Shane
A couple of weeks ago, I filled up my Healey with gas since the tank was about half full. As I drove home, it started sputtering like it wasn't firing on all six cylinders. I got it home and the following morning, she wouldn't start.
When I turn the key, I can hear the ticking of the fuel pump. When I start the car, it will just crank and crank. Even if I spray ether into the carbs, it just won't fire. I am getting spark, and the pump occasionally clicks to feed more fuel to the carbs as I'm cranking.
Now if I fully choke the carbs, it will start; although it sounds like a tractor. If I let up on the choke even just a little, it will die. I think I have a spare fuel filter around here somewhere that I'll try swapping to see if that's the issue. Although if it was, I don't know why the fuel pump would keep pumping.
Any ideas?
Any ideas?
