installation of soft top instructions?
recordsj
Has anyone come across a good website with instruction in installing a new soft top? Bought a new Robbins soft top for my '74 MG Midget.
Jim_Gruber
Installing a Convertible Top - Steve Byers
NOTE: This procedure was written specifically while installing a top on a '73 Midget, but they can be adapted to other models.
1. Fold the top in half along a line from front to back. This locates the centerline. Mark the location of the centerline at the front and rear of the top with chalk.
2. Put the top in place over the rear fastener locations with the chalk mark lined up with the center hole in the cockpit pinch weld. Place the rear retainer bar in place with its lower edge lined up with the upper edge of the binding material on the top. It helps to have an assistant or two to keep the top properly stretched from side to side and located while you punch the holes for the fasteners in the top material.
3. From the cockpit side, using an awl or icepick through the center fastener hole in the rear cockpit pinch weld, punch through the top material to locate the fastener hole. Ensure that the awl comes out through the center hole in the retainer bar.
4. Install the center snap fastener through the retainer bar, top material, the outer lip of the cockpit rubber seal, and the cockpit pinch weld.
5. Alternating from one side to the other, repeat steps 3 and 4 to install the remaining six snap fasteners along the rear edge of the top, working your way out from the center. Be sure to check that the lower edge of the retainer bar stays aligned with the upper edge of the top binding, as in step 2, before punching the hole for each snap fastener.
6. Position the top material tightly around the curves at the rear corners of the cockpit. Use the Tenax stud holes in the pinch weld to locate the holes in the top for the Tenax fasteners. I preferred to do these one at a time, and alternate from side to side to make sure the top stayed even. The lower edge of the top should be almost touching the little ledge on the body as it goes around the corners. Punch the holes with the awl. Install the Tenax fasteners on the top, and the studs in the cockpit pinch weld, then fasten the top using the Tenax fasteners
7. When all the fasteners are installed at the rear, latch the top frame header rail to the windshield.
8. Determine the center point of the top frame header rail, and mark it with chalk. I used the windshield center rod as a guide.
9. Pull the top tight over the frame and down against the header rail over the windshield, lining up the chalk mark on the top (step 1) with the chalk mark on the header rail (step 8). Have a couple assistants keep the top tight from side to side over the frame. While keeping the top material stretched over the header rail, and feeling the edge of the header rail through the top material, mark a line on the top across its whole width indicating where the edge of the header rail is. Now mark a parallel line 1/2 inch back from the first. At this point, you can erase the first line. (NOTE: what you have just done is allow for 1/2 inch of stretch to make sure the top is tight when finally attached to the header rail and the top is latched)
10. Unlatch the top frame and partially fold it back. Apply contact cement to the outer surface of the header rail and the inner surface of the top material back to the chalk line.
11. After the contact cement sets up, attach the top to the header rail, aligning the chalk line with the edge of the rail. The remaining top material should be folded over the rail and secured with contact cement, trimming any excess as necessary. I preferred to let the material overlap the holes for the seal channel.
12. Now you are ready to install the seal channel and seal. I used self-tapping screws for the seal channel instead of rivets. Probe with the awl through the top material to find the rivet holes in the header rail. This will properly locate the seal channel. The seal has a foot that is stuffed into the channel with a screwdriver (or similar tool).
13. The various snap fasteners for the interior can be located by rubbing chalk on the mating male part on the windshield posts and top frame, stretching the material over the male fastener, and rubbing it to transfer the chalk. Use an awl to punch the holes in the center of the chalk marks. It takes a special tool to install the snap fastener female halves, but they are available and not expensive.
JPSmit
wiki please
JPSmit
sorry - should have been clearer - recently Basil the magnificant put up a WIKI board (like a BCF Wikipedia) it here https://www.britishcarforum.com/tikiwiki/tiki-index.php and is (should be) the repository for information deemed "keepers." Those instructions were keepers and I think should be posted over at the WIKI site /bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
thanks for them
JPSmit
Anyone have a video to put up soft top on MG midget 1979 having a hard time getting last step over wideshielf to latch
How long has it been down? assuming it is vinyl, they tend to shrink - so, if this is the case. put it as up as you can get it and park it in the sun for a couple of hours, then try.
J TR6 Hardtop/Soft Top Installation Triumph 2
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
maxwedge5281 soft top installation for 63 bj7 Austin Healey 1
S Healey BN7 Soft Top installation instructions needed Austin Healey 6
L Soft top installation and acclimation question Spridgets 4
Tronch BT7 soft top installation Austin Healey 0
tr6web TR6 TR6 Soft top installation Triumph 9
A MGB Seat Cover Installation MG 1
Sarastro TR4/4A Convertible top installation problem Triumph 12
D BJ8 Top Installation Detail Austin Healey 3
zoohow BN4 Top Frame Installation Austin Healey 1
R MGB side chrome installation MG 4
P Alternator Installation Pic Austin Healey 4
VeeCee MGB 1974 MGB Roof Installation MG 0
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
Bruce 3000 Rally Grille Installation Austin Healey 5
bighealeysource Master Cylinder Installation Austin Healey 9
kodpkd Disc Brake Pad Installation Austin Healey 11
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
KVH General Tech New Clutch Installation--TR4A Triumph 5
KVH TR4/4A Engine Installation Triumph 28
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
T Kilmartin Adjustable Front Shock Mount Plates - Installation Instructions Austin Healey 0
MGTF1250Dave T-Series Interior Trim Panel installation MG 12
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
WHT BJ8 Transmission Installation Austin Healey 0
Robert Somma power window installation TVR 3
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
nevets Water Pump Installation Austin Healey 9
AUSMHLY BJ8 Driveshaft Installation Austin Healey 10
H 100-6 Interior Installation Austin Healey 4
nichola TR6 Door handle and window crank installation Triumph 0
Cappy Moto-Lita Steering Wheel Installation Austin Healey 3
Walter74 Steering Rod Installation Austin Healey 6
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
S Axle Shaft Installation Difficulty - Help Sought Spridgets 8
D Tri carb: order of installation question. Austin Healey 5
T Ribcase Shift Lever Installation -Bushing Spridgets 1
71TR6 TR2/3/3A Poly Bushing installation Triumph 6
R TR2/3/3A Seat Installation Triumph 13
M Healey back folding shelf installation Austin Healey 1
EWD TR6 Sound/Heat Mat installation - 74 TR6 Triumph 14
R TR2/3/3A Overdrive wiring installation Triumph 14
R TR2/3/3A Pic of installation of ground strap-TR-2 Triumph 2
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
Healey Nut Heater Box Installation Austin Healey 4
Marvin Gruber BJ7 Top Installation Austin Healey 1
Lin Healey assembly line - engine installation Austin Healey 19
B BT7 Door Seal Installation Austin Healey 13
