    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
More on mechanical fuel pumps
T
Tinster
I have had 6 or 7 flatbed rides home due to failed mechanical fuel pumps. Paul Rego kindly gave me a beautifully rebult, OEM fuel pump. It lasted almost 200 miles.
Some folks laughed when I installed a parallel, hard wired, electric fuel pump system. Well it saved my arse today. Paul's pump failed in the middle of an intersection froma region mall to expressway. Cops were were on me immediately. Talk about a road-block!
Within ten minutes I had my hard wired electric fuel on line and drove drove home. I highly recommend ANYONE with a mechanical fuel pump install a hard wired electric pump in your earlu TR6s. Saved my arse today. The mechnical pumps are POS, IMO. I've had many in my Six.
Brosky
Please pull it apart Dale. I'd like to know what failed in there. Mine has about 2,000 miles on it and I don't drive it much at all. I'm always worried about gummed up fuel from my lack of driving so I use Marvel gas treatment every other tank fill up. So far no issues.
I'd like to see if the diaphragm or something else failed inside. I can't believe that it would only last 200 miles.
trrdster2000
Dale and Paul, Wow, that is hard to take, having that many failures. Dale, are you getting the control arm on top of the cam that runs the pump. I have seen them run off the bottom portion, but not for very long.
Wayne
Brosky
Wayne,
Dale has had that pump on for a couple of seasons now, so he installed it correctly. I'm just puzzled as to what let go after all this time. There was an earlier thread a month ago about fuel pump reliability and Dale posted the following, so something went wrong shortly after posting this:
"Randall! You would not be referring to a certain red, 1969 TR6 as having a redundant pump would you?
I went thru 4 mechanical pumps in less than 1000 miles of stop and breakdown driving. Paul Rego kindly sent me a beautifully rebuilt/restored mechanical pump and Don sent me a nice electric pump. I installed them in parallel with an easy switch over. 6000 miles later, Paul's pump is working just fine."
I'm just wondering if the diaphragm was eaten up or if something is inside the screen blocking the output. Or, it could be the valves. I'm sure he'll have it apart soon and the mystery will be solved.
trrdster2000
Paul, I too will wait for the answer, very puzzling.
Wayne
NutmegCT
My eyes are failing again. In Dale's first post about an hour ago, he says "Paul Rego kindly gave me a beautifully rebult, OEM fuel pump. It lasted almost 200 miles."
But Paul writes that in an earlier thread, Dale wrote "6000 miles later, Paul's pump is working just fine."
Could someone help me understand what's actually happening here?
Thanks.
Tom
Brosky
I didn't dream my response up Tom. It was quoted from an earlier thread in December about fuel pump reliability:
BCF Fuel Pump Relliability
I'd really like to know what failed, because I have a rebuilt pump on mine that was rebuilt with the same kit only two weeks earlier than the one that I sent to Dale. It came from this page on my site: Brosky Fuel Pump Rebuild
poolboy
Thanks.
Tom
Does smell fishy.... :sick:
Andrew Mace
In my experience over the years with many Triumphs, the OEM AC mechanical fuel pumps are like anvils and almost as reliable. The main differences are that anvils usually don't get sediment, varnish and rust from the gas tank in them, and they don't usually need to be rebuilt every....30-40 years. :wink:
TomMull
I agree 100% with Andy, there's not much in there to fail and it's fairly foolproof, two little one way valves and a diaphragm. I'd have a look inside for crud. My TR3 pump is 50 years old and works fine (ok it was in storage for almost 40 years). My anvil, on the other hand, is only a bit over 100 and already needs a new face. Tom
pdplot
The Piper Warriors and Archers I flew for many years had both a mechanical and an electric pump. The electric pump was only switched on for takeoff and landing. before taking off, we always shut off the electric pump just to make sure the mechanical pump was ok. I never had any problem.I may install a bypass electric pump on my TR-6 as I posted earlier.
PD
donbmw
I have had only 3 pumps fail. 2 of them on my TR3 the pivot pin which was pened in place came out. The pump I installed the valve came out found they where not pened reinstalled and this pump is still being used. I have installed a electric pump inline that because of vapor locking I am have with todays fuels..
Don
glemon
Wayne
This has got me curious, I have the pump on my TR250 with the sediment bowl pointed down, which made sense to me as it purpose is to accumulate sediment, I don't know which way it is supposed to go, but I do know it is darn near impossible to get the oil filter in and out, is the sediment bowl on a 250/6 supposed to go up or down? I assume the correct orientation of the sediment bowl will get you the correct orientation of the arm....
Brosky
Our pumps don't have those bowls. Only one way to go on the engine. It never would have gone 6,000 miles if installed incorrectly. Very interesting development.
Mickey Richaud
Dale - didn't you post about crud in your gas tank a year or so ago? I remember a picture of what came out of there; really nasty stuff. How does that fit this timeline?
Mickey
T
Tinster
Tom and Paul- An old feller like me is prone to typos, expecially on this new laptop the Mrs bought for me. Sorry!
I will type this slower. Yes! I have several seasons and about 6000 uneventful miles on Paul's beautiful pump. It is installed correctly. My fuel tank was brand new from Tony so no crud or rust. I buy my Hi Test fuel from only one gas station. I also put fuel additive every other tank or so.
I'll pull the pump out and see what's up. Something must be gummed up, who knows. I'll post what I find. Not in good health today- so later this week.
Thanks all
Mickey Richaud
OK - I knew you replaced the tank, but wasn't sure of the timeline.
Hope you get to feeling better - too many fish out there with your name on 'em!
Brosky
Well, the car can sit while you rest. Get better and let us know what you've found.
Good luck.
Brosky
The pumps that I rebuilt were all original units (with the levers) that were 30 plus years old. Most were filled with crap inside, but the disassembly and micro-polishing took care of that. These were spotless when I assembled them.
They are pretty bomb proof unless something gums them up, which is always my concern with the gasoline of today. Or, the fuel may attack the rubber, but I did use the best kits from TRF at that time, so we'll have to wait and see.
Bayless More Prefect Progress Other British Cars 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
C MGB More Weber help needed MG 27
DrEntropy More lessons in Japanese engineering Other Cars 7
KVH General Tech More Technical Questions—TR4 Triumph 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
AngliaGT A Few More Spotted 6
AngliaGT Saw a Few More Spotted 0
Bob Claffie More Village pics Other British Cars 0
Bob Claffie More Village pics Other Cars 3
M TR6 More noob questions… Triumph 14
Bayless More Paint Other British Cars 3
AngliaGT A Few More Local Vehicles Spotted 5
Basil More BMW Z4 trials Other Cars 21
AngliaGT A Few More I saw Yesterday Spotted 10
SteveTheBrewer Spitfire More rust repair Triumph 1
AngliaGT A Few More along Highway 220 Spotted 3
Bob Claffie More pics from Falls Village Festival Other British Cars 3
Sherlock Another cruise night, more interesting British iron Spotted 2
Y MGB More things that seem odd.... MG 2
D TR2/3/3A More Fuel pump questions. Triumph 10
jlaird MGB More on Bee's status MG 6
AngliaGT A Couple More Spotted 0
tr6nitjulius TR6 TR6 meeting my Demands & Giving Back more! Triumph 2
tr6web TR6 More leg room needed Triumph 5
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
Nelson No more MG Midgets Spridgets 3
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A TR3A SU's More Pics Triumph 0
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
7 No more Bosch tools for me Restoration & Tools 4
D TR2/3/3A More small nuts [ and studs!] Triumph 2
C TR6 More fun with Lucas Triumph 5
Bayless More Sprite progress finally Spridgets 23
Bayless Even more progress - the Prefect Other British Cars 5
maxwedge5281 one more time.....mirrors! Austin Healey 14
Bob Claffie T-Series More or less TD action MG 0
R More Shroud to Scuttle install Austin Healey 4
Y MGB Answer to a question creates more new questions.... MG 12
K TR2/3/3A Auxillary carb return spring in "More BS about TR,s" Triumph 9
S TR2/3/3A little more door gap Triumph 14
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
D BT-7 tri-carb Two more questions Austin Healey 18
R TR2/3/3A One more crank pulley question Triumph 7
K TR2/3/3A More electrical....the Starter? Triumph 8
