Stewart
For some reason my mg is heck on stereo's and they don't seem to last. My last one a parrot asteroid which is an android based radio that was a great idea but poorly executed, hard bricked.
I know people have wired to ipods to amps with good results but I don't want to deal with plugging in my phone and the wire that's associated with it. So I searched for a bluetooth receiver that would run off a switched source and did not have a built in battery.
I found the Belkin F8Z492TTP Bluetooth Music Receiver fit the bill. While it comes with a ac power supply it voltage wise it's standard usb and uses somewhat common connector. I did get lucky and already have a usb cable that fit the bill. Obviously to power this I needed a usb power supply and found a 12-24v usb charger from amazon.
Installation
Quite simple if you already have an amp. Made 2 wires with bullet connectors on one end and spade connectors on the other for the usb power supply. + to the white/green wire switched power and black to the ground. Usb cord is installed and run to the bluetooth receiver. The blue (or color of your choice) wire to turn on the amp is also bulleted and installed on the w/g wire. Use caution and check the sensing voltage of your amp as some amps may use a different voltage. The bluetooth module comes with an rca to 3.5mm cable and with a female to female connector it's hooked up to the rca cable running to the amp. Pair up your phone/ipod whatever to the receiver and your done.
Sound quality is quite good and it's loud enough to be heard on the freeway with 4" speakers. Volume control is via the volume buttons on my Samsung galaxy s3. The volume buttons always work when a music source is selected even with the screen off. I did try using the headset jack directly to the amp and while it sounded good maximum volume was quite a bit lower than the bluetooth module. Also for those who use smaller speakers installing a set of bass blockers allows you to keep great overall sound without the excess bass distorting the sound.
https://www.crutchfield.com/p_127BB600A2/Bass-Blockers-600-Hz-cut-off.html
Parts List
Blue Sea Dual USB Charger Socket
RCA Jacks Dual Inline Coupler (AH210N)
Blanking plate to cover the hole left from stereo removal
Choice of 2 channel amp and associated wiring
Installation
Parts List
