Hand brake/ Parking brake
Jerry1
My hand brake does not hold well. I checked the cables to the wheels and they are so tight you can play a tune on them.
Other than that the regular brakes work good. They are the drum type.
Any suggestions on how to fix the problem?
Jerry 1
Steve_S
Are you sure the rear brakes are operating properly? The car will stop even if the rears are out of adjustment since most of the stopping power is in the front brakes. Try operating the hand brake manually by pulling the levers at the rear of the brake drums. They should move without hesitation and return themselves quickly.
Keoke
HI Jerry1, be sure the rear brake shoes are adjusted correctly.---Keoke
78MGB
New set of wheel cyls did the trick for me. Went ahead and did the kit, shoes, etc.
Let us know how you fixed it.
J
Jerry1
Thanks for the reply. I will try the parking brake manually first. I never thought of adjusting the rear brakes because the brakes felt ok. I will check the adjustment. If that is the problem it will be an easy fix.
Nunyas
Mine didn't hold well when I first got my car. Adjusting the rear brake shoes fixed the issue for me.
J
Jerry1
Thanks for your help. Right real wheel cylinder was not even working due to bad seal. Left rear brake way out of adjustment. Ordered two new brake cylinders from Moss. They arrived in 3 days. Adjusted the braks and everything works fine. Thanks so much.
/ubbthreads/images/graemlins/savewave.gif
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
S Routing of Hand Brake Cable Austin Healey 6
B MGA Hand brake handle disassembly MG 1
M Hand Brake Adjustment Spridgets 11
Michael Oritt Hand brake adjustment Austin Healey 8
Dave Richards Rear Brake Cylinders not Fitting Hand Brake Lever Austin Healey 2
Tinkerman TR2/3/3A TR 3A Hand Brake Trim Out Triumph 4
PatGalvin TR2/3/3A Hand Brake Lever Fork Triumph 7
T TR6 TR250/TR6 - Improving hand brake mech advantage Triumph 11
J Hand brake rod, twisted? Spridgets 3
T Streched hand brake cable? Spridgets 18
bigjones 1500 Hand brake cable Spridgets 0
I Bugeye hand brake cable questions Spridgets 3
I Bugeye hand brake help please Spridgets 8
J Hand brake cable question. Austin Healey 3
1 Hand brake ratchet gone... Spridgets 3
Tinkerman TR2/3/3A TR 3A Loopy Hand Brake Cable Triumph 10
bighealeysource ADJUSTING THE HAND BRAKE ON A BN1 Austin Healey 1
TonyPanchot Tr hand brake Bush Triumph 4
Tinkerman TR 3 Hand Brake Pawl Release Rod Triumph 3
TR6oldtimer TR6 TR6 Hand Brake Install Triumph 2
T Hand Brake help needed. Triumph 17
drooartz Hand brake for late drums on a Bugeye Spridgets 17
7 Hand brake balance problem Triumph 9
kyreb1862 MGB Hand Brake Problem 77 MGB MG 3
S TR2/3/3A tr3 hand brake handle Triumph 14
A TR4/4A TR4 hand brake boot Triumph 2
R For Sale Original AC Ace/Cobra seats. Early 60's, hand made Leveroll by A.W. Chapman, London Other British Classifieds 12
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
K For Sale Starter Hand Crank Triumph Classifieds 0
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
C Left to right hand drive Austin Healey 2
M Wanted TR3 Hand Crank Guide Triumph Classifieds 3
Got_All_4 TR2/3/3A Hand crank misalignment Triumph 9
Boink Left-hand Drive E-type at Windsor Jaguar 5
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
H weird things painted by hand with a brush Austin Healey 6
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
BN6_2197 Adjustment of hand break BN6 Austin Healey 2
Simmo TR6 Right Hand Drive Conversion Help Triumph 3
Simmo TR6 Right Hand Drive conversion Triumph 5
D 69 E-Type sputters when making left hand turn Jaguar 6
B BN2 First right hand drive model car number 16 Austin Healey 4
B TR6 Right Hand Drive????? Triumph 8
Jer "banning" of right hand drive cars being discussed in this province... Spridgets 12
