Help decoding Sprite’s VIN please
Editor_Reid
Platinum
H = Healey
A = Engine displacement between 800cc and 1999cc (originally meant between 800 and 999cc, but since "B" meant an engine between 2000 and 2999cc and there was therefore no letter between A and B to designate an engine between 999 and 1999cc, A came to mean "below 2000cc").
N = 2-Seat Tourer
8 = 8th model in the series (nobody seems to know why the Sprite "series" started with 5).
L = Left Hand Drive.
5560 = The individual chassis number.
HAN8L5560 is a Mark III Sprite with a 1098cc engine, at least originally.
pan
Reid,
Your comment "nobody seems to know why the Sprite 'series' started with 5" needs a response. Has nobody ever considered that AN5 followed BN4? There is said to have been a "BN5" but this designation was never applied to a production model.
But having said that, anyone attempting to make logical sense out of the Austin model designations is looking for trouble.
Cheers,
Alwyn
Michael Oritt
Yes, I too have always wondered about why the early 100-6's were called BN4's. Perhaps it was an admission by some realist that the jump seats were useless for seating and the car was in reality a two-seater, which they later took back when they introduced true two-seated 6's and needed to fall back in line with the Austin system of model delineation.
pan
What I have always found odd is that only us Healey guys use the Austin codes when discussing our cars. All Austin cars and trucks had such codes but you rarely see them used outside Healey discussions.
Alwyn
pbraun Help with vin decoding Spridgets 18
bcliff Help decoding a british license plate Triumph 7
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
