intermittant sputtering follow-up
nevets
Not too long ago I posted a message about sputtering which would start once the car got warm. Following the advice of those who commented, I replaced the coil, condenser, points, rotor, and plugs. The result is the car now feels more responsive, however the sputtering is now not just when the car gets warm but all the time. Plus, when backing off the gas, as in coasting down an incline (in 4th, foot off the gas) I get an occasional backfire, which I assume is unburned fuel igniting from the hot exhaust pipes. And I'll also mention, though I'm sure it's unrelated, the car shifts into OD much faster than previously.
I'm thinking maybe it's one of those rather tired looking skinny wires in the dist, one of which is a ground.
Any help would be appreciated.
Keoke
Well replace it and see,however, new condensers can be worse than partially failed old ones.---Keoke
why
I attacked my missing at higher RPM when hot as a fuel system problem, after new pump etc. etc etc it turned out that in the wire from coil to distributor,at the distributor end, the central wire (actually like a compressed carbon) had burned back a bit into the insulation. 2 minutes to trim insulation, reft end connector, stick it back into distribtor--all better
I think it was on this board that someone said " In old English cars most fuel system problems are electrical"
Jay '65 3000
nevets
nevets
After replacing the condenser again and also replacing the little ground wire inside the dist, the sputering appears to have stopped.
why
Let us all hope and pray the key phrase is not: "appears to have stopped."
As to previous post, the wire that goes into the distributor has little metal fitting at its end which makes the contact with the inner metal piece down in the hole in the distributor. When I pulled that out of the distributor, and took a look at it, the end of the wire was a bit charred, upon taking the metal end fitting off I could see that there was no inner wire, it was burned back about a millimeter up into the insulation. Upon cutting off the insulation, it was not a wire at all but seemingly a fabric-like material impregnated with carbon. I exposed about a 1/4 inch of this material, put the end fitting back on, bending the "wire" back around and up the outside of the insulation, so it was firmly clamped between metal fitting and insulation thus making good contact with metal fitting, stuck it back into distributor hole, and voila, the year long search for misfire at higher rpms when at about 180 deg or higher was no longer present.
nevets
nevets
Thanks for the detailed explanation. Although my problem was of a different nature, the effect was similar. I'm just glad the designers of the AH had the good sense to locate the distributor so that it is very accessible.
TimK
Backfiring on deceleration can result from a poorly sealed manifold to down pipes gaskets which allows air in the exhaust and incompletely burned fuel can ignite more easily. I stopped my problem with new gaskets between manifold and downpipes and tightening the brass nuts.
nevets
nevets
Good point. I'll check the nuts for tightness. Part of the fun in troubleshooting a problem is the sudden appearance of another seemingly related problem, but one which turns out to be totally unrelated. Gets you going round in circles.
nevets
nevets
I took the car out for a fairly long test drive and all seems well, almost. Engine is smooth and strong when accelerating, but when I hold a constant speed it sort of burbles...hard to explain, not a misfire, just not a smooth constant drone from the exhaust. If this was Car-Talk I think I could do a a pretty good vocalization of the sound.
Any thoughts?
BTW, Thanks for all the help with this
GregW
Platinum
Well, if it was a motorcycle, I'd say you were lean on the needle and to shim (raise) it a ½ notch. On a SU, maybe richen the jet slightly.
Patrick67BJ8
Any thoughts?
My first thought: Balance the carbs with a unisun(spelling). With the SU tools in the dash pot and wire arms lined up, rev the engine and observe that they both rise equally and together. Then check the throttle linkage for proper adjustmentfor both carbs(this is critical and most often overlooked.
Patrick
M TR6 Intermittant starting problems Triumph 4
Gordon_Dedrick TR2/3/3A 59 TR3A Intermittant electrical issue, Triumph 5
M intermittant gauges Triumph 3
tr6web TR6 Sputtering help Triumph 6
F TR6 Sputtering at low rpm Triumph 16
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
F TR6 Sputtering along Triumph 14
bugedd Sputtering Spridgets 15
PeterK TR4/4A Stalled project, now sputtering Triumph 3
S BJ8 Sputtering at High Engine Speed and in Overdrive Austin Healey 36
J MGB 69 MGB sputtering problem MG 5
nevets sputtering issue fixed...it was the timing Austin Healey 4
Bremer TR2/3/3A TR3A sputtering after 1 hour of driving Triumph 1
drooartz Sputtering in left hand turns Spridgets 17
nevets sputtering redux Austin Healey 3
nevets Intermittent sputtering Austin Healey 38
K TR2/3/3A TR3A: Occasional sputtering and hesitation? Triumph 4
K TR2/3/3A TR3 Coil + Heat = Misfiring and Sputtering? Triumph 6
TR4A_IRS Sput...Sput...Sputtering? Triumph 19
Shane Fully choked and sputtering Austin Healey 3
Mio Sputtering under load Spridgets 27
U sputtering at start Spridgets 3
Wana UPDATE: Engine Sputtering Austin Healey 2
Don Elliott TR4/4A Sputtering when hot TR3 & TR4 Triumph 29
Luke_Healey Ignition/Sputtering troubleshooting? Spridgets 16
Wana Engine sputtering... Austin Healey 22
H Rough Idle and Sputtering Austin Healey 22
mabbott TR6 73 TR6 Sputtering problem? Triumph 17
wkilleffer Sputtering/backfiring around left-hand turns MG 4
Gray_Cat Sputtering/warmish Running BN1 Austin Healey 2
K ran fine, now sputtering/backfiring at speed MG 8
T TR6 TR6 Sputtering Triumph 12
CARSINC Follow My Spriget Blog As I Complete SpyderMite Spridgets 24
jlaird MGB Follow up to my bad post on prewar MGs MG 4
longbridgehealey Horn question follow up Austin Healey 12
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
P TR6 Follow-up to hard starting Triumph 4
F Follow on questions from HD6 carburetor rebuild Austin Healey 5
drooartz The teardown begins, follow along at home! Spridgets 51
D TR6 Follow-up question Triumph 3
P Follow up to valve job Triumph 3
drooartz MGB Follow along as Drew tears down an MGB engine! MG 21
KVH TR4/4A TR4A OD Follow Up Triumph 10
tahoe healey Gunson colortune follow-up Austin Healey 17
eschneider TR2/3/3A follow up - TR3 broken pushrod &compression test Triumph 1
G follow up question on ZDDP Triumph 12
tahoe healey dizzy follow up Austin Healey 7
KVH TR4/4A Tires and Wheels on a TR4--A follow Up Triumph 9
G Follow-Up Horn Question Triumph 2
