Holy cow I think it worked [Bugeye compression]
tdskip
Hi folks. So I broke in the compression gauge (new tool - sweet!) as I'm starting to try and figure out exactly why she is smoking.
I got the following 1-140, 2-120, 3-130, 4-130. Cylinder 4 has a normal plug coloration, but 1-3 are oily black.
Do I need to do a wet test to get more data to diagnose?
This is a continuation of the following original thread; https://www.britishcarforum.com/ubbthread...p;page=2#218834
RobSelina
Re: Bugeye compression results
20 psi is a pretty big fluctuation. I'd get the engine warm, then do this test again. Once you do it 'dry', if you still have a pretty wide spread, I'd also do a wet test for good measure.
T
tdskip
Rob, I was afraid someone was going to say that about the spread....
Could the valve's just be out of wack?
Permission given to tell be bold faced lies if it makes me believe that I really don't need a rebuild. LOL.
Kurtis
The 20 psi spread is a little high, but in itself, I wouldn't think it would warrant an immediate rebuild. However, the condition of the plugs indicates that you may be getting excessive amounts of oil in the combustion chamber. It wouldn't hurt to adjust the valves and try again, but I don't think it will make that much difference.
As Rob suggested, make sure you warm it up and try again. A wet compression test will tell you if it's valve or ring related - If compression goes up after you a add oil, you have bad rings. But the pattern you described in the previous thread seems to suggest valve guide seals may be the culprit. If it is a problem with the valve guide seals, that may not be that big of an issue. I believe they can be replaced (if you're careful) without removing the head.
Good luck!!!
jcatnite
A good leak down test will help you isolate the problem with you engine as well. Combined with the compression test results, you will have a really good idea about what is going on in your engine. Oily black plugs are tough to correct without opening the engine up though bud. There are other avenues for oil to get into the cylinders but the amount they pass is usually pretty limited. I'm not familiar with your particular engine but a good check would be to see how much pressure the crankcase is venting while it is running. If there is a good amount of pressure coming out of the crankcase vent (blowby) and you have oily plugs, probably going to need new rings.
JC
regularman
[ QUOTE ]
[/ QUOTE ] I would take the intake loose and see if there is any oil in there from somewhere. Otherwise I would pull the head off and drop the oil pan and pull the pistons and look for stuck or cracked rings. It might have been run hot and this will do bad things to rings.
jlaird
yep the rings are worn but seemingly not all that bad in my mind, I think the valve guides and such are very suspect.
T
tdskip
OK - so I added a small amount of Marvel Mystery Oil (MMO) to do a wet compression test. Engine was cold for this test.
The results are;
Wet 1-150, 2-140, 3-145, 4-135.
Dry 1-140, 2-120, 3-130, 4-130.
This seems to confirm that the rings are the culprit, right?
Would adding a bit more MMO into the cylinders and crankcase and running her a bit help?
THANK YOU for all of your help - I really appreciate it.
jlaird
Noop, not at all. You found part of the problem. Plan on a valve job and new valve guides while it is apart along with main and rod bearings and prop a new oil pump as long as you are in there. Also check the clutch and throwout bearing, etc etc.
jlaird
No but I would redo them while the engine is apart, hate doing things twice.
Stand by, we'll get more input before you turn a wrench, a second opinion is always good.
regularman
That mystery oil might loosen up the oil rings if they are stuck, but if they have been heated to where they have lost thier spring then that might be it. I would suspect the valve guides or seals more if it smoked on start up and then cleared up after a little run time. If it has oil in it after running then look at the rings. You can pull the head and the oil pan with the motor still in the car and pull the pistons out and check them.
[ QUOTE ]
..... as long as you are in there. Also check the clutch and throwout bearing, etc etc.
[/ QUOTE ]
Love that line. Its how it all starts...
mark
T
tdskip
Holy cow - I think it worked!
Hi folks,
So after two rounds of Marvel Mystery Oil (MMO) in the cylinders and letting her sit for 48 hours I fired up the Bugeye today and....no smoke! Not on start up, not after running her. She seemed smoother too.
Thanks everyone!
jlaird
Re: Holy cow - I think it worked!
Wow, maybe you just had some gumed up rings, I hope.
Congratulations.
zimmy
i put MMO in my oil when i first started up and my 1275 runs wwaaaayy better then expected after its long sleep....; ) ...go MMO! try some seafoam next...spray on pistons, then try it in the carbs while the motor is running........zzimmmmmy
1 Holy Cow! 250 morphed into 441! British Motorbikes 9
L Holy Cow I'm so EXCITED!!! Spridgets 2
Stewart Holy cow MG 6
AweMan Holy Cow! Triumph 9
T TR2/3/3A Fuel filter madness on the TR3 [holy cow] Triumph 11
PATR8 Holy Cow, I have a barn find.... sort of Triumph 4
T Holy cow - the new coil is a huge improvement Triumph 13
Steve_S Holy cow, NICE! Other Cars 6
PC Holy Grail of Italian/Brit sightings Spotted 3
TomMull Post-War Other Herald: Holy Moly! [Why it took me so long to make the accelerator bracket] Triumph 2
Healey Nut Prices for Healeys [Holy C@#p] Austin Healey 22
BillyB62 TR2/3/3A Holy smoke - a PINK TR Triumph 24
T TR2/3/3A tr3 bulkhead holy question Triumph 13
angelfj1 Holy Leakin' carbs, Batman Triumph 28
M Holy Smoke! Triumph 8
Morris Holy crap! Spridgets 22
E Holy mother of pearl !! Furflex! Austin Healey 8
D Holy Bat-Poop. Other Cars 8
S Holy Sprite makes the newspaper Spridgets 1
S The Holy Sprite is painted Spridgets 17
Stewart Holy smokes it runs!! MG 5
jlaird Holy Sprite pics last weekend Spridgets 6
jlaird Holy Sprite Spridgets 0
S Fr Jack in his Holy Sprite Spridgets 8
jlaird Holy Sprite has arrived in Toms River Spridgets 5
jlaird Holy Sprite almost there Spridgets 2
jlaird Holy Sprite now in PA Spridgets 0
jlaird More Holy Sprite Spridgets 8
jlaird Holy Sprite Pics Spridgets 10
jlaird Holy Sprite, from the road. Spridgets 10
jlaird Holy Sprite Spridgets 2
S The Holy Sprite Spridgets 13
B HOLY CRAZY! Spridgets 23
DNK Holy Delivery Batman!! Triumph 17
roofman I FOUND THE HOLY GRAIL OF CAR MECHANICS Triumph 15
19_again new bearings---holy moly MG 19
Daimlerdb18 MGA Holy Blisters! MGA Paint Question MG 22
aeronca65t Rally Video-Holy Moly! Racing 7
Creatrixx Holy clogged coolant holes, Batman! British Motor Corp 17
timbn2 HOLY Crap!!! is this guy for real...??? Austin Healey 5
sparkydave Smokin' in the boys' room and a holy filter... Spridgets 9
R6MGS Holy Truck! Other British Cars 12
Nunyas Holy Vapor Lock Batman! MG 41
G Holy Moly, Now I Need Better Brakes! Triumph 11
Stewart Ahh holy Joseph Hazelwood grrrrr MG 4
Steve Finding the Holy Grail: The car nut's equivalent Jaguar 16
R Holly cow there were four!! TVR 3
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
livinginthepast BE horn never worked. Now it won't shut up Spridgets 12
regularman I worked in the basement a while today. Spridgets 21
