So here I am again trying to mate the overdrive to the gearbox and have been trying to do so for over a week. OD hangs up about a cm short. It's engaged on something as I have to give it a good yank to get it off again. Oil pump has been tied with a piece of string so it's not that which is causing the issue. Splines have been aligned as best I can and look good to me with the naked eye. But it still will not go on. Overdrive is new, gearbox has just been rebuilt. So what to do next? I am thinking about disassembling the gearbox again at checking that the mainshaft does indeed fit in the new od. Surely it couldn't be the case that the splines in the od don't fit my mainshaft...? What should I do...persevere with it? Disassemble to gearbox...? Or try to find a specialist to do it for me...? Suggestions gratefully received....
Myles
Myles
