GT6 Turning GT6+ brake drums
Hoodat
Hello all,
Been lurking and learning here for a while; now a question I can't find an answer to here or elsewhere on the Web: What is the maximum diameter to which the GT6 drums can be turned? The machinist at the local NAPA shop sez he's not sure he can find the specs. I can't find any dimensions stamped on the drums.
TIA for the dimension or suggestions on where to look for it.
Chuck
jsfbond
That is why we got rid of our brake lathe at the parts store, we hardly ever turned rotors and drums because the price came down so much. Throw-away society.
jsfbond
We just had a sales mtg., and were informed that (commercially) nobody is making rotors in North America. The quality is there, but so are the jobs!
jsfbond
Hoodat said:
Hello all,
Chuck
I will look at my drums tonight (they are in good shape) and see if there is any info to be found.
hondo402000
yea and most of our foundries were forced into shutting down because of our wonderful government and the EPA. no wonder companies outsource
I will leave it a that
Hondo
H
Hoodat
Thanks, JimEgan. I'll see if that's good enough for the machinist. He was making noises about liability issues last week....
Chuck
TR3driver
Great Pumpkin - R.I.P
I won't. The steel foundries had <span style="font-weight: bold">years</span> to clean up their act and install furnaces that were less polluting (and cheaper to operate). Instead <span style="font-weight: bold">they chose</span> to continue operating the old open hearth furnaces that were making such a mess of that entire area. The EPA didn't shut down the open hearth furnaces until it became obvious that the steel companies were never going to do it on their own.
I used to live in the area, I've seen the perpetually orange-brown air, the effects of acid rain on practically everything, the thick carpet of dead fish on Lake Michigan. The lake has recovered somewhat, but at one time it was thought to be permanently "dead".
It's an ill bird that fouls it's own nest; but that is exactly what they were doing.
Oh, and steel production still isn't exactly dead in the US. We produced almost 100,000,000 tons of raw steel last year. That's a little off from it's historical peak of 130 million tons, but not by much.
70herald
I remember going through Gary Indiana in the '70s. There is a good reason it is (was?) called the armpit of America.
The last time I drove through about 10 years ago the air no longer stank or burned your eyes.
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
Scotsman TR2/3/3A Drum break turning specifications Triumph 2
2billydavies TR2/3/3A Question about front turning blinker wires Triumph 12
Rob Glasgow Turning brake drums Austin Healey 5
M Really dumb question related to turning back wheel and drive shaft Spridgets 4
P Turning to Top Dead Center Austin Healey 11
G MGB Hand turning the crank MG 7
Lukens Turning motor over by hand? Triumph 22
P Steering column turning Triumph 2
Sopwith_Camel slow turning Spridgets 25
Jim_Gruber Steering Rack, harder turning Left than Right - Spridgets 11
B Crank turning Austin Healey 8
pjsmetana Thump Thump Thump... when turning hard Triumph 5
J ignition key turning, BJ8 Austin Healey 5
C Turning ball joint Triumph 6
jjbunn Battery drain after turning engine over Triumph 7
beaulieu turning over an engine sitting for years ? Jaguar 22
miranda steering wheel won't turn back after turning Austin Healey 6
O Starter Turning over- Please help MG 4
AUSMHLY Turning radius Austin Healey 5
Cain TR6 TR6 Crank Turning for Timing/Retard Unit Triumph 8
G LOSS OF POWER WHEN TURNING RIGHT? MG 4
F Turning your engine when adjusting your valves ? Triumph 6
TR4 TR4/4A TR4 points turning white???? Triumph 19
J TR6 TR6 not turning off Triumph 3
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
C GT6 GT6 fender flares Triumph 0
B GT6 trying to ID my New Car. GT6 Triumph 6
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
D GT6 9 months later. GT6+ progress Triumph 3
luke44 For Sale ‘72 GT6 MKIII For Sale Triumph Classifieds 0
LarryK GT6 Fresh purchased GT6 Triumph 11
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
idlehands Wanted GT6+ Triumph Classifieds 11
E GT6 Triumph GT6 MKIII rear hatch springs Triumph 2
B Wanted wing windows gt6 Austin Healey Classifieds 0
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
UltimateQuestion GT6 GT6 Mk3 rear wing removal Triumph 3
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
