how do you clean
walshja
the mess after hitting the grease spots with grease?
i found 6 spots on the front suspension to grease, 3 on the left and 3 on the right
i was hoping this would eliminate a squeaky front end I have. while it seemed to help on the right side of the car, I still have a loud squeak on the left side
but in hitting the grease spots I found I created quite a mess, there's grease all over the nipples, and where the grease oozed out. there's a huge mess, that I can't seem to get clean.
anyone have a trick? how do I get all that grease cleaned up?
joe
RickB
If anything I just use a paper towel & wipe off excess.
I'm not running a surgical unit or anything under there though. :wink:
jlaird
Wipe off what you can with a dry paper towel then hit it with carb cleaner and wipe off the rest then a spray grease remover like 409 or something for the final touch.
I know, that's overkill but I hate to get my hands dirty when working on Miss Agatha.
walshja
walshja
well, I had been just trying to wipe it off, but like Jack, I hate getting dirty when working on the car.
so it's OK to spray cleaner products in there? it won't seep into to fitting and take out what I just pumped in?
I shall give it a try !!
thanks for your tips.
joe
RickB
Ever hear of gloves? Vinyl gloves?
For me I just keep a jug of that citrus smelling hand cleaner in each car and another in the bathroom.
To each his own :laugh:
jlaird
Don't need a lot of cleaner to get the grease off unless.............use the cleaner stuff, re greese and remove excess with paper towels. Go on to the next area.
About getting in the fittings, don't use that much. Just enough to cut the film.
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
tr6nitjulius For Sale TR6 working/clean parts 4sale Triumph Classifieds 0
Basil Easy way to clean fuel injectors (out of car) Other British Cars 2
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
T How do I clean sand out of a ring & pinion? Spridgets 2
BoyRacer How to clean a cloth wiring harness Austin Healey 14
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
JimLaney Media blasting engine parts - How to clean? Spridgets 5
D TR2/3/3A Exhaust manifold clean up. Triumph 6
I General TR Mold clean up suggestions Triumph 4
S TR2/3/3A overdrive transmission, cosmetically clean Triumph 12
R General TR Best way to clean unpainted parts Triumph 1
jaegzie Cylinder wall has some build up. Need to clean. Spridgets 4
NutmegCT Cooling system clean/flush Restoration & Tools 11
T TR2/3/3A Is there a way to take apart and clean/repair TR3A headlight dimmer switch? Triumph 8
nevets How to clean a E Z Bleed ? Restoration & Tools 11
C How to clean a Lucas Headlight? Restoration & Tools 5
R did a little clean up today Triumph 5
D Best Way to Clean Corrosion on Fuse Clips. Jaguar 3
Darrell_Walker Fuel tank - just clean, or clean and seal? Triumph 15
bighealeysource How to clean aluminum shut face finishers ? Austin Healey 9
T silcone clean up Triumph 9
Moseso Mini ! Clean! Also, heavily customized ! Spotted 2
bighealeysource How to clean up rear backlight on factory hardtop Austin Healey 11
BugeyeNJ58 Garage Clean Out-1100 Engine and 4-speed Trans. Spridgets 5
K TR2/3/3A Best way to clean TR3 Bakelite horn button? Triumph 8
Rut Transmission clean up Restoration & Tools 5
W Garage clean up Spridgets 0
S Very clean 1970 Morris Minor Woody on eBay Other British Cars 6
J Paint help! [I've got a mess to clean up] Triumph 9
D Wire wheel clean prior to paint MG 1
ekamm Clean looking sedan on Eastcoast Triumph 0
M What's the best way to clean off under-gunk? Spridgets 10
T best way to clean a canvass top? Triumph 4
T Working with clean parts is soooo very nice Triumph 19
SilentUnicorn How not to clean a motorcycle chain British Motorbikes 6
tmc Clean the gas tank or buy a new one? Triumph 8
J what should I use to clean 30yr old vinyl? Triumph 6
T Radius arm clean-up and bushings Spridgets 7
B Time to go racing again - seeking clean Spridget Racing 32
T 30 minutes of clean up and much better Triumph 19
T MGB-GT Clean MGBGT cheap on BMW forum MG 5
T How should I clean my diff now that it is out..... Triumph 9
P Clean behind the Grill on a 100 Austin Healey 3
jjbunn Calipers! How to clean and install? Triumph 7
boeingpilot Brake Rotor Clean Up Restoration & Tools 4
RickB To clean old tarnish off replacement fuse box? Spridgets 10
tosoutherncars Armstrong lever-arm dampeners - clean & replace Spridgets 6
regularman The clean up Spridgets 0
