G
I finally installed the throttle cable on my triple setup and "improved" engine and can finally capture that last 10% of power that I was losing with the modified stock mechanical linkage. I just wasn't able to get full throttle with the slop in the hard throttle linkage and the cable gives me essentially 100% capacity. That's scary....now I do need better brakes. I modified the cable setup a bit by moving the carb bracket to between the 1st and 2nd carbs. Had to move the lever arm on the throttle shaft from the middle to the first carb. Same effect but now no binding in the cable. Notice I pulled the shielded cable away from the header with a stainless steel cable tie. Also had to modify the firewall bracket to clear a heater hose. Otherwise, a clean install. I am really having a hard time keeping my foot out of the carbs.....just when premium is $3.50 a gallon!
Bill
Bill
