Home Made Leakdown tester
Morris
Check out my ugly but functional leakdown tester. Total cost: roughly $30.00.
According to my tests, I have a bad intake valve on #1 and bad rings on #s 1, 2 and 4.
Number #3 was strong. A drop of only 2-3 pounds. The rest dropped 20-30 pounds. Would being off true TDC cause these results?
jlaird
For the mentaly impared how about a few details on that rig?
drooartz
I'm at a loss too (my fault) as all I see is an air hose with a spark plug welded on, and a pressure gauge. Of course, I haven't the faintest idea of how a leak down test works. Always nice to start off the year feeling a bit lost. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
jlaird
He must have a Y or a T on that gage.
Morris
Morris
That's the article I based my rig on. The air compressor I used already had a pressure reg and line gauge, so I was able to eliminate those parts (though they had them at Lowe's for @ $13). I did not go the grease hose route because it would have necessitated buying a pipe thread tap. And also, welding is a lot more fun than tapping thread.
drooartz
Thanks for that link, Jeff. I think I understand now...
Bugeye58
Glad it helped, Drew. it's a simple concept, and much more precise than a simple compression test.
I'll get the hub puller in the mail tomorrow, by the way.
Jeff
drooartz
Can you do such a test on an engine that's been pulled and is missing carbs/exhaust? Might be nice to test the 1275 I've got sitting on my floor if it was possible.
Thanks again for sending out the puller.
Bugeye58
Sure you can test an engine like that. It's actually a bit easier to do with the carbs and exhaust off. It makes it easier to listen at the ports. Also easier to rotate the engine with the crank nut accessible.
As always, make sure the piston for whichever cylinder you are testing is at TDC on a compression stroke. If it's a little off, the air pressure may force it back down in the cylinder. I usually leave the breaker bar on the crank bolt, or otherwise lock the crank to prevent that from happening.
Jeff
Dave Russell
Yoda - R.I.P
Jeff
Hi Jeff,
Good stuff. As you likely know, recip aircraft engines are rigorously tested in this manner. For aircraft engines, there are prescribed calibrated restrictor orifices to match the cylinder displacement. This gives an actual calibrated leakage reading that can be compared to the particular engine specs. The .040" diameter restrictor mentioned is a pretty good compromise for most engines. Sometimes, more elaborate testers use two pressure gages, but the single gage is usually more than adequate.
For folks who don't wish to be confused by a reverse reading pressure gage, or go to the trouble to make a new reversed dial face, the Moroso gage can be had for a bit more money.
https://www.pegasusautoracing.com/productdetails.asp?RecId=844
You are correct, the sparkplug end of a higher end (screw in type) compression tester works very well. It has a quick disconnect & numerous plug adapters. With the quick disconnect, it's very easy to set the pressure regulator to exactly full scale on the gage & then connect to the cylinder adapter hose.
I also agree, problems further down the cylinder can be checked, but as you say, once the piston is off TDC, the crankshaft must be securely held in position against air pressure.
I have also found the part about a speck of carbon under a valve causing leakage more than once.
Good thread, all of it. It gives far more information about engine condition & the location of problems which can not be done with the engine disassembled.
GB1
Nice Improv Tool. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Here's what I have, it cost 89.95, probably about 10 years ago, if it blew apart today, I got my money's worth.
JerryB
""""", it cost 89.95, probably about 10 years ago"""
What happend...blew apart....did a gage blow?
Matco stuff of the truck is a lot pricier now.
Tavia (tavia.com) makes a very nice dual gage piece. They have moved to Florida about 4 years ago as Tom got tired of sunny So Cal.
He also makes a really nice bolt stretch gage that is priced rite and reads to .0001"
They have an engine builder deal.....
Bugeye58
Jerry, I can't remember if my leakdown tester is a Tavia or a Longacre, but it's essentially the same as Haps. I think around 85 bucks, or so, about the same time frame as Hap.
I've also got a Tavia bolt stretch gauge, and a valve spring rate tester that have served me well.
Jeff
AngliaGT Miata - ALMOST Made it Home Other Cars 7
RAC68 Home Made Healey Exhaust Headers from a BOX Austin Healey 15
wangdango Home-made ducting for BJ8 radiator? Austin Healey 11
JPSmit Land Rover Defender - and Home made special Spotted 1
Xte TIPS : Home made tool for the thermal sensor Austin Healey 7
JPSmit Home made axle puller Restoration & Tools 5
RickB Well my Midget made it home... Need Help! Spridgets 80
hondo402000 TR6 TR6 fan shroud, home made Triumph 7
Tabcon Home made sway bars. Racing 23
tweety Home made heater valve will it hold...... Spridgets 3
Trevor Jessie I made it home from the lake of the Ozarks... Spridgets 28
G Is this a home made valance guard? Triumph 7
W Home-made tonneau - has anyone tried? Triumph 15
JPSmit Home Made Rotisserie - I'm sooooo Happy Spridgets 15
simpzimmer Made it home: brakes Triumph 5
MattP Hooray! I made it home. MG 5
Patton The car made it home for it's birthday Austin Healey 2
philman Wedge TR7 finally made it home Triumph 7
Hamish Racing TR2/3/3A Aintree sprint (uk) home to the British GP Iain 1950’s Triumph 0
R TR6 I just brought this to its new home. It has been stored for 15 years, has only 21000 miles , and only 1000 sincw Triumph 12
AngliaGT Saw This When We Got Home Today Spotted 3
JPSmit Ms Triss is home again. Spridgets 12
drooartz Carried home on my shield... again Spridgets 17
7 General TR Its home! Triumph 7
R The long road home Spridgets 1
Basil TR2/3/3A On my way home from town - spotted this Triumph 9
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
JPSmit Ms. Triss is home! Spridgets 12
Lin A little "Stay-at-Home" Healey Nostalgia Austin Healey 10
JimLaney For Sale 2 MK IIIs :Free to good Home Spridgets Classified 1
S TR2/3/3A TR3 clutch release bearing... from Home Depot? Triumph 12
Joe Schlosser Wire wheel Parts Free to good home Spridgets 0
Jim_Gruber Drove Bugsy home this AM Spridgets 15
waltesefalcon It's home! Other Cars 9
drooartz MGB Engine on the hoof - parts car comes home MG 8
JPSmit Home from Boarding School! Spridgets 11
D TR2/3/3A Home Again! Triumph 12
steveg HD8s easily rebuilt at home Austin Healey 4
drooartz Penny the Bugeye in her new home Spridgets 39
R Prepping to bring my 100 home Austin Healey 5
NutmegCT T-Series New home for an old TD MG 30
Jim_Gruber Bugsy II - Left for a new home this morning Spridgets 4
Marla TR4/4A Take the long way home Triumph 11
drooartz MGB An old friend comes home - I have an MGB again MG 27
Keith_M Look what came home Spridgets 14
steveg Odd problem but it got me home! Austin Healey 9
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
JPSmit Ms Triss is coming home today Spridgets 7
Bob McElwee Miss BT has a new home [probably a new name too!] Austin Healey 1
Mickey Richaud T-Series Home, James MG 4
