Turning to Top Dead Center
peteatgr
I am preparing to install a new Pertronix Flame Thrower distributor and I want to make sure it's timed properly to TDC. I've never had to try to turn the engine before unless I had the radiator out and the fan removed making everything really easy and open to reach - simple to get a wrench on and turn away. I'd prefer not to have to take both both of those out again. Pardon my ignorance, but what's the easiest way/technique to turn the motor forward to TDC with everything installed? I've got the plugs out but just can't seem to get a good enough grip on anything. I've loosened the fan belt but am beginning to think maybe I should have it under tension and use it and rotating the water pump by hand to turn the block? I'm sure this gets done al the time, but I've never had to in 39 years..............or I can't remember back that far.
Patrick67BJ8
With the spark plugs "out" and the car in "gear" (emergency brake "off"), push/pull the car and the engine will rotate.
MikeAH100M
I found that rocking the car by grabbing a tire was the easiest. To determine TDC, I used Norman Nock's suggestion of putting a wooden dowel in the spark plug hole #1. Move the car until the dowel is pushed out the farthest.
richberman
I did it using a compression tester with the Schraeder valve removed and replacing the compression gauge with a vacuum/pressure gauge. I purchased both on Amazon for around $20. I put one rear tire up on a jackstand, leaving the other tire on the ground, placed the car in 4th gear and removed all plugs to make it easier to turn. Was able to face the gauge the the right rear and see it as I move the tire until the gauge did not cause pressure or vacuum. Doubly confirmed by looking into the plug hole.
steveg
I did it using a compression tester with the Schraeder valve removed and replacing the compression gauge with a vacuum/pressure gauge. I purchased both on Amazon for around $20. I put on rear tire up on a jackstand, leaving the other tire on the ground, placed the car in 4th gear and removed all plugs to make it easier to turn. Was able to face the gauge the the right rear and see it as I move the tire until the gauge did not cause pressure or vacuum. Doubly confirmed by looking into the plug hole.
That's pretty cool!
vette
Put your fan belt back on snug. Remove spark plugs. from right side of car, put left hand on fan belt between generator and water pump pulley and press belt down to make tight. With right hand grab fan blade, ( MAKE SURE ALL POWER TO IGNITION IF OFF) pull or push fan blade to turn engine. To ensure TDC on the compression stroke vice 180* out, take distributor cap off, now turn engine till the pointer and the notch in pulley line up. When on TDC on the compression stroke the distributor rotor will point to approx 1 to 2 o'clock. If the rotor points in the opposite direction you are not on the compression stroke. Dave.
P
peteatgr
All good techniques and I've already made use of a couple. Thanks. I've got the engine positioned at TDC so that the notch on the fly wheel is directly opposite the pointer, but in that position the orientation of the distributor drive spindle appears to be 180 out of proper phase when I look at my distributor and the different size drive lobs cut in the face of the spindle itself. Is it possible that the fly wheel might have a "180 mark"? The notch appears professionally made.
I thought about removing and realigning the distributor drive spindle using the 5/16" fine thread bolt as a couple of manuals describe and the bolt threaded into the center of the spindle just fine. But I was still unable to remove the spindle. The spindle moves up and down a small fraction of an inch but feels like something is still holding/locking it in place. Anyone have any hints on techniques for removing the distributor spindle? Is there a set screw or something holding it? Or should I even be messing around with that?
Keith_M
You're on the exhaust stroke instead of the compression stroke. Turn the crank one full revolution and bring it back to TDC. That should bring the distributor to the correct place.
bob hughes
As to the difficulty in removing the drive gear with a 5/16 BSF bolt, you would need to turn the gear as you pull it out - anti clockwise from memory, but it sounds like you would not need to do that now.
The best way to ensure that you are on the compression stroke TDC is to remove the valve cover and observe the rocker arms on the number one intake and exhaust - both valves should be closed.
:cheers:
Bob
steveg
:cheers:
Bob
In addition, the rockers for #1 cylinder will both be loose.
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
Scotsman TR2/3/3A Drum break turning specifications Triumph 2
2billydavies TR2/3/3A Question about front turning blinker wires Triumph 12
Rob Glasgow Turning brake drums Austin Healey 5
M Really dumb question related to turning back wheel and drive shaft Spridgets 4
G MGB Hand turning the crank MG 7
Lukens Turning motor over by hand? Triumph 22
P Steering column turning Triumph 2
H GT6 Turning GT6+ brake drums Triumph 10
Sopwith_Camel slow turning Spridgets 25
Jim_Gruber Steering Rack, harder turning Left than Right - Spridgets 11
B Crank turning Austin Healey 8
pjsmetana Thump Thump Thump... when turning hard Triumph 5
J ignition key turning, BJ8 Austin Healey 5
C Turning ball joint Triumph 6
jjbunn Battery drain after turning engine over Triumph 7
beaulieu turning over an engine sitting for years ? Jaguar 22
miranda steering wheel won't turn back after turning Austin Healey 6
O Starter Turning over- Please help MG 4
AUSMHLY Turning radius Austin Healey 5
Cain TR6 TR6 Crank Turning for Timing/Retard Unit Triumph 8
G LOSS OF POWER WHEN TURNING RIGHT? MG 4
F Turning your engine when adjusting your valves ? Triumph 6
TR4 TR4/4A TR4 points turning white???? Triumph 19
J TR6 TR6 not turning off Triumph 3
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
S TR6 Soft top material Triumph 10
Sarastro TR4/4A Convertible top installation problem Triumph 12
A TR6 TR 6 Soft Top Triumph 4
D BJ8 Top Installation Detail Austin Healey 3
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
zoohow BN4 Top Frame Installation Austin Healey 1
L Do you have a picture of these convertible top details? Spridgets 4
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
Frameman 1949 Soft Top Webbing Austin Healey 2
Overdrive45 Convertible Top Cover Fit Austin Healey 6
D Top installer recommendations NYC tri-State area Austin Healey 0
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
S For Sale FREE HARDTOP.. top is in Palm Springs, Cal. Call Bob ,562 400 5983 MG Classifieds 1
E Spitfire '69 Spitfire hard top Triumph 2
Celtic 77 MGB B-pillar repair kit for convertible top MG 1
Popeye TR4/4A Tonneau or top cover? Triumph 12
7 Top, hard Triumph 0
JPSmit Today's top tip - Rain X Restoration & Tools 3
Popeye General TR Old robbins top in box Triumph 7
