How to tell when you are not using your car enough
G
When you go into the garage and find that your wife has been using it for storage.
I need to get out and drive this thing....
Brosky
Re: How to tell when you are not using your car en
When your paint starts to turn red and you smell raw gas......
Platinum
I thought it rather cruel, meself.
...but fair. /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
T
Tinster
Yeah well............Paul /bcforum/images/%%GRAEMLIN_URL%%/savewave.gif
My "car shop" measures 8' wide by 18' long.
Everyone knows the fine painting skills acquired by
ole Tinster during the Crypt Car ordeal. So I've
gotten real good with Harris paint stripper and Eastwood
rust primer.
Red with gas fumes, you say huh??
I'm having some thoughts to giving Amos a new outfit to
wear.... just soz no one might mistake him for Crypty.
The boys at the custom paint shop claim they can duplicate
exactly a certain Mimosa yellow, even from an internet
photo. $110 a quart. How many quarts it take to paint
a TR6?
Amos the Mimosa Boricua TR6. I'd hafta git me some gansta
wheels in that case.
/bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif dale todo corazon
tomshobby
photo.
Dale, you could then call Paul's Senior and your's Junior! /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
T
Tinster
Well Tom,
Maybe or maybe not. Depends on how you define senior.
Amos will be powered by a TR250 engine block.
So far, that TR250 block is the only component
of Crypty that has not broken down or blown up.
So Amos will have a power plant Senior to the other Mimosa.
I'm an old dude, far Senior in years to the upstart
youngster who is raggin' on poor cryppled Crypty.
Hummmmm- I've got part of the engine bay stripped to metal
and primed with Eastwood. Now is it worth $110. to try a
test patch in Mimosa? ( je,je,je- while Wendy's in Colorado
visiting friends!!) /bcforum/images/%%GRAEMLIN_URL%%/nonono.gif
DNK
Dale- What did you use for your fuse panel container?
Platinum
TUPPERWARE!?!?
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] TUPPERWARE!?!?[/QUOTE]
Doc, you talk about me being cruel????
Sorry Dale, I just couldn't pass it up. Especially with your "up on jack stands" signature.
Actually, Amos would look rather handsome in Mimosa, but you'll have to order the Chestnut interior to make a matched set.....
You will notice that I referred to Amos, as I shall in all future communications regarding the fine red TR6 restoration in Puerto Rico. However, Pedro will still be DPO Pedro, because no amount of good will can ever change that.
Brosky
Dale, I wish that I had the time to do what you're doing with the car. I don't want any of the work, just the time.
Platinum
/bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
toysrrus
Hi There Tinster;
In My Opinion, (I`m not a Body Guy), The "ONLY" way to get a Perfect or as Close as possible to the Orig. Paint is to have the Paint Scanned:
I cannot see any way someone can realistically tell You that they could match a Paint even from an "Internet Photo"! "NO WAY JOZE`"! How do you right that Phonetically?
Anyways; That`s My $.02:
See Ya Later;
Regards, Russ
T
Tinster
Power Block Cover box-
Eventually I'll design and build a proper Lucite
box with hinges and gasket.
For now, I need protection from the volcano ash and
the Sahara desert dust we get every summer during
hurricane season.
Tupperware?
Nah. What's my hobby? Fishing. That there's a waterproof,
floating, artificial lure box with gaskets and locking lid.
I removed the interior seperators and then I cut a portion
of the end and a bit of the bottom out for the wires to escape.
It is functional- maybe not beautiful but functional.
Kinda like it's owner, ha, ha.
No TR parts arrived so I'm spending the weekend working
on that pesky master bathroom sink leak for Wendy. Getting
near to a solution.
Tupperware in Puerto Rico? Ya never know. I saw a Fuller
Brush man truck the other day.
d
Platinum
I'm certain Paul has a paint code to give Dale. But the thought of a complete colour change is kinda radical. Better part of a gallon for top coat, but the red ideally should be stripped and the body done with a good epoxy high solids primer before that... waay too expensive & time consuming...
Just my opinion.
roofman
Once you burp that Tupperware it makes quite the air tight seal.
T
Tinster
Russ/Dr:
Go put on a pair of long pants and see if
one cuff seems a bit higher up yer shin than
normal.
Your leg's been pulled!
All hidden evidence I can find indicates red
was the factory installed color. Red it will stay.
And like YEAH! A paint change is gonna happen any time
soon. Wendy's gonna spring $8k or so to repaint
my non-running TR6. Not even in my dreams.
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
L Can anyone tell me what car this is from please? Other Cars 0
jlaird Just may be the new Miss. Agatha. Sat will tell, only 37 miles away. Spridgets 26
TomMull Why didn't somebody tell me about this before Restoration & Tools 5
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
J anybody tell me why this thread closed? Austin Healey 4
matmire Curious if these photos tell you anything about my car. Spridgets 24
Boink You tell me... Spotted 3
D Bumpers and over riders, How do i tell if they are replacement or not Austin Healey 5
J How can I tell if I have a negative ground tach? Austin Healey 5
J How can I tell Austin Healey 1
T TR2/3/3A Can someone tell me height of roll bar that will allow soft top on TR3A? Triumph 3
JPSmit Viva GT show and tell - and a question Other British Cars 4
M gotta tell somebody Spridgets 10
J How to tell if your car is from the South... Spridgets 15
rkep01 How to tell if lever shocks need rebuilding? Spridgets 3
I How can you tell if a transmission is good? Spridgets 2
S Oh the stories this car could tell! Jaguar 1
M Tell me I need a fuel tank sending unit Spridgets 21
jlaird Miss Agatha was trying to tell me something Spridgets 4
I How can you tell if a starter is good? Spridgets 6
T How tell if gear reduction start fits is right? Triumph 2
R Austin but can some tell me what model, please? Spotted 5
I Can someone tell me what these are? Spridgets 12
drooartz Manifold vs carb vacuum - how to tell? Spridgets 18
T Why don't you guys tell me this stuff ;-] Triumph 10
F Compression test: What does it tell me Spridgets 6
T How tell if wire wheels are good? Triumph 7
T Can you tell what kind of car this is Triumph 9
R How do you tell if a rim is bent or warped Spridgets 1
T How tell if a used radiator is good Triumph 14
R Tell me this is not a big deal Spridgets 7
bighealeysource How can I tell if the polarity has been changed on Austin Healey 20
DrEntropy We're havin fun NOW I tell ya!! MG 26
JPSmit Show & Tell - tonites craft, luggage straps Spridgets 11
JPSmit Show and Tell - new carpet & progress Spridgets 44
RickB 5 speed trans, please look & tell me it is the one Spridgets 13
theleisure Silicone or Synthetic, How to Tell Spridgets 5
CCURTISS How to tell if paint is Enamel or Lacquer??? Restoration & Tools 7
I How can you really tell how old a tire is? Triumph 22
bthompson My turn for Show and Tell! Spridgets 12
kodanja Tell your worst TR horror story! Triumph 45
T Quick - tell me about your TR driving big miles Triumph 25
mrdibbles How to tell what year your Healey is? Austin Healey 14
58Custom How to tell diff btwn 1275 speedo & 1500 speedo? Spridgets 13
R Don't tell me I have to pull the *&%!#engine again Spridgets 13
AngliaGT How to Tell if an OD Trans MG 2
tomshobby show-n-tell Triumph 8
