TR2/3/3A Has anyone put in a Hi Torque Starter from Moss?
Momikey
I think my starter is going out. Has anyone put in a Hi Torque Starter from Moss? They don't have the rebuilt starters for my TR3a model anymore. I'm sure I can find one somewhere or have mine rebuilt I think but I thought I would just get the Hi Torque starter if it's any good. Any thoughts?
Geo Hahn
Well, you've 'pulled the trigger' so that's that - but the original Lucas is easily serviced and very durable & reliable. Good luck with the upgrade.
M
Momikey
I will keep the original and have it rebuilt. I keep all the original parts I have replaced.
donbmw
Before installing the high torque starter you put some thread locker on the bolts that hold the motor to the mounting flange. Other wise you will be stuck a motor falling off or about to.
Don
Popeye
Bronze
Dumb question, but why upgrade the starter? I've not gotten far enough into my rebuild to decide what I will do. But it seems those that have love it, for example Bill says "the change from the old starter is amazing...highly recommended!" And Geo and Momikey state "the original Lucas is easily serviced and very durable & reliable"
What's the benefit of the upgrade? Weight, and ability to start a cranky engine?
M
Momikey
Well in my case I'm not good at rebuilding starters and really don't know the first thing about it. So my starter is bad so to have it rebuilt would cost me more money at first to get it done then the new one cost and it might take awhile to get it rebuilt since I'm not to sure where to take it any way. Quick fix get the better starter now and have the original starter rebuilt later. :encouragement:
Geo Hahn
...What's the benefit of the upgrade? Weight, and ability to start a cranky engine?
I think the performance improvement may be a somewhat misleading perception as in many cases a failing Lucas starter is being replaced with a new or freshly rebuilt hi-torque unit. In that situation one would expect a dramatic improvement.
The bog heavy Lucas starter may not be for everyone, but I find the common problems that the Lucas starter suffers from after 'only' a half-century of use are often just worn brushes, deteriorating field coil wraps and worn bushings. All things I can deal with.
If the engine is in good nick the starter has a pretty easy job - shoot, I can crank start the engine by hand so that big bomb of a starter should be able to also. Once any issues are addressed the Lucas starter starts the car. I think of it as what psychologists call a hygiene factor... once it can do it's task (start the car) it cannot get better. IOW, a different starter will not start the car twice as well.
The hi-torque versions are lighter and easier to deal with once any fitment issues are resolved but (for me at least) they address a problem I don't have.
donbmw
The high torque starter is easier to replace on the car.
Don
Mickey Richaud
Don
Yep - that happened to the one I had a while back.
groupdeville
On an engine that takes the early-style (pre-TS50000 "bomb shaped") starter, replacing the starter with one of the gear-reduction modern ones will allow greater room for installing a set of headers on the car, and will provide much better clearance for changing the starter after the headers are in place.
With the original starter, even if the header pipes clear the starter, having exhaust-temperature heat right near the end of the starter is not the sort of thing that's good for any electrical component.
The bomb-shaped starter also does have a bit of a weak point in the rubber coupling that's part of the drive: it can slip if the rubber bonded inside it breaks loose from the metal. I vividly remember pulling the TR3 starter on below-zero New Hampshire mornings to jam small pieces of wood in the starter drive coupling to get it to transmit enough power to get the car running. Too young, inexperienced, and impecunious to just get another rubber coupling back in the dark days before parts became more available for the early cars.
Geo Hahn
Assuming both are in good condition... does a gear-reduction starter spin the engine faster or slower than a stock starter (I really don't know)?
I do recall that when hand-cranking the engine a fast pull on the crank seems to be more effective than a slower pull. More like a 'yank' than a 'crank'.
M
Momikey
Well I put the new hi torque starter in today an I also hooked it up using the attached solenoid not only did the grinding noise go away but the car starts right up. I like it.
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
T TR2/3/3A Has anyone put sound deadening in a TR3. Were the results worth it? Triumph 21
regularman Has anyone here put a bugeye front end on a square Spridgets 2
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Got_All_4 TR2/3/3A Has anyone installed one of these slack limiting plates Triumph 4
Got_All_4 General TR Has anyone used these poly bushings Triumph 6
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
Got_All_4 TR2/3/3A Has anyone tried this new steering box top plate Triumph 14
steveg Has anyone used a knock sensor? Austin Healey 0
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
G TR4/4A Anyone know if this car has sold yet? Triumph 0
Sherlock Spokane Race Track, has anyone been there? Racing 3
T TR4/4A Has anyone used steel gear bushings in their TR4 transmission? Triumph 3
G Has anyone here had any dealings with ANGLO PARTS.COM ? Austin Healey 4
JFeher TR2/3/3A Has anyone installed a TR6 OD transmission in their TR3? Triumph 8
MY66AH Has anyone used this paint?? Spridgets 7
H Has anyone changed their electrical distribution? Austin Healey 7
scoutll Exhaust manifold has cracked-Anyone have a spare? Spridgets 2
60TR3A Has Anyone Undercoated Their Car? Triumph 27
scoutll Has anyone had a hardtop shipped? Spridgets 15
S Has anyone ever seen or heard of this? Austin Healey 9
T Advice, has anyone done this Triumph 2
jlaird Has anyone noticed Spridgets 20
NardisCNC Has anyone used the Oberg Engine Tilt Lift?? Spridgets 15
Cookie Has anyone changed wheel cylinders? Spridgets 20
bgbassplyr Has anyone else Other British Cars 9
L Has anyone ever had to.... Spridgets 12
gubba Has anyone here used this Rack & Pinion? Triumph 8
M Side Curtain Rubber Has anyone tried MacGregor? Spridgets 2
T TR6 Has anyone ever made a new TR6? Triumph 20
angelfj1 Octane Boosters - Has Anyone Mixed their Own? Restoration & Tools 5
S Has anyone seen....... British Motor Corp 1
weewillie has anyone Restoration & Tools 12
angelfj1 Liquid Powder Coating - has anyone tried this? Restoration & Tools 4
regularman Has anyone ever done any wind tunnel tests.. Spridgets 22
G TR6 If anyone has had their TR6 on the dyno to tune Triumph 16
C Has anyone seen........ Triumph 6
healeyboz Has anyone.... Spridgets 5
MGBGT_noob MGB Has anyone ever tried this with an MGB? MG 10
jlaird Has anyone Spridgets 4
H Anyone Own or Has Driven a TVR Sagaris? TVR 11
mgblue79 Has anyone tried E85? Spridgets 16
AweMan Has anyone ever .............. Triumph 10
roofman Has anyone installed an electronic voltage ... Triumph 19
W Home-made tonneau - has anyone tried? Triumph 15
Nunyas has anyone else seen this? MG 14
J Has anyone converted to TBI? Triumph 11
neilh Has anyone successfully patched a leaking tank? Spridgets 15
1 Has anyone ever heard this tip? "Weeping" head MG 11
bugimike Has anyone seen this on ebay? Spridgets 10
