leak down vs compresion test
folks i am working on a ford v6, yea i know, but any way...engines has a miss at all speeds, lock of power ruff idle. traced the problem to #2 cyl. i have replaced all six injectors, compresion is good nice and even on both banks, around 175 or so, got my hands on a leakdown tester and did it up this evening, the numbers are all 6-8% on all but #2 which is 26% and i hear air leaking into the valve cover. Is this a no brainer or what? i cant seem to get my head around the compresion being so good and this cyl obviously being bad, am i to assume that there is a crack thru the head into the rocker area? all thoughts on this are welcome.
mark
It may be bad rings on that piston with air leaking past them into the crankcase then up through to the valve cover since there's no way out down below....
Another possibility might be a bad head gasket venting into those passages. But I'd also expect oil in the coolant or vice versa- if you have neither try testing and look for bubbles in the coolant.
SteveL
Broken valve spring comes to mind, as does a burnt valve...
SteveL
Banjo
I'm with James,
Hearing air in the valve cover is blowby from the rings. The air is leaking into the crankcase, part of which is the valve covers.
Do you have spark at that cyl. If the compression test was good, it should still be firing at least at higher speeds.
SilentUnicorn
thats what gets me. i did forget to mention that the coolant overflow is full of oil, and i mean full of oil. the level is good but it is all oil. there is occasional white smoke but not much. the underside of the v/c was pretty milky with signs of water. if it was rings, or a head gasket, wouldn't the compression be somewhat lower? when i goose WOT i can get an intermenint backfire in the intake. what is happening to the fuel charge? and another thing is that the engine doesnt seem to want o get to temp very well it comes up and drops off, almost like it is cooling to much.
cap plug and wires are all new, and the fire is in the hole, i have visually checked that the plug is firing. i have even swapped plugs around, makes no difference. i checked the inj when i had the rail off and all are firing. compression is the same with plugs out or in.
theory: a crack in the head into the oil return passage including part of the water jacket.
theory:
headgasket blown between oil return and water jacket and cyl? would this allow compression to build but also quench the spark? (its kinda tuff to read these plugs but they are all somwhat black and sooty, but they havent really been driven on much)
more thought from my rambling mind...
mark
Paul Johnson
You're right on. 20% is maximum allowed on leak down, best I recall. You certainly have either a failed head gasket or cracked head, given all the other indications.
A
Americanshine
Has any one ever thought of a bent valve? That would do it in a leak down, I have seen this at many a drag race. Someone may have floated the valves and one got bent. Just a slight bend would do it for ya, and the motor would still operate.
Dave Russell
Yoda - R.I.P
The good feature of a leak down test is that it can locate problems & also eliminate problems. He hears leakage into the crankcase/valve cover. A bent valve would cause leakage into the intake or exhaust systems, not the crankcase. Especially with oil in the coolant, the cracked head or leaking headgasket are the most likely sources of the problem.
SteveL
is this a 4.0L?? There is an oil passage that goes
through the head gasket to the head, to lube the rocker
shaft... or am I thinking about the 2.8L?? You may have
a blown head gasket between a coolant hole and the oil
passage, a crack in the block between the oil gallerey
and coolant side, or a cracked head, which the 2.9L and
the 4.0L are somewhat famous for...
SteveL
SilentUnicorn
yea its a 2.9, i have been haunting the ranger forum a little and have learned that these motors can crack a head if ya look at them wrong. looks like i will be pulling the head in the near future, of course it couldn't be the ez side. its the passenger side and the vehicle has ac, which will make it a lil bit of a challenge. but i think it can be done in place.
mark
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
KVH General Tech Leak Down Test Triumph 17
dklawson Spitfire 1300 Spitfire Compression & Leak Down Results Triumph 15
dklawson Leak-Down Tests - What's Good ??? Spridgets 18
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
N TR5/TR250 Starter Box Assembly Leak Triumph 14
I MGB Sprung an (oil) Leak! MG 2
B TR6 Triumph tr6 coolant leak Triumph 4
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
edkap2002 TR6 Amperage leak? Triumph 4
B Oil (or Coolant) Leak Austin Healey 10
G HD8 Carb Leak Austin Healey 7
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
B Phanton Oil Leak Spridgets 12
Martinld123 Steering Box Leak Austin Healey 27
B gas leak underneath the carburetor Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
Gundog61 BN2 Steering Box Leak Austin Healey 2
P TR6 Brake fluid leak? Triumph 6
Zitch Engine Oil Leak After Long Drive Austin Healey 19
D Wire Wheels and Air Leak Austin Healey 16
T crankshaft (rear) bearing leak Spridgets 2
P Subaru fluid leak Other Cars 9
D TR2/3/3A Have exchanged one leak for another. Triumph 10
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
Michael Oritt Leak from carbs Austin Healey 13
2 TR2/3/3A Oil leak in tranny Triumph 4
nichola TR6 Oil pan is going to leak: suggestions? Triumph 11
D Clutch Master Cylinder Leak Austin Healey 20
S Axle leak at backing plate Austin Healey 26
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
Michael Oritt Water Pump Leak Austin Healey 41
tahoe healey Leak into boot Austin Healey 17
S Rear axle - small leak .....? Austin Healey 7
S TR2/3/3A Vacuum leak Triumph 19
Lin Rear differential drain plug leak Austin Healey 16
steveg Strange Oil Leak Austin Healey 7
gfholl Coolant Leak Spridgets 9
1 MGB Found the leak, now what? MG 11
TomMull TR2/3/3A Transmission oil leak Triumph 17
S TR2/3/3A Differential Gasket & Oil Leak Triumph 9
KVH General Tech OD Transmission Leak Triumph 5
D BT7 Oil Leak at Distributor Austin Healey 5
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
J TR4/4A Oil leak from rear of motor. Triumph 28
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
warwick-steve Final fix for clutch pipe to master cylinder leak?? Austin Healey 13
