Is my Thermostat Sticking?
borjis
Much like a jet fighter pilot, I monitor my guages constantly always on the lookout for abnormal conditions (water temp and oil pressure)
I was driving today and noticed that the temp guage was going well beyond "N" for the first time ever. This engine has just over 1,000 miles on a full rebuild and everything during the restoration of the car (completed last year) was replaced.
Now it would get very close to the red zone while driving, when at a traffic light it would quickly move back to N. But when the RPMs went up even a little, it would climb back up again.
Is my thermostat bad/stuck?
I'm seriously considering removing it and running without one as I only drive the car on nice days and only after a proper warm up period.
maynard
You didn't say what year your car is, so here is a couple of ideas.
If it has an electric fan (as in the rubber bumper cars), it may not be turning on.
If you don't have the electric fan, you have the typical sympton of a partially clogged radiator.
B
borjis
1972 MGB.
It's a brand new radiator and both (heater core also) were flushed and pressure tested when the engine was assembled 2 years ago.
I checked the coolant levels before driving today and it was full and the coolant green and clean.
It does have an electric fan but its working well as usual.
Like I said, its a brand new car now with about 1,035 miles on it as of today. This has never happened before.
jlaird
Agree, would remove the thermostat and see what happens. It will be fine without the thremostat for quite some time. In any case they are cheep.
David_DuBois
"...when at a traffic light it would quickly move back to N. But when the RPMs went up even a little, it would climb back up again." The fact that the temp indicationclimbs quickly with any increase of RPM would indicate that you have a non operative voltage stabalizer. If the thermostat was stuck, the temperature would not drop when you are waiting for a signal (the temperature doesn't drop that quickly), nor would it climb quickly with a rise in the RPM. Take a look at your fuel gauge and oil pressure gauge (if it is electrically operated) and see if either one of them goes through those silly gyrations with changes in the RPM. If they do,it is a clear sign that the voltage stabalizer is causing problems.
Cheers,
B
borjis
David, that is VERY interesting indeed.
My fuel guage was acting funny today as well.
I filled the tank a week ago and the guage went down a little but sometimes it would peg itself at full.
Today it did the same thing, sometimes it would show 1/4 tank but it would be pegged at full again minutes later, I kept wondering why the heck it was doing that.
Oil Guage is mechanical and was operating properly.
The voltage stabilizer (the little box next to the fuseblock right?) is one of the few things that has not been replaced and is the same one the car has had in it for 10 years when I bought it before the restoration.
I was just thinking the other day of replacing it with the new solid state one that Moss sells as the original looks old and not so pretty to look at compared to everything else in the engine compartment.
Anyone else using the new moss solid state voltage stabilizers?
David_DuBois
The oltage stabalizer is on the forward bulkhead ahead of hte dash and roughly in line with the steering column. Check the ground to the thing before replacing it. It is grounded through the mounting screw, so take the screw out and check that you have bright metal on both the stabalizer and on the bulkhead around the screw hole. If you do need a new stabalizer, the solid state ones will work fine.
Cheers,
B
borjis
moss was out of ones for negative ground so I ordered one from victory british.
Interesting it is the box in the bulk head.
Do you know what it is that is mounted next to the fuseblock? (little metal box)
BoneIdle
It's probably your stabilizer, but I had similar symptoms when I first put mine on the road. The rear brakes locked up after driving about 50 miles ( lack of use by PO). Sitting at a light was no problem, but as soon as I accelerated, the temp gauge would start climbing. Funny thing: acceleration was a little sluggish, but not so much that you'd suspect the brakes were having problems.The smoke from the rear wheels gave it away, though.
K TR2/3/3A Further to "plugging the thermostat bypass hose"/ Triumph 25
K TR2/3/3A Thermostat for hot summer driving? Triumph 1
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
Twit TR4/4A shining up thermostat housing Triumph 9
Lin Thermostat and blanking Sleeve question again Austin Healey 7
R TR2/3/3A Thermostat and bypass hose Triumph 15
T TR2/3/3A Question on TR3 thermostat from TRF Triumph 6
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
AUSMHLY BJ8 Thermostat Austin Healey 4
Healey Nut Thermostat blanking sleeve Austin Healey 13
RAC68 Radiator Core Replacement and Sleeve Thermostat Alternatives Austin Healey 20
D BT7 Thermostat Austin Healey 1
D BT7 thermostat gasket Austin Healey 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
C Corrosion of the thermostat cover Austin Healey 8
R TR2/3/3A Correct Thermostat? Triumph 7
O TR2/3/3A Thermostat housing Triumph 3
AN6-TX 948 Thermostat Housing Spridgets 11
S TR2/3/3A Bellows thermostat for tr3 Triumph 11
steveg Robertshaw sleeved thermostat Austin Healey 3
mgedit TR2/3/3A Quick Question on Thermostat Triumph 14
S TR2/3/3A used thermostat Triumph 5
B TR6 Which thermostat TR6? Triumph 3
P Overheating after shut down & recommendation on thermostat Austin Healey 3
R correct thermostat Austin Healey 3
steveg Thermostat questions Austin Healey 44
R Thermostat revist Austin Healey 11
T TR2/3/3A How do I remove temp gauge capillary end from thermostat housing on TR3A? Triumph 8
R looking for Moss 363-370, 1500 thermostat housing Spridgets 13
KVH Thermostat Housing Gasket--Must the Sealant Dry? Triumph 3
J TR4/4A TR4a Thermostat Triumph 2
GBT remove thermostat MG 11
K TR2/3/3A Who is running a Sleeved Thermostat in their TR3? Triumph 16
Anthony_S Thermostat Triumph 4
M 99 XJ8 Thermostat Housing Failure Jaguar 0
Skip_Shervington TR2/3/3A TR3A Thermostat Housing Leak Triumph 6
Morris Thermostat vs. Pinging Spridgets 14
R TR4/4A Tr4a, what engine thermostat for San Diego Triumph 9
M Headremoval and thermostat.. Austin Healey 3
R Need more heat - which thermostat MG 15
RJS Thermostat Stuck Open? Triumph 11
Darrell_Walker Wedge TR8 hoses, thermostat, etc Triumph 2
hondo402000 getting rid of my oil cooler, hoses, thermostat Triumph 2
rlich8 TR4/4A TR4A Thermostat Bypass Triumph 5
BugeyeNJ58 Geo Metro Radiator - need thermostat housing Spridgets 10
Westfield_XI What if the thermostat was in upside down? Spridgets 9
D Thermostat Austin Healey 37
T TR2/3/3A TR3 thermostat rating Triumph 4
M T-Series Thermostat Switch Question MG 11
BugeyeNJ58 Thermostat question - is it needed in hot weather? Spridgets 5
