Hand brake balance problem
70herald
Hi Just took the Herald over to check things out before the safety inspection and we found a problem with the hand brake.
On the tester, one side has almost twice the braking force as the other side (required to be less than 10% difference). the regular rear brakes were properly matched.
The rear shoes are new, but they worked with the regular brakes. Since there is only one cable going to both brakes it obviously isn't that either. Pretty much the only thing that isn't used by both sides is the brakes themselves. When I put is all back together I didn't notice any unusual wear which might explain this but I didn't really look either.
Open to any and all suggestions.
Andrew Mace
So long as the cables (and the wheel cylinders) are free to slide where they need to slid and the pivot points free to pivot (and both sides' rear brake shoes are adjusted properly), I can't see why it shouldn't balance itself out.
Double-check all pivot and slide points for lubrication, and make sure the wheel cylinders do move back and forth. They don't move very far, but they need to do so.
That's all I can think of at the moment, other than to check for obvious damage. (I once had an axle shaft u-joint let go. the flailing end of the axle bashed the handbrake cable guide enough to trap the handbrake cable within; took me awhile to figure out why I couldn't push the car around in my driveway once the tow truck had dropped it!)
AweMan
Take a look at the brake shoes. There is a primary and a secondary shoe on each side {On most cars One Lining is slightly longer than the other}
Make sure they are in thier proper orientation.
It is easy to position them correctly on one side and reversed on the other without noticing. The reversed side will bind much tighter than the normal side will.
Don`t ask me how I know~................
Don Elliott
Is it possible that the linings on the "loose" side need to be set a little closer to the drum ?
You write that you have put new brake shoes in. If so, you need to drive the car and use the brakes for- I don't know - some miles so the linings wear a bit on the high spots and then they will take the shape of the drum. Then you re-adjust them onto the drums and they should be the same on each side. Then you go back and have him re-inspect it.
foxtrapper
Lightly pull the handbrake and then go under the car and look at the cables. Most likely you will find one side is tight, and the other is slack. The cable doesn't slide well across the compensator yoke. If it's not centered, you'll get uneven braking.
70herald
Ok, I feel dumb now. Just took the brake apart, and discovered I put it together incorrectly,
I put the handbrake pivot on top of the hydraulic cylinder instead of under it. OOPS! seems to work properly now. Now I just need to find time during the day to bring it back to the shop to check it out and then bring it over for inspection.
Aweman, at least on these brakes, the shoes are identical.
Andrew Mace
Glad it was that simple!
Right, and they'll fit either way (at least the trailing shoe will; the leading shoe only fits one way because of the handbrake lever). If you look at several different diagrams of these brakes, you'll see the shoes oriented both ways! I suspect it really doesn't matter on these.
AweMan
I knew my 56 tr was that way {identical shoes} But didn`t know about your car. As I stated some cars have a short and a long lining shoe, IF this is the case they must be orientated properly.
Just a shot in the dark, but in any case i`m glad you figured it out with minimal diffaculty.
70herald
Andy, you have lost me here, the shoes are identical, the only difference being whether the installer put them in front or back on the brake. Are you talking about "up-side-down"? I am not sure that they will fit in more than one way.
Andrew Mace
Sorry, yes, I should have said upside-down, and yes, they will fit both ways -- right-side up or upside-down -- on the trailing shoe.
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
S Routing of Hand Brake Cable Austin Healey 6
B MGA Hand brake handle disassembly MG 1
M Hand Brake Adjustment Spridgets 11
Michael Oritt Hand brake adjustment Austin Healey 8
Dave Richards Rear Brake Cylinders not Fitting Hand Brake Lever Austin Healey 2
Tinkerman TR2/3/3A TR 3A Hand Brake Trim Out Triumph 4
PatGalvin TR2/3/3A Hand Brake Lever Fork Triumph 7
T TR6 TR250/TR6 - Improving hand brake mech advantage Triumph 11
J Hand brake rod, twisted? Spridgets 3
T Streched hand brake cable? Spridgets 18
bigjones 1500 Hand brake cable Spridgets 0
I Bugeye hand brake cable questions Spridgets 3
I Bugeye hand brake help please Spridgets 8
J Hand brake cable question. Austin Healey 3
1 Hand brake ratchet gone... Spridgets 3
Tinkerman TR2/3/3A TR 3A Loopy Hand Brake Cable Triumph 10
bighealeysource ADJUSTING THE HAND BRAKE ON A BN1 Austin Healey 1
TonyPanchot Tr hand brake Bush Triumph 4
Tinkerman TR 3 Hand Brake Pawl Release Rod Triumph 3
TR6oldtimer TR6 TR6 Hand Brake Install Triumph 2
T Hand Brake help needed. Triumph 17
drooartz Hand brake for late drums on a Bugeye Spridgets 17
kyreb1862 MGB Hand Brake Problem 77 MGB MG 3
S TR2/3/3A tr3 hand brake handle Triumph 14
J Hand brake/ Parking brake MG 6
A TR4/4A TR4 hand brake boot Triumph 2
R For Sale Original AC Ace/Cobra seats. Early 60's, hand made Leveroll by A.W. Chapman, London Other British Classifieds 12
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
K For Sale Starter Hand Crank Triumph Classifieds 0
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
C Left to right hand drive Austin Healey 2
M Wanted TR3 Hand Crank Guide Triumph Classifieds 3
Got_All_4 TR2/3/3A Hand crank misalignment Triumph 9
Boink Left-hand Drive E-type at Windsor Jaguar 5
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
H weird things painted by hand with a brush Austin Healey 6
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
BN6_2197 Adjustment of hand break BN6 Austin Healey 2
Simmo TR6 Right Hand Drive Conversion Help Triumph 3
Simmo TR6 Right Hand Drive conversion Triumph 5
D 69 E-Type sputters when making left hand turn Jaguar 6
B BN2 First right hand drive model car number 16 Austin Healey 4
B TR6 Right Hand Drive????? Triumph 8
Jer "banning" of right hand drive cars being discussed in this province... Spridgets 12
