Help! Antifreeze coming between head and block
ichthos
After many years, I thought I was ready to start up my Bugeye. My last step was to pour the antifreeze in. I poured it in, stepped back to admire my work, and went inside to have a glass of wine. When I came out back to the garage I noticed a small puddle below the carbs on the floor. Oh, feces. I am not sure what I did wrong. I can't remember what I did to the head because it has been a while. Any ideas on what the problem may be? What do I need to do and check? Please help me get of Bugeye restoration pergatory.
Kevin
bgbassplyr
Are you sure AF is coming from between the block and head?
Did you tighten and torque head when you installed it?
Correct head gasket?
Water pump tight? Gasket ok?
Thermostat housing tight/cracked?
Top hose fit well and tight on the thermostat housing? Clamp tight?
Antifreeze is slicker than water and will find a way out when water won't. Check the above and get back with answers.
Deleted member 8987
Heater hose at back?
Got a shutoff valve?
Is it leaking out the stem?
Kevin, how about a little more to work with.
948, 1098 or 948 engine?
Copper or composite black head gasket, if copper head gasket, what did you dress it with?
By pass hose on the water pump, heater valve sealed as earlier mentioned?
What torque on the head?
Were the block and head surfaces cehked for straightness, and were either resurfaced?
64rocksprite
Uh oh..Hap - what dressing is required for a copper head gasket? I bought a Payen copper gasket. I haven't torqued it down yet, heads just sitting on there.
I thought 'goop' on the head gasket was a no-no??!
I
ichthos
I have a 948 engine. I know I haven't given a lot of information to work with, but that is because I rebuilt it ten years ago and can't remember a lot. It has sat in my study until I installed it last week. I did retorque the head to specs. I will check every thing listed, and if I can't locate the leak, I will pull the head to give more feedback. I guess compared to all I have gone through with this car, pulling the head will be minor.
Kevin
jlaird
Seems to me that goop on head gaskets is a no no, however that said Copper gaskets do require a bit as I remember.
bigjones
Bronze
Well, the Moss Motors Technical guru recommended 2 to 3 light coats of Copper Kote on their gasket (both sides) (for the 1500cc engine). Their gasket is a Payen (made in South Africa, no less) - a black material with a steel core.
Cheers!
JPSmit
I have been stewing about this one - I seriously doubt it is coming from the head gasket unless something is really wrong. I'd be much more inclined to be inspecting the frost plugs or the hose connections. Assuming the engine is in the car it is amazing how far this stuff can migrate before it hits the ground. (On purpose I think)
It may even be a bit of overflow. All I'm really saying is look for the easy stuff first - twice.
G
Cheers!
Check the Moss catalog, they list the spray sealer along w/ the gasket. Two schools of thought on HG sealer use.
A. on non print-o-seal gaskets no, but o.k on older non sealer type.
B. use no sealer at any time as the head needs to expand and contract freely when it is heated and cooled.
Both thoughts apply to exhast gaskets too.
I've done it both ways and I'm still alive. Supposedly if it's pure dead soft copper, none is needed but the stuff is really hard to find. I think it's called 060. I have no presonal experience in the area.
I've been looking for some to do metal sculpting and can't find any; only harder alloyed stuff. Same goes for pure aluminum. ( avalibility)
Platinum
Permatex High Tack. Or in a pinch (here we go again :wink: ) a thin film of motor oil.
This with Payen copper composite gaskets.
The_architect
I just got my bugeye back on the road for the first time since I bought it nearly a year, after completely rewiring it. Coming home from DMV, and about six miles from home antifreeze starts coating the windshield! I watched my temperature gauge, got home safely, and judging on where it was squirting out, I thought for sure it was a head gasket.
Turned out to be a split in the seam on the side of the bypass hose on the water pump. Don't panic yet, Kevin. Look very carefully at all your hoses.
Charlie
G
Charlie
Especially at the clamp as they tend to cut the hose over time.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Turned out to be a split in the seam on the side of the bypass hose on the water pump[/QUOTE]
I keep one of those accordion style hoses as an emergency spare, but I use regular heater hose for the bypass.
The_architect
Trevor, I agree the accordion style hose looks like trouble in the making. I didn't get a chance to replace it yet, but I must say getting my fat hands into that little space to put real heater hose on there does not look like it is going to be fun. Looks like hours of frustration in the making. Any tips for me? Charlie
I usually do it when the head or water pump is off, but I've read that it can be done using a pair of vise grips to fold and hold the hose then start each end release the grips.
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
E GT6 Help electrical guru needed Triumph 4
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
