I took a 64' non overdrive gearbox with bad sycros and a 66' overdrive gearbox with bad gears and made one good OD gearbox. I used the OD and the mainshaft from the 66' and pretty much everything else for the 64' gearbox. Installed new Moss sycros and gaskets. Also rebuilt the OD. The bearings seemed fine, but the front bearing may have had some play, but didn't seem too bad. New clutch also.
The problem: I have a "rubby"/ "winey" sound (when cold) when I push in the clutch pedal. It goes away when the clutch is left out either in or out of gear. When it warms up it goes away. I think it is the pilot bushing? I didn't grease it and really didn't look at it carefully when apart.
The other thing is that the third gear sycro doesn't function? Could these be related? I know that later years require different sycros, but 64' and 66' should be the same? All the other sycros work fine.
Any ideas before I pull everything back apart? Thank you
