Spitfire Jumping a dead battery on a Spit MK1
DanNagy
I had a busy schedule on my last trip home, but I made time to take the Spit for its paperwork. Unfortunately the battery was dead, and it needed a jump start. It's too late, I already tried it and burned something up. I wasn't thinking. darn the reverse grounding. I appreciate out-of-the-box thinking, but why-oh-why did they do that?
Anyway, something is toast, and my best guess and clue from my mechanic is probably the alternator. Is there consensus?
Next time I'll take the battery out of the car and charge it up. That's a $150 impatient mistake for not asking on the forum first. Sigh.
Andrew Mace
Dan, did something "physically" burn up as in smoke and flames, or is it just that something now appears not to be working? Yes, you could have burned up an alternator if you had one, but odds are pretty good that anyone who fitted an alternator to an older Spitfire would also have reversed the battery polarity to the now nearly universal Negative Ground, seeing as there weren't and aren't all that many Positive Ground alternators around.
Otherwise, it makes no difference how the "dead" car is grounded, nor the "live" car, so long as you make sure the cars don't touch and that Positive goes to Positive and Negative to Negative. Actually, in jumping a Positive Ground car from a modern Negative Ground car, I suppose it might make sense to connect the Negative cables to the respective battery posts and then connect the Positive cable from the jumper car to a good ground on the dead car. Frankly, I never bother with that. (Actually, I've jumped more Negative Ground cars with my Positive Ground Herald than the other way 'round!)
tdskip
Sorry to hear of your trouble Dan - but can we get a bit more specific.
Is the battery still totally dead? Is it holding any charge? What happens when you turn the ignition key?
DanNagy
DanNagy
Thanks Andy and tdskip, no, it didn't really burn up or smoke... drama on my part. The battery had enough juice in it to cause a click, but not enough to turn over. So when I saw the battery was put in backwards, I called my mechanic and he explained it was a positive ground car. He said to reverse the jumper cables. I did, and sparks started to fly. Big sparks. I immediately removed the cables, but then I no longer had the click. I assumed that I burned something out.
Now I am back overseas and can't get at it until July, but I want to have a part waiting for me to put in. I want to work on this myself if possible. This is my learning car. So far, my score card isn't looking so good.
Andrew Mace
I'm still not totally clear, but now I'm wondering if you were actually ok the first time. But when you reversed the jumper cables, THEN the connection WAS backward? That could cause sparks, I suppose; worse, it could have caused problems with the vehicle from which you were jumping. Or were you just using a bare battery as a jumper source?
Again, on a generator system, I don't think you'd have done much if any harm to the Spitfire, with the possible exception of the "dead" battery.
hondo402000
It doesnt matter jumping positive ground cars as long as the cables go positive post to positive post and negative post to negative post
hondo
cheseroo
I would speculate that the sparking that occurred when the leads were reversed drained what little remained in the Spit's battery. In your position with what appears to be limited time, a new charged battery probably is in your future. Buying anything outside of that would be a bit speculative unless you really need spares. If car is generator equipped, I would suspect the voltage regulator would take a hit sooner than the generator in a quickie reversed lead situation. I guess it all really depends on the amount of time you have to fuss with the car but I can't see being in big rush to buy a new alternator particularly since this sounds like the leads were reversed for a very short time. For those with more time than money and scottish heritage, I've been able to buy some extra mileage out of marginal batteries by dropping an aspirin down each cell and charging. The aspirin seems to clean the plates a bit and buy a little extra oomph.
DanNagy
DanNagy
Lol. I've dropped aspirin in car batteries when I was younger and had forgotten about that trick. Okay, I'll try a good charge on the battery when I get back and go from there. Thanks for all your advice.
P.S. I was jumping the Spit from another car - no damage.
Joe Schlosser Bugeye Spedo jumping Spridgets 6
jlaird Miss Agatha jumping up and down Spridgets 0
vette PCV Valve, Jumping in With Both Feet Austin Healey 17
J BN2 Tranny Jumping Out of 1st Gear Austin Healey 1
PeterK Jumping a battery safely Triumph 2
L How to smooth out a jumping fuel gauge? Austin Healey 20
tinman58 Old LBC jumping new muscle Triumph 1
B TR6 TR6 Jumping out of Reverse Triumph 5
H jumping out of 2nd gear Austin Healey 3
T Argh! Jumping out of second gear now Triumph 10
davidk Speedometer needle jumping Triumph 29
L Tach jumping, rough idle. Triumph 9
tony barnhill #5 Rocker Jumping off Pushrod MG 16
Michael Oritt Battery Jumping Negative/Positive ground cars Austin Healey 31
J Jumping a Positve Grounded Battery Austin Healey 3
G Jumping Tach MG 4
DerekJ Batteries Going Dead Austin Healey 9
K TR2/3/3A The Dead Pedal Triumph 3
T MGB MGB Dead Short? MG 8
petnatcar Dead Pedal Austin Healey 12
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
R How old is "dead" FORUM Navigation Questions 5
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
FlyingCat Spitfire Dead Starter? Triumph 18
Sopwith_Camel dead at the finish line Spridgets 10
6 Dead Circuit ARRGH! Spridgets 13
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
L TR6 need help on long dead TR6 Triumph 16
petnatcar DEAD PEDAL for a BT7 Austin Healey 25
2billydavies TR2/3/3A dead battery... until i disconnect the wire from coil to distributor Triumph 10
T TR4/4A Flat/dead spot on the starter? Triumph 5
K TR2/3/3A Dead Petronix and rough running..... Triumph 10
M TR2/3/3A Finding top dead center Triumph 6
GTP1960 TR2/3/3A Fuel pump inertia switch vs. dead engine switch? Triumph 14
JPSmit Truck diagnostic advice needed [I suspect it is dead!]] Other Cars 7
sim Dead spark plugs ? Spridgets 52
JPSmit Sometimes I am surprised I am not dead Spridgets 15
P Turning to Top Dead Center Austin Healey 11
R dead pedal for '74 midget? Spridgets 4
RickB All 4 parking lights dead, fuses all good? Spridgets 6
dklawson Alex Moulton Dead at 92. - 12/10/12 British Motor Corp 1
NardisCNC DEAD Battery Question...... Spridgets 12
D Dead Boot -- What do you know about this ? Jaguar 6
G DEAD BATTERY Austin Healey 4
M Top Dead Center Triumph 48
L I see dead cars... Austin Healey 9
D Car seems to have a dead battery [I no it's good] Spridgets 13
G GRRRR -- Dead in the water again!! MG 6
S Wedge TR8 starter dead spot? Triumph 26
G Gauges dead after wash Spridgets 6
