MGB MGB 1966 Gearbox
chuggy
Hi there. I have a 66 MGB roadster. Can anyone tell me what the attached (see pic)is? My gearbox leaks oil, from a small hole in the bottom of the casing. Out of this hole is what looks like the end of a split pin. Does anyone know what this is? I've looked through the haynes manual and can't find any reference to it. Any comments appreciated.
vping
Bronze
I do not see a pic but this is normal. I think it hold a spring to keep tension on the inside but my memory fails me. stoo early. Yawn.
Platinum
The split pin is just there to keep the weep hole from clogging with foreign material. Sounds as if the rear main seal or the transmission input shaft seal (or both) has become worn.
vping
Bronze
Now I remember. Good morning I am awake now that I have been under my sink for an hour trying to fix a leak. Thanks doc.
Forget about that spring thingy thing.
Platinum
Mornin' Vince! Did you conquer the leak?
vping
Bronze
Between last & this post had to run to the Depot. The mrs. likes to wash the plants in the sink and give a drink I've told her no and she say" oh whats the harm" "calm your jets". Ok.. lets see I was a plumber for about 5 years and have laid more pipe than...well lets just say more than any sane person would in 5 years of plumbing.
Little grains of sand settle in the bottom of the P-trap and sit there eating away at the brass. A little bump and you know what starts happening from aforementioned fitting. Just about to put it in and all should be well.
Platinum
's what I meant by rear main seal.
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 3
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J MGB 1966 MGB won't start MG 1
J MGB Just bought a 1966 MGB MG 50
C MGB 1966 MGB windshield glass MG 4
1 MGB 1966 MGB hard shifting into 3rd MG 1
ronzet MGB Hard to Start 1966 MGB MG 4
J MGB 1966 MGB Hard Top. MG 1
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
T MGB MGB hoses MG 6
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
R MGB 1972 MGB Defroster Hose MG 2
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
T MGB-GT cant rails on 1967 MGB GT MG 12
