should repeat the stated action..
2: Connect the condenser across a 12volt source, then short the lead to the case it will generate a spark.
Generally if these conditions are met it is OK. Excessive operating heat can cause it to fail however.
Healey Nut
You have a bad battery switch , disconnect the small white wire with black stripe from the switch or the side of the dizzy and try again .
glemon
When I am stumped and the intuitive fixes that come into my head don't work (basically when all else fails and I am totally stumped) I go here:
https://herald-tips-tricks.wdfiles....art0/Lucas Fault Diagnosis Service Manual.pdf Electrical stuff explained in a pretty simple way so even I can usually understand it, and good step by step diagnostics.
(Edit) BTW--my money is on the battery cut off switch too, mine would kill my car like that with no warning, sometimes when out and about, disabling and bypassing it made my Healey ownership happier.
pkmh
I had a similar problem where I had little spark, no spark and then a lot of spark. Yes, I too, replaced the condenser, points, rotor ignition coil wire, disconnect (and yes that setscrew is a bad design--it will severe your black and white wire every time you "lightly" over tighten it), clipped all other end wires to the distributor and then checked the carbs for fuel flow.
Hopefully, you can still inspect your old ignition wire (using the radio reduction type) going to the distributor cap. Mine was burnt. What I did next was inspect the distributor cap's center node, that carbon spring piece. Pulled it out more so more contact was made onto the rotor. Bingo! Strong and continuous spark, car started right up. Now waiting for a new cap to come. Evidence of that problem was seeing how burnt the wire was going that carbon spring piece. Hopefully, this will fix your issue if your still have one, notwithstanding other issues.
Paul
PS. One other possibility that also happened to me was one of the ignition coil leads was severed, not visible from view. So you may want to check all your electrical connections. Hope all works out.
trglory TR2/3/3A TR3a spark plugs Triumph 1
CARSINC Spark plug thread size Spridgets 2
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
L T-Series Spark plugs again ? MG 2
B TR6 Gas on spark plugs Triumph 7
Carlbanan56 MGB No spark and engine cranking slow MG 10
kodpkd Spark Plugs Austin Healey 3
P TR2/3/3A NO spark at points Triumph 36
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
B Healey Won't Start - No Spark Austin Healey 38
L TR4/4A spark plugs Triumph 9
BierRunner TR6 Life without Spark :( Triumph 25
J TR2/3/3A No spark in TR3 Triumph 20
G TR4/4A TR4 Lacks Spark! Triumph 22
M For Sale NOS Champon NA-10 Spark Plugs Jaguar Classifieds 2
tr6web TR6 No spark 1972 TR6 Triumph 35
PAUL161 T-Series Odd spark plug encounter! MG 10
MadRiver No Spark Austin Healey 18
K TR2/3/3A Testing spark plug wires..... Triumph 11
Gliderman8 TR6 Spark plugs for TR6 Triumph 7
B Anyone have spark advance data for Piper camshafts? Spridgets 1
B TR4/4A Spark plugs Triumph 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
S Spark Plugs Spridgets 2
AUSMHLY BJ8 NGK Spark Plugs Austin Healey 13
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
AUSMHLY When to replace spark plugs Austin Healey 1
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
K TR2/3/3A Spark Plug Gap? Triumph 4
FlyingCat Spitfire Spark to Coil Triumph 23
K Numbered Spark Plug Boots? Austin Healey 27
tahoe healey Spark Plugs Austin Healey 20
Got_All_4 General TR Anybody Hear or Use This Hot Spark System? Triumph 10
mgedit TR2/3/3A Lost Spark Triumph 26
jfarris TR2/3/3A Which spark lug to use - copper/platinum/iridium Triumph 14
S No spark, im in the dark. Spridgets 6
G spark plugs Austin Healey 10
B Spark Plug Wire Caps Austin Healey 16
Sopwith_Camel MGB the mysterious disapearing spark MG 21
S Wedge Need help with TR8 no spark Triumph 7
vickxxx T-Series 1952 MGTD spark plugs. MG 4
S MGA 1956 MGA negative ground, True Spark Ignition distributor MG 3
B TR6 Spark plug gap Triumph 5
toysrrus TR6 Spark plug question Triumph 23
K TR2/3/3A Spark Plug cuts and diagnosing? Triumph 13
