I think I have a screw loose!!!!!
77_MG_Midget
I need to replace the screws that mount the handbrake assembly to the body mount (see pic). The screw is a countersunk phillips head machine screw, 8MM x 1.0 x 25mm (fine thread 8mm, 1" long). NOBODY seems to have these. Not British Tools and Fasteners or Bolt Depot. Certainly no one locally here in Las Vegas. Does anyone know where I may get these or what may be able to be substituted. I know a 5/16 SAE, fine thread is close, but really not a perfect match. I'm at a real loss... /ubbthreads/images/graemlins/confused.gif
Platinum
Only suggestion that comes to mind is Wurth fasteners. But they usually don't sell -one- of anything. Is there a shop in your area that services Euro cars? Check with them... Ooohh!! There's the "museum" near you. They *restore* cars. Go chat up somebody there!
sparkydave
I had to replace those too, and they are a pain to locate. I wasn't going for originality and used a countersunk fine thread machine screw from Home Depot. Since the head wasn't completely flat but slightly rounded I had to use a Dremel to flatten the top so it would clear the handbrake lever. The screwdriver still fits though, so no biggie.
The bolts holding the bracket onto the body were a pain too; a couple of the captive nuts on the inside of the tunnel had snapped off, so it took some patience with a hacksaw blade to remove those. I just used regular nuts with the breaker bar shoved in from the front to hold them.
CK_1500
It's been a while since I've had the handbrake lever out, but I don't remember anything on my car being metric (except now for the repro ignition solenoid, but that's another story.)
That said, even McMaster Carr only showns 1.25mm pitch in 8mm machine screws, so they're no help either.
Sorry I couldn't be more help...
-=Chris
RobSelina
yea, I don't see that spec being very likely. Are you sure it's metric? 5/16" fine thread seems much more likely....
Do you have a 5/16" tap? You could certainly make it 5/16" fine thread very easily /ubbthreads/images/graemlins/laugh.gif
sparkydave
Come to think of it, didn't the countersunk screws have separate nuts, and not captive ones? I seem to remember just getting nuts that matched the screws I bought (5/16" fine thread). Yes, someday I may be referred to as the DPO because I have a mixture of bolts and screws with threads that are different from what BL used. :p Usually I was more concerned with keeping things attached than originality, and it has had its share of captive nuts snapping off or bolts shearing off.
jlaird
Nuts are not captive.
sparkydave
Sorry Jack, I think I misunderstood your reply. My guess is you were referring to the nuts on the handbrake, and not nuts in general. My bad.
Morris
At my local Lowe's there is this amazing rack of trays that has all kinds of crazy and unexpected fasteners. If you have not checked there, it may be worth a trip.
BTW, most everything on your car should be SAE. Does the 5/16 24 seem loose or tight? It may just be an issue of worn or rusty threads.
Platinum
Because I can't recall Spridget spec's "off the top" it seems strange to have metric threads there (or anywhere) on an LBC. But because of the time it was built I figured it was possibly what they used. Earlier cars were decidedly SAE.
77_MG_Midget
77_MG_Midget
[ QUOTE ]
[/ QUOTE ]
Thanks everyone for replying. Yes, all nuts are captive on the handbrake assembly. I haven't tried the 5/16 x 24 machine screw. I just used a thread pitch gauge to determine what type of threads they are. The SAE didn't seem to be exact, where the 1.00 MM pitch gauge seemed to be right on. Maybe I read it wrong. Anyway, I've looked at Lowes, Home Depot and the local true value (who has a great selection of weird nuts, bolts, etc). All have the 8MM x 1.25 (course thread metric), but not the 1.00 (fine thread metric). So maybe there's no choice but to try the 5/16 x 24.
I didn't give a 5/16 x 24 machine screw a try because I didn't think it was correct. But if others have used it, then sounds like that's my ticket. I'm not restoring to total stock, so being the "original" machine screw is not important to me. I was more worried about the screw backing out if I used SAE instead of Metric.
So hard to tell with the '77s. There's such a mix of SAE and metric, you don't know what your going to find.
jlaird
mine are not captive. shrug
Morris
Early in my days of Midgeteering (aka about a year ago), I mistook quite a few 5/16 24's for M 8 X 1.0. At that time I assumed that becuase my car was Euro it was metric. Oops!
Consequently, if I ever sell my car to one of you guys, you are going to need a few metric tools...
Bugeye58
An M8x 1.0 has 25.4 threads to the inch, and is commonly mistaken for a 5/16 x 24, by people who think that since it's a European car, it has to be metric.
Jeff
Platinum
Add to that the English were more err... *headstrong* over the "conversion" to The Metric System than we were, and there would be no way an LBC would have metric fasteners on it. I just could NOT be certain. I hate getting OLD. 5/16 NF. No metrics.
Thankyewverymuch, Jeff. /ubbthreads/images/graemlins/england.gif
77_MG_Midget
77_MG_Midget
[ QUOTE ]
[/ QUOTE ] /ubbthreads/images/graemlins/lol.gif And that would be me for one...
CCURTISS T-Series MGTC Door Latch Backing Plate [screw loose] MG 0
nevets Condenser Securing Screw Austin Healey 14
B Surprise screw head Restoration & Tools 0
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
G HD8 Idle Adjust Screw Austin Healey 10
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
R Grille Top Cowl Screw Austin Healey 7
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
C Size or matching screw on cap for Trafalgar bottle? Austin Healey 0
T C42 BJ8 generator long screw needed Austin Healey 2
C TR6 ZS 175 What does this screw do? Triumph 2
JimLaney Rocker shaft plug/screw delima Spridgets 3
Jim_Gruber BE Quiz for Today - Beehive front Turn Signals take a ? possibly 6/32 screw Spridgets 1
Jim_Gruber BE Quiz for Today - Beehive front Turn Signals take a ? possibly 6/32 screw Spridgets 2
S T-Series screw size MG 0
Jim_Gruber Did I find another need for a Whitworth Wrench Set/ Did I screw up intake manifold Spridgets 5
M TR2/3/3A Where does this screw go? Triumph 6
B Rear Seats - Do I have to drill screw holes through the brand new leather upholstery? Austin Healey 13
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
Joe Reed General Tech Starting a screw in a tight location... MG 9
CJD TR2/3/3A Screw Post Coils Triumph 6
cmacmillan TR6 metering needle - no longer in a relationship with adjustment screw... Triumph 9
J SU HD6 - Slow Idle Screw Austin Healey 13
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
G Lens screw for AH 3000 BJ8 Austin Healey 1
R TR4/4A Assembling the interior - dash support and radio plate screw holes don't match up Triumph 4
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
Geo Hahn TR2/3/3A Steering Box Adjusting Screw Triumph 12
P Fuel Float to tank bolts [machine screw] size?????? Spridgets 1
P BJ 8 broken hood frame screw Austin Healey 6
tinman58 TR5/TR250 Did I screw up? Triumph 4
Brooklands TR2/3/3A Set Screw Triumph 6
K TR2/3/3A Proper size of "set screw/bolt?" for top of trans..... Triumph 1
B TR2/3/3A anyone help me identify the screw attaching seat slide to the floor? Triumph 8
CanberraBJ8 screw size for window bracket? Austin Healey 3
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
GBRandy Wedge TR8 AF Screw Triumph 1
A TR2/3/3A TR-3A Trunk handle screw Triumph 10
S TR2/3/3A little adjusting screw tr3 Triumph 1
Gliderman8 Removing stubborn screw Restoration & Tools 22
H Side marker lens retaining screw Triumph 6
NutmegCT TR2/3/3A TR3 hard top screw Triumph 5
wangdango '96 XJR reversed battery charge screw up... Jaguar 2
sparkydave Rear view mirror set screw Spridgets 0
W How big a screw up? Spridgets 5
S Austin Healey 100 6 screw list Austin Healey 6
L Stripped windshield frame screw hole Spridgets 6
K TR2/3/3A TR3A Windshield Stanchion Screw Removal? Triumph 8
J Windshield pillar to windshield frame screw size? Spridgets 2
