Help me place the "TRIUMPH" on the rear
rusty55
The resto is complete. I have the triumph nameplate for the rear of the TR3 but there are no signs of any holes where it should mount. Did a 1960 have this installed originally? I assume it's centered but how about top to bottom? Anyone have a measurement? I'm kinda afraid to drill into this thing :eeek:
Kleykamp
Re: Help me place the "TRIUMPH" on the rear
The center hole is 2 5/8" below the front(top) edge of the rear body panel. If you have the truck handle pointed straight down it points at center hole. If you had body work done on the rear panel you might want to feel around on the underside of the rear body,inside the trunk (sorry "boot"). The holes may just be filled with body filler and painted over,in which case you can just, carefully, push the filler out. If you have to drill, make a template on masking tape and drill through it.
Fairview
Does this help? From my (former) TR3B, an untampered with example.
Number_6
Here's a pic of where the rear Triumph plate is placed on my car. It's a '61 TR3A. The bottom edge of the plate is 3" below the edge of the boot opening and the right side of the 'U' appears to be centered under the Boot's lock tab. Hope this helps.
R
rusty55
Thanks guys. I'm just gonna do it. There is no evidence of it ever being there, even from the inside. Thanks for the measurements and pictures
R
rusty55
Since you guys were so helpful i figured I'd give you a picture of the finished product. I know how you all love pictures. Thanks Again
Kleykamp
That's exactly where I would have put it!!!! Looks good. Can't wait to do that to mine.
TR3Acustodian
TR3Acustodian
I'm in the same boat and the original owner said there was never one there. No evidence of holes. I'm torn about adding something that wasn't there on a 95% original survivor from 58. Nobody seems to have a good insight on it's being something that happend.
TR3Acustodian
I'm going to go ahead an install this new badge. Logic: people who look at the rear of this car all ask what it is. Experts will probably look at it like the car is incomplete and missing a badge (even though I have no evidence that one was ever installed - even from the factory).
Geo Hahn
I had to do that when the restorer thoughtfully welded up the holes. A problem I encountered a year later was cracks in the clear coat radiating from the holes.
I don't know how to prevent it but if you have a two stage paint job it's something to be aware of.
TR3Acustodian
All set! Thanks for all your help. Snaps are tricky had to open the mouths a bit to get to accept the peg. Definitely have to ream the holes a little but the real trick is the trunk is curved and the badge is straight. You have to ben the badge a little between each letter. Luckily Moss makes real chromed steel and it bent easily. If anyone has snapped pot metal, believe me I was sweating the first bend not knowing what was in there.
2wrench Help with where to place one more wire set Triumph 14
A Help! Coolant all over the place. MG 1
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
