If working on MG's were reality based TV shows....
Then I "appeared" on two last night:
"This American's Got Talent" and "Dancing With Little Britsh Cars"
My "dances" were the Bellhousing Ballet and the Starter Samba. I, along with my helpers "Me" and "Myself", got the engine back in the B, slipped onto the input shaft and snugged up to the tranny. I also got the starter into position; that bugger doesn't want to come out unaided when the engine is bolted down! LoL :smile:
Now I just have to put all the various bolts and such back - in the right places - without ending up with left-overs!!
Deleted member 8987
If working on LBC's was a reality show....it would burn out the Network "bleeper".
RickB
If you don't have extra bits left over after finishing you're not doing it right.
These cars were greatly over engineered you know... :wink:
:devilgrin:
S
:lol: :lol: :lol:
JPSmit
I'd have been kicked off the island :crazyeyes:
Platinum
If you ain't done it three times, you ain't done it at all... :devilgrin:
JPSmit
amen to that - I restored mine at least three times at once, with the added bonus that if you take something (like a carb) apart and reassemble enough times, eventually you end up with two.
S
That falls in the same category as "There's never enough time to do it right the first time, but there's always enough time to do it twice." :smile:
JPSmit
true though honestly, mine tends to fall into the category of "It takes me two or three times to get it right."
D Trying to get back working on the 1974 Midget Spridgets 11
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A my OD stopped working after it was working Triumph 25
D TR2/3/3A Traffic at or and horn button not working Triumph 2
tr6nitjulius For Sale TR6 working/clean parts 4sale Triumph Classifieds 0
O Spitfire Tail lights not working Triumph 6
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
Celtic 77 MGB Non working tach. MG 4
M Tachometer not working following ignition upgrade Austin Healey 10
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
KVH General Tech Speedometer Not Working Triumph 5
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
S TR2/3/3A Speed O not working Triumph 27
M Wiper Motor Problem Not Working Spridgets 5
TRclassic3 TR4/4A A type OD working in 3rd but not in 4th Triumph 5
W Healey 100 Overdrive stopped working Austin Healey 15
1 MGB Lights not working MG 11
A MGA High beam indicator light not working MG 2
1 MGB Speedometer and tachometer on '66 MGB are not working MG 8
2billydavies TR2/3/3A generator doesn't appear to be working Triumph 7
Airwave BJ8 overdrive stops working after a while driving Austin Healey 17
warwick-steve Direction indicators not working Austin Healey 29
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
Jim_Gruber Brake Light - Getting them working Spridgets 8
Superwrench Tach not working Austin Healey 6
M TR2/3/3A Panel lights not working........ Triumph 5
Rhodyspit75 Working on the Bugeye body Spridgets 19
J General TR D Type overdrive not working need suggestions Triumph 5
J Helping out some students working on a 59 bugeye Spridgets 6
R Master Cylinder change working Austin Healey 12
F Overdrive - working but not really working Austin Healey 14
T TR2/3/3A Air dam seems to be working very well Triumph 5
BN6_2197 BN6 brakes not working properly Austin Healey 9
bugedd Fuel guage not working Spridgets 7
Nelson Working under the car Spridgets 5
T Horn and rear right indicator stopped working...head scratch imminent Austin Healey 16
R Choke Not Working In Cool Weather Austin Healey 15
D new mecahnical fuel pump not working Spridgets 8
Gerry M TR6 Speedo stopped working Triumph 6
DanLewis Looking for an old-style fuel gauge [working or not] Spridgets 3
P I need a non-working electric tachometer for parts Spridgets 0
DerekJ Left side indicators not working. Austin Healey 3
G MGB STILL working on clutch slave MG 37
bigbadbluetr6 TR6 Rear tail lights not working. Triumph 17
J Funniest thing you found working on your car Austin Healey 32
B Horn Quit Working Austin Healey 14
D TR6 Blower working! Triumph 3
