Hand Brake Adjustment
mikeamondo
Hi folks... can someone give me a quick description of how to adjust the hand brake? My lever pull all the way up with no resistance. At the very top of the travel, with the lever almost straight up and down, I can feel the brake engage a bit. I'm thinking it needs adjusting.
I've installed all new brakes on the rear, adjusted the new shoes appropriately, and at least with the car on jack stands, the rear brakes seem to function correctly.
On my hand brake assembly, I see the cable come into a small bracket just aft of the rear axle. There is nut outside the bracket, where the cable comes in from the front of the car, and a nut inside the bracket. Problem is, I don't know which one to tighten / loosen etc. in order to try and fix the issue. Both can be turned, so that good. I can see that once it's correct, they should tighten against each other to lock in place.... correct? When I put the lever down and then engage it just a smidge, there is not a bunch of slack in the line... I know I may have other issues.... but how is that bracket supposed to work?
Sorry if this has been covered many times... I looked and couldn't really find a good description.
Thanks!
Mike
SaxMan
Have you checked the adjustment of your rear brake shoes? Mine were too far back from the drum. When I adjusted them, the handbrake worked a lot better, too.
M
mikeamondo
I'm going to double check the adjustment of the rear brakes... Especially after reading the article at the link provided by Nelson above... thanks for that site, by the way... good stuff! I still don't have a good description of how to use that adjuster. I guess I'm just a little slow on this... I know works like bicycle brake cables, but that doesn't really help since I've never understood those little voodoo devices either.
I'm thinking that to 'tighten' the brake, I need to shorten the amount of threaded cable end sticking into the bracket... moving the nut inside the bracket closer to the end of the threads. I'll experiment with it tomorrow....
M
mikeamondo
Also... when I adjust the brakes. Am I turning them out until they click? Mine never came to a hard stop... just a point where they click. Then backing them off a quarter turn or so? And then, of course turning the wheel to make sure it's turning freely.... Is that procedure correct?
Bayless
The way to adjust drum brakes is tighten until you cannot turn the wheel then back off just a little, maybe leaving a very slight occasional scraping sound when turning the wheel. The caution here is that you need to ensure both shoes are in solid contact when you can't turn the wheel so try a little more effort on the adjuster to be sure. For the hand brake, you need to effectively shorten the cable. that is, adjust both nuts away from the end of the cable.
Joe Schlosser
However over time the cable will stretch and the lever will still be straight up even when the cable is adjusted to full tight. I had this on my 60 BE, after almost 60 years it had stretched to the point where tit was at the end of its adjustment.
I had to replace the cable which is a real pain but now the lever is maybe 45 degreed and holds very tight.
M
mikeamondo
Fixed my handbrake and got my brakes adjusted properly all in one go! This link here.... https://spriteparts.com.au/tech/handbrake.html ... this guy's description of the adjustment process was spot on.... My handbrake was not working properly because I had failed to adjust the new rear brakes properly.
I unhooked the clevis pin from the handbrake cable, thus freeing the hand brake so it would not interfere in the adjustment process. Then I cranked the adjusters out until I could not turn the wheels. The first time I only turned them out until I had some resistance.... Nope... need to crank them out until you can't turn the wheel at all. And.... trying to turn the wheel with one hand whilst lying under the car is NOT the same as turning it standing beside the car.... Once tightened down that far, then back off a couple notches until it turns freely with a smidge of scraping sound on the brakes. Then.... adjust the cable nuts until the clevis lines up and you can put the pin back into the hole.
After that, not only does the handbrake engage at a lovely 45 degree angle, and hold the car on a steep ramp... but the brakes feel MUCH better than my short test drive right after the brake job. I could only test in my parking lot this evening, due to rain, but I'll have it on the road soon enough...
Thanks for the continued help!
Mike
M
mikeamondo
Oh... and by the way... my reference to 'clicks' while turning the adjusters... I'm guessing that's what other's have called 'notches'. As it turns, there is a slight releasing of back pressure on the wrench every revolution or so... I called this a click... erroneously... no click really.... I backed of about 4 notches total to get the wheel turning freely after I cranked them down...
Bayless
Congratulations. You are becoming a proper LBC owner.
Jim_Gruber
And with our help you'll be able to rebuild the Front End as well. You've already demonstrated Mechanical Aptitude, Problem Solving Ability, and can follow direction. Since you've been successful so far, I'm fairly certain you can undertake the Front End Rebuild.
histerical
Yes, the adjuster's cone is actually a square shape with the corners rounded off so you will feel a 'notchiness' . You don't really want to end up with the blocks on the high spots.
Michael Oritt Hand brake adjustment Austin Healey 8
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
S Routing of Hand Brake Cable Austin Healey 6
B MGA Hand brake handle disassembly MG 1
Dave Richards Rear Brake Cylinders not Fitting Hand Brake Lever Austin Healey 2
Tinkerman TR2/3/3A TR 3A Hand Brake Trim Out Triumph 4
PatGalvin TR2/3/3A Hand Brake Lever Fork Triumph 7
T TR6 TR250/TR6 - Improving hand brake mech advantage Triumph 11
J Hand brake rod, twisted? Spridgets 3
T Streched hand brake cable? Spridgets 18
bigjones 1500 Hand brake cable Spridgets 0
I Bugeye hand brake cable questions Spridgets 3
I Bugeye hand brake help please Spridgets 8
J Hand brake cable question. Austin Healey 3
1 Hand brake ratchet gone... Spridgets 3
Tinkerman TR2/3/3A TR 3A Loopy Hand Brake Cable Triumph 10
bighealeysource ADJUSTING THE HAND BRAKE ON A BN1 Austin Healey 1
TonyPanchot Tr hand brake Bush Triumph 4
Tinkerman TR 3 Hand Brake Pawl Release Rod Triumph 3
TR6oldtimer TR6 TR6 Hand Brake Install Triumph 2
T Hand Brake help needed. Triumph 17
drooartz Hand brake for late drums on a Bugeye Spridgets 17
7 Hand brake balance problem Triumph 9
kyreb1862 MGB Hand Brake Problem 77 MGB MG 3
S TR2/3/3A tr3 hand brake handle Triumph 14
J Hand brake/ Parking brake MG 6
A TR4/4A TR4 hand brake boot Triumph 2
R For Sale Original AC Ace/Cobra seats. Early 60's, hand made Leveroll by A.W. Chapman, London Other British Classifieds 12
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
K For Sale Starter Hand Crank Triumph Classifieds 0
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
C Left to right hand drive Austin Healey 2
M Wanted TR3 Hand Crank Guide Triumph Classifieds 3
Got_All_4 TR2/3/3A Hand crank misalignment Triumph 9
Boink Left-hand Drive E-type at Windsor Jaguar 5
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
H weird things painted by hand with a brush Austin Healey 6
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
BN6_2197 Adjustment of hand break BN6 Austin Healey 2
Simmo TR6 Right Hand Drive Conversion Help Triumph 3
Simmo TR6 Right Hand Drive conversion Triumph 5
D 69 E-Type sputters when making left hand turn Jaguar 6
B BN2 First right hand drive model car number 16 Austin Healey 4
B TR6 Right Hand Drive????? Triumph 8
Jer "banning" of right hand drive cars being discussed in this province... Spridgets 12
