I'm worse than a five year old I swear
G
So my mechanic called up today.
I had arranged to go up to his shop tomorrow to take him the tank I had made, and the radiator with the oil cooler installed - it looks really nice btw.
He tells me that the axle shafts I've been waiting for since Dec arrived this morning. His two quotes are "they are powdercoated" and "they look really good". He also tells me that I'm going to have to modify the adapter plates on the R200 - the studs need to be cut off and drilled out to make holes to match the stock diff pattern.
Now I'm jumping around and twitching like a little child the night before xmas. I want it to be tomorrow so I can go see my car. Pretty sad, no?
VitSport6
No...Not sad at all, Merry Christmas!
Good luck tonight /ubbthreads/images/graemlins/wink.gif
Banjo
I know exactly what you're going through.
Read "AAAUUUGGGHHH" in the Pub forum.
Keep sane!
Banjo
Well Alan, My tomorrow was yesterday, so I can return the sentiment now.
May sleep come easily, so the dawn comes quickly.
Deleted member 3577
[ QUOTE ]
modify the adapter
[/ QUOTE ]
So that would be a "custom modified adapter" /ubbthreads/images/graemlins/grin.gif
Like a OE part's 2nd cousin?
G
Something like that.
I will finally know if they were worth waiting for though.
DNK
Alan- I thought it was suppose to be a bolt on.
don
LastDeadLast
The Nissan diff requires that the output flanges be redrilled to accept the TR axle bolt pattern. Same for the input flange too. Richard will do this for you if you buy the diff from him, but you need to handle this yourself, if you purchase the diff on your own.
G
The output flanges on the R200 I got from Richard G. had adapter plates with studs welded in to match the TR bolt pattern. You just shove them through the holes in the halfshafts and bolt up.
The new halfshafts don't have enough clearance to accept these studs - they were designed to cope with the ORIGINAL diff - which as you remember had another set of four holes and was bolted to the halfshaft flange with four small bolts. The guy who made these said he provided hex head bolts that go through the other way (heads facing you as you look inward).
It'll be a lot easier to explain when I have a picture of it - it would be a direct bolt in if the studs on the adapter plates hadn't been welded into place. Now they just have to be cut off and holes drilled where they were. They unbolt from the diff so its not such a big deal.
It will be bolt in if you have an original diff though. I'll grab a camera before I head on up there and snap some pictures.
S Pre-War my hood problem got worse! Triumph 6
TomMull Is a poor restoration worse than no restoration Restoration & Tools 4
M Are these seat frames worse than they look Spridgets 7
RickB LBC things could be worse - I suppose... Spridgets 14
TR6oldtimer Worse and best job in a TR factory Triumph 11
Brosky I guess I could say, it could have been worse Triumph 85
Dadandson Missing and getting worse Spridgets 17
G Clanking noise is getting worse on startup..... Triumph 25
G And to make matters worse..... Triumph 4
S I'm making it WORSE! HELP! Triumph 15
A Clutch or Worse? Austin Healey 3
Ed Sweeney Whats worse: Wiring woes or bodywork blunders? MG 15
L General MG Five speed MG 6
Michael Oritt Smitty's Five-Speed Manual Austin Healey 1
WHT Tremec T-5 Five-Speed Transmission Austin Healey 39
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
AngliaGT Went to West Virginia Today [For about five minutes] Spridgets 2
P For Sale Five 6.50-13 Bias ply US Royal Safety 800 tires for sale Spridgets Classified 0
S Five Years Ago Today... Spridgets 7
HealeyRick Bugeye on Hawaii Five-0 Spridgets 0
JPSmit Question five Spridgets 20
catfood Saw five iteresting vehicles on the way home last night.. Spotted 3
R_Lyle TR6 Drain the fuel tank - five year old gas? Triumph 4
S TR6 I'm back!!! As of five hours ago, I'm again a TR owner! Triumph 14
B TR2/3/3A 1957 TR3/ Minor detail questions Part Five Triumph 15
W For the first time in five years... Spridgets 9
Brosky From Hagerty - Five affordable cars to buy now Triumph 11
N Five speed query? Spridgets 4
N Five speed tranny's!!!!! Spridgets 10
T Five MG's on Craig's List MG 4
T Wedge TR8 five bolt wheels and hub Triumph 5
mrdibbles Set of Five Austin Healey 3000 Disc Wheels Austin Healey 5
T top five "watch for this" list Austin Healey 6
R Lug Nuts for Riley One-Point-Five Restoration & Tools 1
LeeMcKee TR6 TR6 Five Speed Conversion? Triumph 5
R five-bolt wire wheels Austin Healey 2
vping Riley One Point Five Other British Cars 20
vping Riley One Point Five Other British Cars 3
vping Riley one point Five Spridgets 2
J Five Speed Trans. MG 8
S Rivergate Five Speed Conversion Spridgets 6
B Spotted: 1956 Series I, 107" Five Door For Sale Rover / Land Rover 1
S Sixty-Five Big Ones Austin Healey 3
mctriumph TR2/3/3A Old trick on SU's Triumph 5
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
K TR2/3/3A Old school battery shut off switch....... Triumph 3
S TR2/3/3A old 4 bolt axle set up Triumph 12
K TR2/3/3A Old school penetrating oil? Triumph 24
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
S TR2/3/3A old 4 bolt axle differential. Triumph 11
