MGB Moss MGB gearbox gasket - ugh!
Vespa
So. I was putting together an MGB gearbox today ('73). Pulled out the gasket set from Moss to do a dry fit check, and NONE of them fit. Correct kit, and correct gaskets, but made so poorly that they are impossible to fit! I am SOOOOOOOOOO tired of poorly made parts. Vent over.
- Paul B,
Did you try soaking them? Works some times. I make most of my own gaskets anymore out of quality gasket material. PJ
It does get frustrating, for sure.
One thing (which you may have already done) is to let Moss know that the part doesn't fit properly. Despite our frustrations, they do take these things seriously and want to know when there are issues.
- Paul B,
Paul
If you wouldn't mind. Could you drop me an e-mail with the invoice and date these were purchased. We build the kit in house from individual gaskets and I'll test fit them all if in fact they were purchased from Moss recently. The only reason I'm asking this is that there have been a rash of problems with parts purported to be from Moss, but upon investigation they were supplied by other sources.
thanks
I can be reached at: doddk@mossmotors.com
Kelvin Dodd
Moss Motors
Now that's more than personal service!! Moss rules!!
Hi Paul, that’s the saddest part of getting thorough with your car and spurious spares play spoil sport. Many times instances like these happen even when you get stuff brand new and out of the box; but when it aint gonna fit, it just aint! Let me suggest you post to your requirements at [Deleted]
One thing for sure, Kelvin will work on rectifying the problem, he's done it before. But, If you've worked on this type of stuff before and I'm assuming you have, why not just get some gasket material and make your own? Better than tying up a job waiting on a gasket. PJ
I am building three LH O/D gearboxes and just ran into the same problem. The rear extension gasket appears to have shrunk. When placed over the three studs , the bottom holes are 'half moons'. Fortunately I still have some factory original 22B404 gaskets in stock. Also be sure to check the gasket thickness. Factory was a 'compressed' .012" I've found replacements anywhere from .008-.025. This requires a readjustment of the front cover shims which you should do anyway since about half of the gearboxes have wadded up their .002 shim. I have sent an image to Moss to let them know.
Alan T
I am new to the site today. Hoping to get some insight into a tranny problem. I bought a kind of rough but running 78 mgb. I was told it had a moss 5 speed tranny and when I drove it home it shifted well and it seemed fine. Please don't laugh too hard but I never had to put it into reverse before buying it and you guessed it, I can't find reverse now after bringing it home. The seller of course acted as though he thought it was o.k. and was not the type to be very helpful or make it right. I have tried about every position with the stick to find reverse even pulling up or pushing down while trying all of the normal locations for reverse and can"t find it. The car was probably sitting for a while, but all foreward 5 gears work very well. I am not a great mechanic and it probably sounds like wishful thinking, but I am hopeful reverse is there and I am just not doing something right. Would appreciate any help. thanks, Wayne
Take the gearshift lever and smack it to the left, it's spring loaded, hold it there and pull back. If the transmission has overdrive, make sure it's not in the OD position. You can damage the OD unit if it's in, in reverse. Overdrive is the 5th gear. If it doesn't have OD, it's a 4 speed. (Assuming it's an MGB transmission). PJ
Wayne -- you will probably find that you'll get better response if you ask your questions as a new thread ("Post New Thread" at the top left of the window).
That said, the Moss 5-speed conversion is a T9 transmission, I believe reverse is up and to the left (next to 1st gear).
My T-9 5-speed from Quantum - reverse is pull left in neutral, push down on knob, then up where 1st gear would be.
Sorry but, a Moss 5 speed in a 78 B? I assumed that not knowing much about MGBs, you had an MGB with overdrive, which IS a 5th gear. Strange when you could buy 4 MGB OD transmissions for the price of one Moss 5 speed. And, there's nothing wrong with a stock B transmission with OD, their almost bullet proof! PJ
Basil MGB Moss Motors MGB - Jay Leno's Garage MG 3
W MGB MGB- Cant find reverse on my Moss 5 Speed MG 2
PAUL161 MGB Moss major suspension kit MGB MG 3
Bret MGB Moss Motors EFI for the MGB! MG 3
CJ Burton MGB Moss has a sense of humor MG 0
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
shadowfever Moss Motors MG Midget seat covers Spridgets 6
Celtic 77 MOSS response issues Restoration & Tools 11
BoyRacer Moss Motors Center Consoles Austin Healey 0
T TR2/3/3A Moss uprated water pump Triumph 6
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
vette Latest Moss Motors Magazine Austin Healey 1
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
K TR2/3/3A Moss Improved performance camshaft 851-051...... Triumph 0
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
3798j General TR Moss Motors acquires Victoria British Triumph 10
J TR6 Moss HS6 SU conversion kit question Triumph 4
steveg TR6 Moss advance kit maximum advance question Triumph 13
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
Upland Moss build-a-paper car contest Spridgets 1
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
JPSmit Stirling Moss - Sebring Sprite Spridgets 3
KVH TR4/4A Door Seals: Moss Part 249-607 Triumph 0
Simmo TR6 Moss Seats Triumph 0
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
E Moss stainless exhaust offering. Austin Healey 28
R TR2/3/3A New Control head wiring - Moss purchase Triumph 1
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
K TR2/3/3A Moss Europe has restored the Jabbeke TR2 Triumph 0
Jim_Stevens For Sale Pair of chrome tail lamp bases, NIB, Moss 159300 Triumph Classifieds 0
LarryK Moss Motors buys XKs Unlimited parts house. Jaguar 6
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
K TR2/3/3A The "compensator bar" on the Handbrake...#53 in Moss diagram Triumph 5
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
L 100/ Moss Heat Shield Austin Healey 2
mt10flyer TR2/3/3A Moss Steering Rack Conversion Triumph 26
Jim_Stevens TR2/3/3A Goodridge SS brakelines from Moss Triumph 3
R Moss permanently lubricated U-Joints Austin Healey 1
S For Sale TR6 New Moss 73-76 Seat Foam Kit Triumph Classifieds 0
M TR2/3/3A Fitting on Moss Brake/Clutch Masters Triumph 16
D TR2/3/3A Moss alternator kit Triumph 8
