MGB MOSS's EFI kit for ZS MGBs
Bret
Hey Gang,
Well I just got the winter British Motoring, was happy to see that MOSS has been diligently working on their EFI Kit for the 75-80 MGBs. According to the article the kit is intended as a direct replacement for MGBs currently running the much-hated Zenith Stromberg setup and is scheduled for release this spring.
When I first caught wind of the EFI kit, one of my biggest concerns – was if it would meet the strict California emissions standards. Well it turns out their prototype has already been certified. While they did see some HP improvements with the EFI. It wasn’t really intended as a performance upgrade so much as a means of improving reliability and day-to-day drivability.
The only real issue I see is if the current owner (or the previous owner) had already removed the old ZS setup for something else like say a Webber or a Dual SU setup. But this shouldn’t be such a big concern because chances are if you’ve gone this route you’re not concerned about emissions testing in your area and are better off sticking with what you have.
Price? MOSS is saying it should be about $1400.
Thoughts?
G
efi is a great idea, but for 1400 I could probably work out something with a Holley unit. I've heard one of the GM throttle bodies will bolt on but haven't really pursued it as I'm gonna go with the v6 and til then the weber suits me fine
Mark Beiser
I'm interested in what ECU they will be using. Hopefully it will be fully user mapable and also handle ignition.
If its mapable, you could greatly increase low and mid range torque with the right cham and fuel/ignition mapping.
The combo intake/exhause manifold would limit the top end, but the car could be made VERY much more fun driving around town.
$1400 sounds very reasonable assuming they are going to supply a premade wiring loom and all the needed sensors.
What would make it VERY interesting is if they could include a 3 way catalytic converter so you can delete the EGR valve and smog pump and still be ok for emissions in CA....
I also wonder if they have tried EFI with thier supercharger. =)
One of my goals in life is to build a chrome bumper MGB up that looks almost completely stock from the outside and the interior, but is powered by a supercharged, fuel injected B series engine with a cross flow head.
Bret Moss EFI kit and O/D tranny Latest thus far... MG 8
Bret Speaking of the Moss EFI kit MG 2
Bret Moss EFI kit & other good news! MG 14
Bret MGB Moss Motors EFI for the MGB! MG 3
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
shadowfever Moss Motors MG Midget seat covers Spridgets 6
Celtic 77 MOSS response issues Restoration & Tools 11
BoyRacer Moss Motors Center Consoles Austin Healey 0
T TR2/3/3A Moss uprated water pump Triumph 6
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
vette Latest Moss Motors Magazine Austin Healey 1
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
Basil MGB Moss Motors MGB - Jay Leno's Garage MG 3
K TR2/3/3A Moss Improved performance camshaft 851-051...... Triumph 0
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
3798j General TR Moss Motors acquires Victoria British Triumph 10
J TR6 Moss HS6 SU conversion kit question Triumph 4
steveg TR6 Moss advance kit maximum advance question Triumph 13
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
Upland Moss build-a-paper car contest Spridgets 1
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
JPSmit Stirling Moss - Sebring Sprite Spridgets 3
KVH TR4/4A Door Seals: Moss Part 249-607 Triumph 0
Simmo TR6 Moss Seats Triumph 0
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
E Moss stainless exhaust offering. Austin Healey 28
R TR2/3/3A New Control head wiring - Moss purchase Triumph 1
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
K TR2/3/3A Moss Europe has restored the Jabbeke TR2 Triumph 0
Jim_Stevens For Sale Pair of chrome tail lamp bases, NIB, Moss 159300 Triumph Classifieds 0
LarryK Moss Motors buys XKs Unlimited parts house. Jaguar 6
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
K TR2/3/3A The "compensator bar" on the Handbrake...#53 in Moss diagram Triumph 5
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
L 100/ Moss Heat Shield Austin Healey 2
mt10flyer TR2/3/3A Moss Steering Rack Conversion Triumph 26
Jim_Stevens TR2/3/3A Goodridge SS brakelines from Moss Triumph 3
R Moss permanently lubricated U-Joints Austin Healey 1
S For Sale TR6 New Moss 73-76 Seat Foam Kit Triumph Classifieds 0
M TR2/3/3A Fitting on Moss Brake/Clutch Masters Triumph 16
D TR2/3/3A Moss alternator kit Triumph 8
