For Sale Metropolitan engine and parts
Steve P.
Block number 15F-N-H 25098. Includes pan, crank, cam, pistons & rods, flywheel, oil canister
and adaptor,. Seem to be original bores. Rusty but should be rebuildable. No cracks
or other defects I can see.
Original air filter, also rusty.
$75 for all, pick up in Santa Rosa, CA 95403, Or swap for Spridget parts?
Steve
Steve P. MGA Metropolitan 1500 engine same as MGA??? MG 4
H Nash Metropolitan--It is British--you know! Other British Cars 9
L METROPOLITAN PARTS Other British Cars 0
P Nash Metropolitan Other British Cars 5
doc50 For Sale 1958 Metropolitan Other British Classifieds 0
doc50 58 Metropolitan Steering Box Leaks Other British Cars 0
doc50 Su carbs for a Metropolitan? Other British Cars 1
doc50 1958 Metropolitan Progress Other British Cars 4
doc50 NASH METROPOLITAN trans capacity? Other British Cars 0
doc50 Mash Metropolitan Generator testing Other British Cars 1
doc50 58 Nash Metropolitan valve clearance? Other British Cars 6
Gliderman8 Nash Metropolitan Spotted 3
longbridgehealey 1961 Nash Metropolitan Spotted 2
NutmegCT Metropolitan? Other Cars 20
E The Sprite and the Metropolitan Spridgets 6
J 1957 Nash Metropolitan Heater Parts Other British Cars 6
Mickey Richaud Metropolitan Spotted 1
T Using Midget Suspension parts on Nash Metropolitan MG 10
JPSmit Nash Metropolitan Other Cars 2
aeronca65t Nash Metropolitan Other British Cars 8
78Z Hudson Metropolitan - I never knew! Other Cars 1
D Nash Metropolitan steering rack Other British Cars 1
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
