MGB More MGB gearbox questions
mmotors
What I found: The end float on the third gear turned out to be .016/ should be .004-.006/ .012 too much.
A) would this cause the third gear syncro issue?
B) do I find a .1615 end thrust washer or do I find a shim?
C) wouldn't that just cause the third gear to be moved further away from the syncro and syncro ring? Would it be better to shim between the third and second gears?
Thank you, Shawn
64' MGB
Brinkerhoff
Shawn , Do 2nd and 3rd line up perfectly with their mates on the laygear? 12 thou. does not seem like a lot but it could cause your problem. I'll go look at the shop manual and think about this. Sometimes you have an obvious problem , sometimes its harder to find. Is the change to 2nd gear without noise? This is the early non synchro first isn't it? Kevin
M
mmotors
They do seem to line up fine. The 2nd gear syncro works great. I am very unsure why the 3rd syncro doesn't work, when everything else seems good. One suggestion was to roughen up the cone on the 3rd gear, but I hate to reinstall everything to find out that didn't work.
BlueMax
I’ll remind you that the cones of each gear are a ground finish. Engineers wanted to protect the gear so brass was a perfect alloy to work in this environment. Brass is a malleable alloy; the gears are a harden ground steel alloy. What has taken place is the brass has burnish it self into the cone. Doesn’t the cone look like a polish mirror? If you were installing a brand new gear it would have a surface ground finish not a polish finish. Your gear can not slow down enough to let the outer hub line up to make the shift, that is why you’re getting that crunch. You’re forcing the slide over the gear while it’s still spinning to fast. Your gear still has the sharp edges on it, doesn’t? If it does, which it should, then your road leads back to the synchronizer. If you were a very articulate driver and had the skills of matching RPM with transmission speed you wouldn’t need synchronizers, but the majority of us do not have this wonderful talent so that’s why the engineers installed synchronizers so that everyone can drive a manual transmission. From what I’ve read you are not that much out of spec with your clearances and the gears are properly align. I can only advise you on what is taking place; you have to decide what you want to do.
M
mmotors
Yep, they look like mirrors. I do plan to roughen them up. One thing that is confusing though, is that the second gear surface (cone) is also mirror like and the second gear syncro works great. Any ideas why that would be?
Thanks for the help, Shawn
BlueMax
Not knowing what your issues with the transmission prier to you disassembly and whether your issues were with the 2nd and 3rd gears. However I assume you have replaced all of your bearings including the spigot bearing. Most people over look this bearing and consider this bearing none essential but it too is very important for proper alignment and thrust clearance. Are you running the right shims at your input shaft cover? Your 2nd and 3rd gear cone could have a little more wear on it. When you have the gear flat on your work bench lay the new synchronizer on the gear and measure how much clearance between the synchronizer and the gear to see how much your gear cone has warn. Compare to you specification for your transmission and replace if its out of tolerance. Also switch your synchronizers around to make sure that you do not have a defective synchronizer this can happen sometimes. Make sure that the slide assembly is on the main shaft the way it came off the main shaft. It can go either way I believe, but sometimes they get a ware pattern and need to go back the way the were remove. Scuff all the cones very well, blowing any grit off that gets left behind. I wish I could be their to see and feel what your dealing sorry!
M
mmotors
Funny you say about the pilot bushing. The other reason I pulled the engine and gearbox was because of the pilot bushing. When the car was cold, I would push in the clutch and would get a whiney/ rubbing noise that made it very difficult to get it in 1st gear. I know there was an issue with the pilot bushing, but when the car warmed up it was fine. When I took it apart I noticed that it appeared the the end taper of the first motion shaft was making slight contact with the end of the pilot bushing.
I would think it could be possible that when going to 3rd gear that the pilot bushing could be making contact making it hard to syncro the gear speed. But only 3rd? Why not 1st and 2nd and 4th when warmed up?
I plan to also replace the pilot bushing. Another interesting thing is that the pilot bushing was only about 3/4" long, when it should be 1 1/16". Maybe a wrong one installed prior? Maybe worn down?
B More Spridget [and MGA/MGB] parts- Spridgets 5
Hoosier MGB 1980 MGB rebuild project....A little more help nee MG 4
Bayless More Prefect Progress Other British Cars 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
C MGB More Weber help needed MG 27
DrEntropy More lessons in Japanese engineering Other Cars 7
KVH General Tech More Technical Questions—TR4 Triumph 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
AngliaGT A Few More Spotted 6
AngliaGT Saw a Few More Spotted 0
Bob Claffie More Village pics Other British Cars 0
Bob Claffie More Village pics Other Cars 3
M TR6 More noob questions… Triumph 14
Bayless More Paint Other British Cars 3
AngliaGT A Few More Local Vehicles Spotted 5
Basil More BMW Z4 trials Other Cars 21
AngliaGT A Few More I saw Yesterday Spotted 10
SteveTheBrewer Spitfire More rust repair Triumph 1
AngliaGT A Few More along Highway 220 Spotted 3
Bob Claffie More pics from Falls Village Festival Other British Cars 3
Sherlock Another cruise night, more interesting British iron Spotted 2
Y MGB More things that seem odd.... MG 2
D TR2/3/3A More Fuel pump questions. Triumph 10
jlaird MGB More on Bee's status MG 6
AngliaGT A Couple More Spotted 0
tr6nitjulius TR6 TR6 meeting my Demands & Giving Back more! Triumph 2
tr6web TR6 More leg room needed Triumph 5
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
Nelson No more MG Midgets Spridgets 3
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A TR3A SU's More Pics Triumph 0
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
7 No more Bosch tools for me Restoration & Tools 4
D TR2/3/3A More small nuts [ and studs!] Triumph 2
C TR6 More fun with Lucas Triumph 5
Bayless More Sprite progress finally Spridgets 23
Bayless Even more progress - the Prefect Other British Cars 5
maxwedge5281 one more time.....mirrors! Austin Healey 14
Bob Claffie T-Series More or less TD action MG 0
R More Shroud to Scuttle install Austin Healey 4
Y MGB Answer to a question creates more new questions.... MG 12
K TR2/3/3A Auxillary carb return spring in "More BS about TR,s" Triumph 9
S TR2/3/3A little more door gap Triumph 14
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
D BT-7 tri-carb Two more questions Austin Healey 18
