KVH
Well, it's running good and for 3 weeks that operating shaft hasn't slipped in the pinch bolt. I think that trick of widening the gap with a file and re-pinching worked. I hope.
Here's a question. The Moss book and my manual show rubber washer-shaped magnets under the metal screen in that huge drain plug for the OD. Moss says it's a set of three.
Are you supposed to use all three, or do you "guestimate" the play and use just one, two or three depending upon clearance? Three seems a bit tight, but I'm curious.
It's a Laycock de Normanville Type A (or something like that).
Thanks.
Thanks.
